How Many Heat Pump Installations in the UK Are Actually Good?
Over the past 5 years, heat pumps have gone from niche curiosity to more of a mainstream solution. Hundreds of thousands of UK homes now have one outside, sold as the future of heating. Cleaner. Cheaper. Better. And for some homeowners, that promise has absolutely been delivered. Warm homes, predictable, steady bills, systems that just get on with the job. But for many others, the experience is far more complicated (and far less comfortable) than they were led to believe.
Most homeowners don’t wake up one morning and decide their heat pump installation is “bad”. That’s not how this plays out. Instead, expectations slowly shift. A room that never quite reaches temperature becomes “one of those rooms”. Bills that jump sharply during cold snaps are brushed off as “just how heat pumps work”. Controls that require constant fiddling turn into routine. Over time, coping replaces questioning, and what might actually be underperformance gets relabelled as “average”.
The word “average” does a lot of heavy lifting in heat pump conversations. It sounds reasonable. Not worth making a fuss about. But in reality, average often masks systems that aren’t doing what they were sold to do. Systems that technically heat the house, but only just. Systems that work most of the time, except when winter behaves like winter. Systems that cost more to run than expected, but not quite enough to trigger an outright complaint.
There’s also a powerful psychological barrier at play. Admitting a heat pump is underperforming means admitting something else: that after spending many thousands of pounds, trusting professional advice and committing to a big change, the outcome might not be what it should have been. That’s not an easy thing to face. Defending the system becomes easier than questioning it. Normalising the issues becomes more comfortable than reopening the conversation. And so the bar quietly drops, not because homeowners are dishonest, but because they’re human.
The industry doesn’t help here. Underperformance is too often cushioned with explanations instead of solutions. MCS don’t have a definition for what good (or bad) looks like. Cold rooms are blamed on defrost cycles. High bills are blamed on the weather. Comfort issues are blamed on the way heat pumps “feel different”.
All of which conveniently ignore the truth that these factors should have been designed for from day one. Cold weather isn’t a surprise. Defrost isn’t a flaw. Lower flow temperatures aren’t optional. They are fundamental design considerations and when they’re not properly accounted for, homeowners end up paying for it in comfort, cost, or both.
So the real question isn’t whether your heat pump works. It’s whether it works well enough. Whether your home stays consistently comfortable across all the rooms you actually use. Whether winter bills rise gently or spike sharply. Whether the system runs in the background or demands constant supervision. These aren’t unreasonable expectations. They’re the baseline for a technology that’s now been sold as mature, efficient and future-proof.
Before you watch the video below where I break things down further, take a moment to be honest with yourself. Do you genuinely think your system is excellent, merely acceptable or disappointing? If you’re unsure, that uncertainty itself is telling.
You can also take part in our ongoing homeowner poll on the Renewable Heating Hub forums and see how your experience stacks up against others across the UK. Vote here.
Win a Sustainable Heat Pump T-Shirt
From Sizzle to Fizzle: The Wacky World of Radiator Heat Output
Nathan Gambling
Running my heat pump for half the cost of a gas boiler
Rachel Lee
4 Comments
I believe that we are definitely in the top 10% and apart from the shockingly high price of energy, are very happy with our heat pump installation. We didn’t just stab a finger into a directory for installers but chose from some 20 possible companies. This took many hours due to my finnickety nature and rather unusual requirements. Cinergi took my constraints into account and we came up with a mutually acceptable proposal.
We now have a system that provides a very even temperature (or as I like to call it, a comfort level) throughout the whole home 24/7. We have a particular need for a somewhat elevated temperature (22.5 deg. C) and our system provides this; even when we had -8 degrees OAT in December 2024. Naturally, the COP took a nosedive for a few days – but we remained comfortable! The system is extremely quiet, the only way of knowing it is running from inside is by opening the airing cupboard when we can then just hear a low level sound from the secondary pump. There is no gurgling, knocking, banging or trickling sounds at all. The Daikin heat pump is also very quiet and we never hear that unless we go into the garden.The warmth is very even without cold or hot areas anywhere in the house and it is only because I am a bit of a tech nerd and like to check things are running correctly all the time that I don’t forget about the heating altogether! My wife doesn’t even have to think about the system at all – it just works as far as she is concerned – after all, she is comfortable!
So was it all rosy? Not quite, there were a few minor niggles during installation – some caused by post-Covid shortages and others by my finnickity nature. (I noticed a pump face was upside down but when I commented, the fitter rectified it in minutes. There were a few lengths of pipe that should have insulation on them for the first metre after leaving the Sunamp Thermino heat battery – again, this was rectified very quickly. Overall, we are very happy – it is a great pity that the other 90% haven’t enjoyed such a good experience. Toodles.
paul kershaw
A topic that goes straight to my heart at the moment, as I’ve recently lodged a complaint about my installer with MCS. As expected, the process is heavily weighted in favour of the installer and designed to put you off initially or give up hope part way through, which I’m tempted to.
My Panasonic ASHP gives a SCOP reading of 4 (would that be one spoon of salt or two, sir?) but that’s more through luck than design. Poor install with plenty of issues, fails the MCS Noise Calculations but the Certifier is avoiding that issue, as expected.
Installer is applying the same principles for install and service as for a gas boiler, the word efficiency is just not in their vocabulary.
It’s been a few years, but we met on Tado (probably) consumer panel and I’m obviously still following your journey.
4
