Seal the Deal: Don’t Let Your Heat Pump Leak Energy
Heat Pump Insulation
In recent years, one critical aspect of air source heat pump installations has often been neglected: external pipe insulation. As the demand for energy efficiency increases, the importance of using the best possible external insulation for ASHPs cannot be overstated. So let’s delve into why high-quality external insulation is essential and what characteristics make insulation effective and reliable.
Water Resistance
Moisture can drastically reduce the thermal efficiency of insulation. When insulation becomes wet, its thermal conductivity increases, leading to energy loss and the deterioration of the material. Therefore, insulation with high water diffusion resistance is crucial. Additionally, sealing all joints and gaps is essential to prevent water ingress through capillary action. If the insulation is not protected and every joint and gap is not sealed correctly, efficiency is seriously compromised.
Optimal Insulation Efficiency
The primary function of insulation is to minimise thermal loss. This requires materials that fit well without being compressed, as squeezing insulation into tight spaces can reduce its effectiveness and cause thermal bridging. Ensuring that the insulation is properly clipped on the outside and sealed around pipes and fixtures is vital to maintaining efficiency and preventing moisture penetration. The issue is exacerbated when using standard plastic trunking designed for smaller air conditioning pipework. For instance, the typical 140mm trunking hides multiple issues because the two insulated pipes have to be squeezed in to fit, reducing insulation efficiency and potentially causing thermal crossover that can affect the heat pump’s operation.
What’s more, installers using thinner wall thicknesses than the 19mm standard compromise insulation further. Since it is impossible to clip on the outside of the insulation correctly, many installers resort to clipping the pipework first and then insulating it, using tie wraps to hold the insulation together around the clips. This method leaves gaps and makes it difficult to ensure a consistent seal, reducing the system’s overall efficiency.
UV Protection and Air Contamination Resistance
External materials are subject to degradation from UV rays. Insulation must have built-in UV protection to withstand outdoor conditions over time. Furthermore, in areas with air pollution, such as near factories or busy roads, insulation needs additional protection to prevent contamination that can impair its function. This level of protection should be present out of the box, as adding UV protection during installation in varying weather conditions is impractical and often ineffective.
Through-Wall Sleeving
When pipes pass through walls, sleeving protects the insulation from damage and prevents pests from compromising the system. Proper sleeving and sealing ensure that the integrity of the insulation is maintained, thereby preserving the overall energy efficiency of the building. Standard shrouds on plastic trunking are often not large enough to cover two separate insulated pipes, leading many installers to use a 4-inch core and soil pipe. This approach is problematic as it is not waterproof, allowing moisture to enter through joints and gaps, creating a microenvironment that can never dry out, further degrading the insulation.
All-Weather Installation Capability
Professional installers often work in varied weather conditions. Therefore, insulation products must be easy to install regardless of the weather. This requirement ensures that installations are not delayed and that the insulation performs as expected in both extreme heat and cold. Products must be designed for general weather conditions to help the professional installer complete the job efficiently and effectively.
Sealing of Joints and Gaps
To maintain efficiency, all joints and gaps must be meticulously sealed. Proper sealing prevents thermal leaks and moisture ingress, which can undermine the insulation’s performance and longevity. The insulation products need to support easy sealing, ensuring that every joint and gap is closed, including those through the wall. If plastic trunking large enough to house the insulation correctly were available, it would need to feature high water resistance, be sealed on all joints, and clipped externally.
Good insulation
Ease of Maintenance
Regular maintenance is essential for sustaining the efficiency of ASHPs. This includes inspecting and maintaining external insulation and ensuring that all joints remain sealed. High-quality insulation products should facilitate easy maintenance, helping to ensure long-term performance and reliability. Annual services on heat pumps and systems must include checking the external insulation and all joints to maintain and protect the system’s efficiency and all external products.
Closing Thoughts
Investing in high-quality external insulation for air source heat pumps is crucial for maximising energy efficiency and protecting the system from environmental factors. By ensuring that the insulation is water-resistant, UV-protected, easy to install in all weather conditions, and properly sealed, professionals can significantly enhance the performance and lifespan of ASHP installations. Regular maintenance further ensures that the insulation continues to function optimally, providing consistent energy savings and durability.
This article was written and provided by Primary Pro. Their bespoke insulation solutions not only maximise heat pump efficiency but also enhance the aesthetic appeal of your customers’ homes, guaranteeing a high-quality finish designed to meet the unique needs of professional installers. Primary Pro offer a comprehensive range of insulation products and tools, from various insulation sizes to innovative sealing solutions, all designed to make installations smoother and more efficient. For more information, visit their website or contact them at info@primarypro.co.uk.
Heat Pumps and Defrost Cycles: The Missing Piece in Performance Data?
NIBE and British Gas Partner to Improve Heat Pump Support for Homeowners
Transforming a Derbyshire Property into an Energy-Efficient Haven
Carpenterstation
20 Comments
Editor
11 months ago
Thank you and . This is just how an “infomercial" should be; heavy on the info and clear about the vested interest for the contributor.
Good article.
Johnmo
11 months ago
Just need to maths to backup the facts stated. Optimization of the insulation thickness for different climates and flow temperature would be good. Otherwise worthless advertising.
Admin
Reply to  Johnmo
11 months ago
@johnmo Primary Pro have a tonne of literature. I’ll ask if they have a document that provides some of this info.
Editor
11 months ago
’Fraid I can’t agree, @johnmo.
What the article says may seem really obvious but we only need to look at the many many examples of badly finished installs to see that basics like this just aren’t front dead centre of many customers’ minds. In many ways if there’s some lagging on the pipes then “the installer must have done a thorough job, mustn’t they?”
To my mind the article is simply laying out some reasonable standards that can save a significant amount of money year on year. We often get caught up in technical rabbit holes for improving performance but the basics deserve an airing too from time to time.
Admin
Reply to  Majordennisbloodnok
11 months ago
@Majordennisbloodnok bang on. That was the motivation behind the article, because external insulation is often neglected and forgotten about, especially on short outside runs to the house. This is just a reminder to homeowners to raise this with their installers. Dave was kind enough to write this piece, which is not a paid or sponsored link – I just thought it would be something helpful and interesting for homeowners.
Admin
11 months ago
Some shoddy external insulation examples for us to gasp at.
Very bad
very bad 2
very bad 18
very bad 14
very bad 13
very bad 8
very bad 7
very bad 6
Barbie1
11 months ago
What parts of the air source heat pump should I be insulating?
Editor
11 months ago
Shocking indeed, except possibly the second one.  Are you certain this isn’t a pair of anti – freeze valves?
Rod
Rod
Reply to  bontwoody
9 months ago
Any recommendations on reasonably priced exterior insulation or alternate methods to insulate – e.g. boxing in the exterior pipes and using something else to insulate other than foam? I have about 20m of pipe and am seeing prices of £17 per meter so a £350 cost. My installers used standard grey foam interior pipe insulation on the outside pipes, I didn’t know enough to challenge them and it’s quickly degraded.
bontwoody
Reply to  Rod
9 months ago
@Rod 28mm Primary Pro is just under £10 per metre (ex vat) at BES, Rod
Rod
Rod
Reply to  bontwoody
9 months ago
Many thanks – that is a saving, but still seems pretty high! Has anyone found inexpensive solutions to exterior insulation where there is the ability to cheaply box-in the pipework over whatever is insulating them?
bontwoody
Reply to  Rod
9 months ago
@Rod Well as long as you are boxing the pipes in, I suppose a closed cell expanding foam might work well. Dont use an open cell one though, I tried that in my early heat pump years and when I came to remove it, the whole thing was full of water 😲
Johnmo
11 months ago
None
You insulate the piping, valves (not anti freeze valves) between the house and the ASHP. So from the outlet connections on the ASHP to and through the house wall.
Derek M
Reply to  Johnmo
11 months ago
None
Don’t forget the pipework inside also needs to be insulated.
Johnmo
Reply to  Derek M
11 months ago
There is a school of thought, that says not to bother if the pipes are inside the heated environment, especially if you are running low and slow on a single zone. See Heat Geek for more information.
Admin
Reply to  Johnmo
11 months ago
@johnmo not entirely sure I agree. Heat loss is still heat loss, regardless of whether the pipes are inside a heated environment or not. Insulating the pipes ensures that the heat is used more effectively where it’s needed, especially in a low and slow single zone system. Why would I want to heat my plant room? The goal should be to maximise efficiency, and pipe insulation is one way to help with that.
Of course, different situations might warrant different approaches, so I appreciate the perspective and will check out what Heat Geek has to say on the matter too.
Johnmo
Reply to  Mars
11 months ago
Heat loss is still heat loss, – not entirely correct, if within the thermal envelope it either contributes to the heat emitter surface area via the pipe surface area, and or balances the hot and cooler areas (voids etc) so heat doesn’t migrate away from area where the radiator is.
Insulate DHW duty pipes, as these would heat the house in summer – not good
It’s a heat geek video on YouTube.
AllyFish
5 months ago
Weekend upgrade, Primary Pro done properly, unlike my installer’s attempt. Less heating the street hopefully 😉
IMG 5788
seatonian
seatonian
18 days ago
Hi – fyi – there’s a dead image link in the ‘Optimal Insulation Efficiency’ section. (hopefully tagging )
20
