Tomato Energy
ÂPosted by: @transparent"With the transmission pipeline currently oversubscribed at more than 560GW – three times what is
needed to meet Britain’s net zero goals – there is huge uncertainty around what substations need
building and where."
Surely it is not beyond the capabilities of a government department to sit down with the relevant bodies to weed out the projects that are never going to get built, and then prioritise the rest in an order such that they do know what substations need building where and can make real progress towards rolling out that work at a national level. Or maybe I'm just an eternal optimist 😀Â
Â
- 2,104 Topics
- 46.3 K Posts
- 41 Online
- 3,393 Members
By Toodles , 5 hours ago
By Lucia , 7 hours ago
By Brendon Uys , 10 hours ago
By JamesPa , 12 hours ago
By Scalextrix , 12 hours ago
By ASHP-BOBBA , 1 day ago
By downfield , 4 days ago
By Sune , 4 days ago
