Indra V2H Trial
I joined twitter just for this, and sent:
"Joined Octopus late Aug with a function smart meter from Ovo, hoping to use Go for our EV. Octopus still can't connect to our elec meter (they do to the gas one). Noticed "uSwitch" wrongly think we have a business meter - related?"
Shortly I got back a Direct Message:
"Hi Rob, I just read your tweet and would love to help. I see you have an old generation electricity smart meter and we’re trying to connect to it. I’ve sent a request and need to wait to see if it goes through. I’ll check again this evening and let you know. Thanks, Hector"
I just checked, and uswitch now works correctly. I think that Ovo setup my meter in an unusual way 3 years ago somehow, such that both uswitch and Octopus couldn't understand it. All good now 🙂
It follows the load quite well. If the Indra box is "on", then the smart meter tends to read between -50W and +50W, except in the cheap 4 hour time.
I think if there's little PV, then we tend to pull in 10W to 50W from the grid - it moves up and down as we draw power - the heatpump kicks in and out (600W), the washing machine and fridge are on - they too intermittantly draw power. When there's some sun (when is that?), then from memory I think we tend to supply a varying 10W to 50W into the grid. Kettle+Toaster will likely draw too much and the Indra box will max out, and we start importing some from the grid - our Indra box is configured to +/-4kW.
- 2,767 Topics
- 65.1 K Posts
- 1,641 Online
- 7,169 Members
If you are considering phasing the project, then I woul...
By GrahamF , 6 hours ago
Of course had the heat source been a heat pump it would...
By JamesPa , 8 hours ago
Never assume, it makes an ass of u and me! OK, tha...
By JamesPa , 10 hours ago
@springswood We have two Daikin single split A2A syst...
By Rob of York , 11 hours ago
No, but the heat pump must be capable of delivering a S...
By bobflux , 2 days ago
RE: Vaillant Arotherm Plus 7KW need a service on it
booked it with Vaillant. will use them until i can find...
By AdamK , 3 days ago
I have seen it stated that the declared calorific value...
RE: Two heating zones to one zone
@transparent Many thanks. The garage is fairly well ...
By Profzarkov , 4 days ago
RE: Vaillant Aurotherm - Heater Wire Position
Ah, good point. I need to check if this was installed i...
By Batpred , 4 days ago
@batpred thanks for getting a copy. Appreciate the supp...
