Electricity price predictions
Posted by: @tim441Interesting article on Interconnectors...
https://www.telegraph.co.uk/gift/a552809abbf2e670If Interconnectors stopped for any reason (political...energy demand in other countries.. or even Russia cutting them?)... we don't seem to have any backup or alternative to outages?
The problem is not particularly about 'interconnectors' which are merely a symptom, (or propaganda about 'Russians'), the problem is a privatised grid run for years as a source of profit with minimal investment. It's the same story with all our infrastructure in Britain.
Of course, all you folks who can afford batteries &/or solar are mostly covered. However, most people aren't and as the grid system struggles (which would be happening whether we have renewable generators or not) they are going to pay through the nose for these political failures. This in turn will feed into the naysayers, rinse & repeat.
The only likelihood of being able to mitigate any of this is community energy installations and P2P trading. But Britain is far behind on both of these scores. Sadly.
Community energy installations are a great idea, but the public are made afraid by the press, so its unlikely to happen.
Hoping to be proven wrong!
- 26 Online
@toodles Your use case is indeed very different to mine...
By jamespetts , 1 hour ago
By Tim441 , 2 hours ago
Hell no, October as a matter of principle. If I had my ...
By Old_Scientist , 2 hours ago
By Toodles , 2 hours ago
Seems a lot of work with hit or miss results and potent...
By dgclimatecontrol , 3 hours ago
@dgclimatecontrol I have no intention of removing the...
By Morgan , 3 hours ago
By Transparent , 3 hours ago
By HCas , 6 hours ago
By jamespetts , 7 hours ago
By HCas , 1 day ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
