Mixing of pipework/components' with different internal dimensions - theory vs reality/practical approach
Also, in terms of positioning of the 22mm-based components, I'd be keen to know others thoughts on where these would go to optimise flow and their performance - examples:
- the mag filter - it disturbs flow so should it go before the circulating pump so that the pump can push most effectively round the circuits and back to the outdoor unit, or should it be the last thing before the return pipe to the outdoor unit so that it has most chance of removing debris from getting to the unit
- the flow sensor - do we want to know the flow nearest the LWT (so it should go before the circulating pump), the flow that would more likely be going round the heating circuits (so after the pump, or does either position actually make any difference?), or on the return pipework - if the latter, before or after the mag filter - pro's and con's to both!
What do people think?
Posted by: @rhh2348
I would suggest:
Mag filter last on return so it filters out stuff before it gets to the outside unit. Do you also have a strainer in you system?
Before the pump is likely to be less turbulent and so more accurate readings possible. If you decide on the return then after the mag filter so you don't get crap in your flow sensor.
Hello All, remember your designing a loop transferring liquid water. The pump just moves the liquid round in circles. It makes no difference to system pressure drop which order you install the components because it's a loop. However your ASHP vendor will specify what should be installed to protect the plate exchanger inside the heat pump.
I would suggest:
Circuit return > globe valve > mag filter > strainer > flow sensor > ASHP inlet > ASHP outlet > pump > globe valve > Circuit feed.
That way you can close two valves and get at everything to do with the heat provider.
But check the installation drawings for your vendor, they will tell you what must go where.
Regards
Bob
No, I don't - reading https://renewableheatinghub.co.uk/forums/postid/15126, @heacol recommends removing the mag filter and adding a Y strainer! Thoughts??Posted by: @robsPosted by: @rhh2348
Agree, however would the DN19 of the flow sensor body not affect performance to the heating circuits?Before the pump is likely to be less turbulent and so more accurate readings possible.
That's a fair shout as long as the sensor body isn't going to create debris...If you decide on the return then after the mag filter so you don't get crap in your flow sensor.
From the heat pump perspective, given the flow rate is most pertinent to LWT, input power, and compressor frequency, it's probably best as the final component on the return (with a significant length of straight 28mm pipe before it to smooth turbulence out) for the unit's optimal operation.
It seems to be normal practice to put the filter on the return pipe to the heat pump so it catches any debris from the main heating system before it gets to the heat pump. I would consider putting the flow meter next to the filter so that there's only one section of plumbing with a smaller diameter in the heat pump circuit. Each change in diameter and velocity creates some extra losses.
Maybe the analogy is imagining that cars could just drive faster through those single carriage section. All that acceleration and extra friction would lead to higher energy consumption. If they go too fast they will also damage the road/pipes. Do too much of that and you’d run out of energy (aka petrol, or pump head). Yep also far from perfect…
- 22 Forums
- 2,097 Topics
- 46.2 K Posts
- 23 Online
- 3,385 Members
Our interview with Henri from Havenwise it out:
By Mars , 4 hours ago
By downfield , 5 hours ago
By Sune , 8 hours ago
No idea, but Google-Fu leads me to Bon chan...
By Scalextrix , 1 day ago
By Aventus Eco , 2 days ago
By Tim441 , 2 days ago
By abam48 , 3 days ago
By Toodles , 4 days ago
By downfield , 5 days ago
