[Solved] Daikin Altherma noisy heat pump - help and advice needed
Hello,
So we had another visit yesterday, two installers with lot more experience. They sorted it, in about 30 minutes. They unclipped the pipes from the ceiling joists, so they now just sitting on top of insulation. Said they okay to leave as not moving.
like you all recommended it was pipes attached to joists.
They said from the beginning they wouldn’t have installed as their colleagues had. They would have gone from the top of roof and put the volumiser on top of the airing cupboard. The ceiling was like a drum vibrating from the pipes.
Anyway so far so good and we wasn’t woken last night. hope this may help someone else. We do still have noise but that is purely the ashp and when it’s not on full speed you can’t hear it.
Hi @clairelp I’m not sure if you will see this as it has been some time since your earlier messages, but if you can, please can you let me know the name of the people that helped fix your system? I’m based not too far from you on the Suffolk/Essex border and am having similar troubles with loud, intermittent noises I think coming from the pipes since I had an ASHP installed. It has made 2 bedrooms almost unusable unfortunately. Thank you! (And thanks also to everyone who also helpfully made suggestions on this thread - good ideas for me to back to my installer with).
- 2,774 Topics
- 65.4 K Posts
- 2,349 Online
- 7,177 Members
@mrkfm, I’m definitely not trying to put anyone off get...
By Mars , 2 hours ago
I agree, which is why I am currently resisting buying a...
By JamesPa , 2 hours ago
Is there any expected time frame for an update to be ab...
By Singlespeed , 6 hours ago
Posted by: @springswood I confess to becoming a litt...
By Rob of York , 7 hours ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 11 hours ago
@editor does that mean you have to have two separate ex...
By mrkfm , 1 day ago
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 1 day ago
Depends on what controls the pump! Thats the whole poi...
@renewables345 I would say if it a new build it’s no mo...
By Aventus Eco , 3 days ago
