14kW Ecodan system ...
14kW Ecodan system installed in a 370sqm new build
7 Users
12 Reactions
 HJD
(@hjd)
Hi all thanks for the comments. Before everyone leaps to conclusions about the amazing performance I have to admit to a typing error at 7am this morning....its actually 270sqm rather than 370sqm! Which makes the stats less impressive!
Posted by: @hjd
Sorry Howard, you only get 5/10 for personal performance, 'must pay attention to detail'. 😉 But your systems performance is still very good, even with your smaller property.
You can obtained data for energy used and energy produced from your FTC controller, which will allow you to calculate your ASHP's Coefficient of Performance (COP), which is a measure of how efficient your system is operating. If you are not certain how to obtain this data, there are a number of videos on the internet, or you could ask one of the friendly forum members.
(@batalto)
@hjd we are very similar. I have a 12kw Midea unit and my floor space is 262m2
262m2 house in Hampshire
 HJD
(@hjd)
@derek-m Indeed - definitely a D- for effort!
I calculated the COP on the Central Heating which is running at 3.7. The DHW is much worse - around 1.6
Posted by: @hjd
Hi Howard,
We will let you off this time, just don't do it again. 😎ย
A Cop of 3.7 seems quite good, though it may be possible to improve this. Producing DHW is always going to have a lower COP because of the higher water flow temperature required. What is the desired temperature setting for your DHW?
You may have read in one of my earlier posts today that I am developing a spreadsheet which models an Ecodan based system. Since you have the same model as Kev (who supplied the Ecodan data), you may also find it of use.
 HJD
(@hjd)
@derek-m I am fairly pleased with a CH COP of 3.7 under this new 'weather compensation' approach. I looked at last year's data, when the ASHP was relying on the zoned room thermostats only, and for 2020 I only achieved an equivalent COP of 2.7.
ON DHW - we have it set at 48deg which is a reasonable balance, for us, between hot water from the tap and energy efficiency. We tried both timed and immediate reheat approaches and found that immediate reheat was more energy efficient (just).
Definitely send me the spreadsheet when you have it. Thx
Page 2 / 2
