High electricity use – 17kW Grant Aerona 3
Posted by: @jgtukpdI spoke with my electrician just now who told me that the original supply (when hp was installed) was single phase but was upgraded to 3phase just after.
The upgrade to 3-phase was most likely initiated by your DNO.
It's possible that they did stipulate the need for this as a result of communications with your ASHP installer...
... but that he didn't appreciate the significance, and thus proceeded with the work before the supply was upgraded to 3-phase.
That's why we need the correspondence which SPEN sent to your installer.
It should've been included in the documents given to you on completion of the HP work, but there's no problem asking for a copy anyway.
I don't believe Grant offer 3-phase heat pumps.
So if that's what your installer favours, then it's possible he was wary of switching to a different model outside of his comfort-zone.
- 2,177 Topics
- 47.9 K Posts
- 53 Online
- 5,748 Members
RE: Repiping and Reconfiguring our Heat Pump System Including Removing the Buffer Tank
@grantmethestrength, if you pull the trigger on the FRV...
By Mars , 4 hours ago
@judith Yes I agree. They are extremely expensive. ...
By GrahamF , 4 hours ago
RE: Which temperature sensor for a Steibel buffer and Ecodan?
@downfield I have never added a buffer sensor as we nev...
By ASHP-BOBBA , 5 hours ago
Riello NXHM Monobloc Air Source Heat Pump
Hi, does anyone have any feedback on Riello NXHM Monobl...
By dgarvey , 12 hours ago
This is actually based on the same chipset as the Svena...
By Grantmethestrength , 16 hours ago
@adamk what you need is enough battery size to cover 3 ...
By Judith , 22 hours ago
@jarlatheoin do put the MVHR in early it’s not an easy ...
RE: How to Zone with a Single Room with UFH
We have exactly what you describe, one utility room wit...
@agentgeorge Come the Ist of October, the Cosy cheapest...
By Toodles , 23 hours ago
@ashfp Mine does have a buffer tank. That was my experi...
By Andrew J H , 1 day ago
I'm sure you are right, I was just trying to understand...
RE: Preparing for 2nd winter in new build house.
Yuch! So that's basically just an on/off control. I...
Good day everyone. I'm new here and have a few question...
By Edin67 , 3 days ago
RE: MCS certificate SCOP vs real-world performance
That may be contributing to lower than expected SCOP. ...
How it does it's job is something of a mystery although...
By Abernyte , 4 days ago
By bontwoody , 6 days ago
By Scalextrix , 6 days ago
