Ecodan 14kW hot water
Where is your water tank? I'm wondering how it gets so cold, way below room temp. Does it ever actually get to 50 deg at the taps?
I suspect that the temperature sensor may be low down in the tank, such that when hot water is drawn from the tank it is not too long before the cold replacement water from the mains hits the sensor, causing the quick reduction in temperature reading.
I suspect you have your hot water on a timed schedule so that its only allowed to come on at particular times of the day.
If you go to the hot water menu does it show the clock symbol by it, if it does then that means its on a schedule. If you want it maintain the hot water temp 24/7 then press the button under tap icon so that it shows the play symbol, this means its on constantly and will heat the hot water as soon as it drops below 45C as you have a 5C drop temp.
- 2,771 Topics
- 65.3 K Posts
- 1,482 Online
- 7,174 Members
By JamesPa , 18 minutes ago
@jamespa My RFQ went out to 20 companies via email; in ...
By Toodles , 50 minutes ago
By Prunus , 2 hours ago
Indeed. My installers were old school plumbers with flu...
By Old_Scientist , 2 hours ago
Hmmm. We have 500sq metres here (including some very hi...
By Carpenterstation , 3 hours ago
Thank you @majordennisbloodnok – that means a lot, part...
Have you looked at the Nibe website? They list their ap...
By Lizzie , 1 day ago
By Papahuhu , 3 days ago
By Batpred , 3 days ago
By Rob of York , 3 days ago
By springswood , 3 days ago
