Posted by: @craig1980A quick update on my system.Â
I'm running at a COP of around 3.3-3.4 at around 3 degrees outside temp including water heating for an hour at midnight. I'm still messing with settings so hopefully this will increase. Once the cold weather arrives the COP definitely drops.Â
LWT at around 28-29 degrees and WC is on.Â
Derek got to the bottom of the issue. I was running the WC settings incorrectly. There are 3 options which run the pump in different ways whilst WC is on and one of those tells the pumps to turn off after 7 mins then back on. That's why it was short cycling.Â
I still need to contact Samsung and I'll let them know about this thread. My Teva out sensor is showing -50 so I may need a new sensor there. I've checked the outside heat pump and it is all plugged in properly. I'll reply on here with any updates.Â
Craig (@craig1980) would you be kind enough to provide @iantelescope with details of the changes that you made to the controller settings to stop the short cycling.Â
Â
Hi Derek,
Many thanks for the data.
I have tried the Samsung Field bits 2091 Options 1 to 4Â on several occasions.
I too found the field bit 2091 option 4 was suspiciously near to my original 8 minute Cycle time.
Samsung field bit 2091, Water Pump 3 subroutine :
1) Delay for 3 minutes
2) OFF for 7 minutes .
3) ON for 3 minutes.
4) OFF for 7 minutes.
However, I, and the French Samsung Engineer tried all of these settings , multiple times, without any great effect.
The pulsing briefly increases the water temperature, and cycle time during the water cycle .
I Do currently use Water Pump 3 given the 2 C thermostat Hysteresis and the slight resultingincrease in cycle time caused by the extra, mid cycle, Motor pulse.
I have , however tried setting Field bit 2091 , Water Pump 2 subroutine again. given that many other parameters, and settings have changed in the interim.
Samsung field bit 2091, Water Pump 2 subroutine has however a 1 C Hysteresis.
Many thanks to you and Craig.
- 2,208 Topics
- 48.7 K Posts
- 72 Online
- 5,868 Members
We've had a slight glitch with our security software fo...
By Mars , 23 minutes ago
@bontwoody I rather feel that this drawn out episode is...
By Toodles , 31 minutes ago
RE: Samsung Heat pump with Yonos Pico circulating pump running all the time
I think you said you have a buffer. Is it the primary ...
By JamesPa , 1 hour ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
Er...no comment!
RE: 4 Year Ongoing Heat Pump Battle With Poor Heat Pump Installation
@fiona sorry to hear that, and I sympathise with you be...
By Mars , 2 hours ago
Um, not accurate, I’m afraid. CCS type 2 connectors a...
RE: Samsung Heat Pump – Can't Activate TW2 Pipe Sensor (for Delta T Control)
If you do suggest you consider repurposing it as a 2 po...
By JamesPa , 12 hours ago
Fully agree with @cathoderay. My journey took 2 years ...
By JamesPa , 14 hours ago
Tim, Yes ChatGPT thought I could get another...
By Mike Patrick , 22 hours ago
RE: Enabling WiFi: Samsung ASHP on Smart Things App
No problem, @richdorm; glad it helps.
By Majordennisbloodnok , 24 hours ago
If that makes you feel happier then go ahead, but it wo...
I do already have the same basic setup, all room influe...
By cathodeRay , 1 day ago
RE: IVT Greenline high pressure switch and electrical cassette errors
OK. You dont say whether it is from the feeds to/from ...
RE: How can I programme a setback for my Samsung Gen6 8kW heat pump?
Yes, and probably also Adia although the latter has a m...
@editor I am all in favour of provocati...
By GrahamF , 2 days ago
RE: How to Understand Wiring Up a Heat Pump
Morning, On top of what everyone else I would deffo loo...
RE: Sizing a heat pump: Save me from my headache
Got the results back from the one we’re ...
By Mikeatthezoo , 3 days ago
