2 bedroom bungalow with a Daikin ASHP
@littlered I get that, but maybe we haven't explained ourselves correctly.
We aren't talking about the thermostats in the house. We are taking about the flow rate temperatures on the heat pump - the heating water temperature. Daikins instruction settings are not potentially the most efficient for you as every house has different heating demands.
Ultimately these settings are what really matter to your costs, not the thermostats
- 22 Forums
- 2,097 Topics
- 46.2 K Posts
- 54 Online
- 3,385 Members
RE: Pressure Drop in primary circuit
Just to update you all. I made up my own fill loop as...
By ohdearism , 15 minutes ago
Hmm Before doing that I would want to be certain that...
By JamesPa , 5 hours ago
By Majordennisbloodnok , 5 hours ago
Sorry Bravo. I have no installer contacts outside the U...
By Mars , 16 hours ago
By downfield , 24 hours ago
By Sune , 1 day ago
By Aventus Eco , 3 days ago
By Tim441 , 3 days ago
By abam48 , 4 days ago
By Toodles , 5 days ago
