Anyone taken a thermal image of their ASHP condenser unit?
No, it's R32. A split system so it's pumped from the outdoor unit up the outside wall to the indoor unit in the loft.
if you have witnessed a refrigerant leak then the system will need to be thoroughly checked. The joints are flared and should seat perfectly. If they don’t and it leaks you have a dead system.
These units a preloaded for a run of up to 15m (generally). So in a short run you might be ok in terms of refrigerant load.
however, and this is the important bit. If refrigerant got out, then it is highly likely that moisture and or air got in. These are non compressible and will cause a fault.
the best course of action is to have a proper fridge engineer come out and follow the service procedure to recover the refrigerant, fully nitrogen load and vac test the system. Then add the correct amount of refrigerant for the system. The preload amount should suffice unless it’s a long run.
the risk of not doing this are not just reduced COP but total compressor failure.
That banding is not a good thing.
Internationally recognised award winning installer of heat pumps and stuff
Ooh @seaenergy that's a bit worrying !!! I'll have another go at my installer then. Thanks very much for you advise. It's been running like that for over a year now - is it in trouble ?
I've sent an email to my installer to remind them that I asked about this at the service last April.
@heat-pump-newbie I would want it properly checked out. If there is a refrigerant leak it’s rarely a good thing. You could be very lucky and it’s all good.
The banding can happen for a number of reasons, the bottom coils for example sometimes use a base heater to heat them as that’s the part of the coils that gets the least heat recovery in defrost cycle.
I expect having it properly checked is cheaper than a new unit A lot of installers are not AC guys, when I do split units I bring in a specialist company to do the refrigerant pipework. They may need to get someone in to do the job properly.
- 2,136 Topics
- 28 Online
- 5,662 Members
By DavidAlgarve , 33 minutes ago
@ashp-bobba interesting insights. We also chatted after...
By Mars , 1 hour ago
I’ve not come across this brand, but then again I don’t...
Sanity check please. Battery storage and inverter sizing.
I had one installer essentially wanting to install a ti...
By AdamK , 11 hours ago
The gaps and holes have reduced on heat pumps over the ...
By dgclimatecontrol , 17 hours ago
Forum Handle: EGP01 Manufacturer: Samsung Model: 8K...
By EGP01 , 20 hours ago
By bontwoody , 21 hours ago
By Majordennisbloodnok , 22 hours ago
By Old_Scientist , 4 days ago
By robinlawrie , 4 days ago
By NJT , 5 days ago
By DavidAlgarve , 5 days ago
By Transparent , 6 days ago
By PatrickVito , 7 days ago
By Mars , 7 days ago
By Tim441 , 1 week ago
