Adding ASHP to thermal store.
I have a new heating system design with thermal store to take advantage of heat produced by log burner and oil fired raeburn. The thermal store is prepared foe ASHP with a coil. The store is designed to run at 45 degrees with appropriate radiators. I'm happy with the design, but I don't understand why coil has been included for the ashp when the log burner, raeburn are both just open circuit. This additional coil is causing problems......
Can I run the ashp on common circuit as well?
I can't ask designer why he specified this, we have parted ways but not because of technical issues.
Might it be because the designer assumed the ASHP would be using antifreeze?
10kWh DC coupled battery
@bontwoody could be but the whole thermal store will be treated water, not potable. HW will be DHW.
I know it's needed for solar because of the higher pressures, but can't figure out why for ASHP - I was reading through specs for ASHP for pipe sizings as I need to finalise and order tank when I realised they are OK with common thermal store - as far as I can see.
Need to order tank, there is a significant saving to be made if I drop the extra coil, due to design problems.
@roohairy I plumbed (!) for a thermal store in my last house and was advised to have a splarge pipe rather than a coil in it for the heat pump. I hadnt realised that the whole of the store would then need to have antifreeze in it and the cost of that. In the end I used the solar thermal coil instead which got me out of a hole at the time.
Nowadays I would probably use the splarge pipe and omit the antifreeze using anti freeze valves (or nothing depending on your attitude to risk). In your position I think thats what I would now do if ordering a thermal store.
- 2,814 Topics
- 66.6 K Posts
- 4,164 Online
- 7,223 Members
Buffer tank on a 2 x 14kw Ecodan system
We have a setup where there are 2 x 14kW Ecodan units (...
By fosterl2 , 39 minutes ago
@rob-of-york The Panasonic units also have a microscopi...
By Toodles , 1 hour ago
Posted by: @jamespa My personal view is that we have...
By Rob of York , 2 hours ago
By SusannaSaunders , 2 hours ago
By Mars , 2 hours ago
By Toodles , 8 hours ago
I didn't throw it away. Is there a way to determine wha...
By bobflux , 10 hours ago
By bontwoody , 1 day ago
By Rob of York , 1 day ago
I think you're right! 🤨
By Chilli304 , 4 days ago
