No-code, plug-and-play monitoring for your heat pump
Posted by: @grantmethestrengthIf there any more sensors that are holding registers that you would like to have a switch for let me know, it is pretty easy to create. Might be worth reaching out to the creator and see if he will update the yaml. It is a cool little family project.
Thanks so much for having a look! Only slight problem is, I have no idea where to access the code for the controller, and how to change it 😆 . Is this all in home assistant somewhere?
It is in the ESPHome settings, click on the device and edit and then add the new code. then do an OTA update
Kind Regards
Si
Grant Aerona3 13kW
Sigenergy 10kW Inverter
16kW Sigenstor battery
To update an ESP device using ESPHome in Home Assistant, you have several methods depending on how your device is set up:
## Through Home Assistant UI (Easiest Method)
1. **Navigate to ESPHome Dashboard**
- Go to Settings → Add-ons → ESPHome → Open Web UI
1. **Update via the Dashboard**
- Find your device in the ESPHome dashboard
- Click the three dots menu next to your device
- Select “Install” or “Update”
- Choose “Wirelessly” if the device is already connected to your network
If your ESP device is already running ESPHome and connected to WiFi:
1. **Make your configuration changes** in the YAML file
2. Use the “Install” button in the web interface and select “Wirelessly”
Kind Regards
Si
Grant Aerona3 13kW
- 28 Online
By dgclimatecontrol , 1 hour ago
My heating isn't 'ON' yet, although it is firing up in ...
By Morgan , 2 hours ago
@damonc If the heat pump controller is in a suitable ar...
By HCas , 3 hours ago
The midea has a number of pre programmed WC curves (wit...
By benson , 4 hours ago
If that's the case then you are right to be sceptical, ...
By JamesPa , 6 hours ago
By Lucia , 8 hours ago
By JamesPa , 10 hours ago
By ASHP-BOBBA , 19 hours ago
By Tim441 , 24 hours ago
By Transparent , 1 day ago
By HCas , 1 day ago
By jamespetts , 1 day ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 3 days ago
