Optimising DHW in summer (once heating season ends)
I'm trying to understand how flow rates affect DHW heating efficiency with a view to optimising flow rates in summer once heating is no longer required.
My system uses fixed rate pumps, so is it more efficient to set a faster or slower flow rate for the DHW cycle?
A slower flow rate presumably allows more time for the heat in the circulating water to transfer into the DHW tank and thus widens the dT between flow and return, which means the final LWT would need to be higher to achieve any given DHW tank set point?
That would suggest a higher flow rate may be more cost effective? But then there's the additional electricity cost of running the circulation pump(s) faster, albeit for a relatively short period of time (my Wilo pumps use ~30Wh more running at max speed versus turning them down by one setting, so maybe 15W over the 30min DHW cycle so probably negligible at a saving of around 1% of the overall electrical usage).
I hate the prospect of leaving a few percentage points of performance on the table for what is an otherwise simple change. Or am I just massively overthinking this and it's going to make no meaningful difference?
Posted by: @old_scientistI hate the prospect of leaving a few percentage points of performance on the table for what is an otherwise simple change. Or am I just massively overthinking this and it's going to make no meaningful difference?
Unless you use negligible hot water the energy used by the compressor will dominate, the water pump will be negligible. So you should optimise for that. Some ASHPs have more than one option for DGHW (eg an 'eco' setting) which takes longer but uses less juice. Does yours?
Posted by: @jamespaPosted by: @old_scientistI hate the prospect of leaving a few percentage points of performance on the table for what is an otherwise simple change. Or am I just massively overthinking this and it's going to make no meaningful difference?
Yes, I already run in the Samsung equivalent Quiet Mode for DHW, which limits output to around 70% and which is more efficient.
Now I'm looking at the effects of flow rate. I agree the potential electrical savings for different circulation pump speeds is negligible at ~1% of overall electrical input.
- 2,783 Topics
- 65.6 K Posts
- 1,143 Online
- 7,187 Members
Sound level calculation for air source heat pump permit...
By Rob of York , 7 minutes ago
RE: Adding additional Solar Panels to a DC coupled battery system
@transparent No it was my baby, entirely delivered by m...
By bontwoody , 1 hour ago
This was interesting and seem like its very expensive o...
By ASHP-BOBBA , 3 hours ago
As we know here, the success or not of plug-in storage ...
By Transparent , 5 hours ago
RE: Do I add Air Con or MVHR to existing A2W ASHP?
Samgsung Quint is an A2W heat pump that also does A2A i...
By Rob of York , 5 hours ago
Ah, that makes sense when a combi is in place. The boil...
By Batpred , 22 hours ago
@bobflux Thanks, that gives me something to check the i...
By Paul1098 , 22 hours ago
For Powerwall calibration, avoid forcing repeated deep ...
By EnergyStorageTech , 1 day ago
By bobflux , 2 days ago
All the 45° elbows required for getting the primaries i...
By Singlespeed , 2 days ago
By bobflux , 3 days ago
By Andris , 3 days ago
By Papahuhu , 4 days ago
By Batpred , 4 days ago
By Rob of York , 4 days ago
