DeLonghi Bran 0041MH air source heat pump
Hello,
We have a De Longhi Bran 0041MH ASHP and live in a highly insulated house in Shropshire.
Whilst the unit is excellent I would not reccomend purchasing one due to the total lack of Service Engineers for this Brand.
We have found that Service Engineers are biased towards the mechanics of the machine and have little real understanding of the programing of the controller other than what the manufacturer writes in the manual.
The program need substantial tweaking ,preferably done in Winter whilst the machine is operating near it's lowest temperature limits, for it to achieve the most economical operation.
Whilst we now have a unit that is operating at it's optimum there is still a problem in that whislt in standby mode it is consuming some 0.44Kw/hr which with the current astronomical cost of electricity equates to ...wait for it...£1392.
If anyone knows how to reduce stanby consumption I would be most obliged to hear from them.
Posted by: @01286pHello,
Looking at the manual for your particular model, it would appear that the water pump has a maximum power demand of 0.42kW. I would suggest that you check the controller settings to see if the pump is set for continuous circulation.
Thank you for that Derek, do you have any idea where in the Controller program / ladder I will find the setting for the pump and if so what should it be.
Thank you
Posted by: @01286pThank you for that Derek, do you have any idea where in the Controller program / ladder I will find the setting for the pump and if so what should it be.
Thank you
I'm afraid that I am not familiar with your controller. Having had a quick look through the manual I cannot see anything obvious. I know that on some systems the water pump can be kept running to circulate the water around the system so that its temperature can be monitored. There is often the option to run the water pump periodically rather than continuously for this purpose.
I would suggest that, if possible, you monitor the energy usage when the heat pump is in standby, to see if it is a continuous 0.44kW, or if it is a higher value being switched on and off intermittently. Check to see if the energy consumption varies with changes in outside air temperature. Also see if the controller display gives any indication as to what may be operating.
@01286p if it helps…. we noticed our HP had a defrost control which was set to act at a ridiculous 15degC. So we asked our call centre to assist in resetting it to a lower temperature. This stopped the circulating pump from working all night. (Of course, that might not be your situation)
- 2,367 Topics
- 53.7 K Posts
- 243 Online
- 6,042 Members
@majordennisbloodnok This may be a better thread to ...
By Batpred , 19 minutes ago
RE: Help needed with Grant Aerona 3 issues
Noted. Its a pity you didnt capture the flow rate and ...
By JamesPa , 6 hours ago
RE: Best Heat Pump Brand in the UK
Last Call to Vote & Win! Haven't voted for your Hea...
By Mars , 6 hours ago
Interesting question. To be frank, since I have no inte...
By Majordennisbloodnok , 13 hours ago
RE: Changing from 4-port buffer to volumizer
@andy1618 see the very sage advice from @editor above. ...
By JamesPa , 22 hours ago
The video shows the JK balancer, but the connection of ...
RE: Ecodan unable to hit legionella target temp - what's the consensus?
@9jwr9 Hi, yes this is the issue with every (stand alon...
By ASHP-BOBBA , 1 day ago
@adamk FWIW I managed unintentionally to 'coax' mine in...
You are in essence right. Adia only works with selecte...
No, you haven’t missed out, @batpred. This thread’ll st...
Also, though they weren’t prepared to match the price t...
By Toodles , 1 day ago
RE: How long will your energy contract last?
My INTELLI-FIX-12M-25-08-29 has less than 12 months to ...
RE: GivEnergy 2025 forthcoming batteries and inverters
Then, perhaps @toodles , you should've made a submissio...
By Transparent , 1 day ago
I am wondering if anyone with an EV could find the 7p/k...
Possibly, but it would also reduce DeltaT across the em...
RE: ASHP sizing - value of Heat Transfer Coefficient
@cathoderay It was reminiscent of the BBC Open Universi...
@morgan They are unsupervised these days, can’t get the...
By Toodles , 4 days ago
Exactly. We only need to compare conditions, to decide ...
By cathodeRay , 5 days ago
