Totally bewildered with my ECO4 heat pump installation
No advice here I'm afraid, only solidarity as I'm in a very similar situation. I hope yours gets sorted.
- 32 Online
By cathodeRay , 48 minutes ago
@ashp-bobba wish you lived closer to Wiltshire! My inst...
By pash44pump , 1 hour ago
@jamespetts Interesting post, thanks. Here are my thou...
By GrahamF , 1 hour ago
@editor So… who’s given in and turned the heating on al...
By Lucia , 2 hours ago
By ASHP-BOBBA , 2 hours ago
By dgclimatecontrol , 4 hours ago
By Lucia , 11 hours ago
By ASHP-BOBBA , 22 hours ago
By Tim441 , 1 day ago
By Transparent , 1 day ago
By HCas , 1 day ago
By jamespetts , 1 day ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
