If your heat pump is costing more than you expected or struggling to keep you warm, start with the symptom you can see. These checks will help you work out what to record, what you can check yourself and what to ask your installer. If you’re weighing up a quote, start with the sizing check.
- Is my heat pump the right size?
- Why isn’t my home getting warm?
- Why is my electricity use high?
- What should my flow temperature be?
- Why does my heat pump keep starting and stopping?
- Why is my heat pump noisy or icing up?
- What if I lose hot water or get a fault code?
- What should my installer have given me?
Ask for three figures from your installer: the home’s design heat loss in kW, the outdoor design temperature, and the heating flow temperature they’ve allowed for. Then find the full model code. The number on the badge describes the model. What you need is its published heating output at the two temperatures used to design your system.
Example: Suppose your home needs 6 kW at −3°C and the system was designed for 45°C flow. A model labelled 7 kW might deliver 5.4 kW under those conditions. In that example, ask the installer how the design covers the 0.6 kW gap and whether the output figure allows for defrost. If a larger model is proposed, ask how low its output can go in milder weather, when your home needs much less heat.
Sense-check the heat loss in your quote, then look up the heat pump’s output at those temperatures. Watch why the kW rating on the badge can differ from winter output.
Work out whether it’s one room or the whole house. For one cold room, note its temperature, the thermostat setting and whether the radiator or underfloor zone is warming. Ask your installer to compare the output of that radiator or zone at your design water temperature with the room’s heat loss. A radiator can feel cooler than it did with a boiler and still keep the room comfortable.
If the whole house falls behind, check the heating schedule and record the indoor and outdoor temperatures over a cold spell. If the controller shows a target and actual flow temperature, write down both while it’s heating. Those readings give your installer a place to start. Read what affects heat pump performance in UK homes.
Start with kWh used and the price paid per kWh. Compare days with similar outdoor temperatures and indoor settings. If you have a dedicated heat pump meter, use that to separate its use from the rest of the house. Check whether your app reports electrical energy used or heat produced, and note whether the cylinder immersion or backup heater ran.
For a simple estimate on a flat tariff, 20 kWh at 25p per kWh comes to £5 in electricity use before the standing charge. On a time-of-use tariff, add the usage cost for each price period. If consumption stays high on comparable days, share a day’s readings and its outdoor temperatures with your installer or the forum. Read how electricity prices and efficiency affect running costs.
Flow temperature is the temperature of the water going to your radiators or underfloor heating. With weather compensation, the heat pump usually needs warmer water as it gets colder outside and cooler water on milder days. The useful question is how warm the water needs to be for your home to stay comfortable. A suitable setting depends on the heat loss and the radiators or underfloor heating in your home.
Check whether your controller is set to a fixed flow temperature or a weather compensation curve. Record the outdoor temperature, target flow and indoor temperature on a mild day and a cold one. If you’re unsure which settings you can adjust, ask your installer to show you the homeowner controls. Try the weather compensation simulator.
A heat pump may cycle in mild weather when the house needs less heat than the unit can supply continuously. Take a few hours of readings while it’s heating the house and note roughly how long each run lasts, how long the unit waits before starting again, and which heating zones are active. Look for a repeated pattern of brief runs and mention any fault codes or rooms that stay cold.
Short runs can have several causes, including controls, limited water flow or how much water is available to circulate when zones close. If your controller displays a flow rate, record it along with the symptoms. Read how water volume affects run times and how to interpret a flow reading.
Note when the noise starts, what the system is doing and whether it’s new. A short recording from a safe distance can help. If the noise is a persistent hum indoors, note where you hear it and whether it changes as the unit speeds up. Frost on the outdoor coil in damp, cold weather may clear during a defrost cycle, sometimes with a brief plume of vapour.
Persistent grinding or rattling, or thick ice that keeps building despite defrost, is worth reporting to your installer. Leave the casing in place and keep tools away from the coil. Compare real-world heat pump noise or read how defrost affects heating output.
Check whether space heating still works, whether hot water is scheduled, and what temperature the controller shows for the cylinder if it displays one. For an error, record the exact code, full model number and whether it happens during space heating, hot water or defrost. Use your model’s manual when looking up the code. If heating or hot water has stopped, or the error keeps returning, contact your installer or manufacturer support.
Before you accept a quote, ask for the room-by-room heat loss, the design temperatures, the proposed radiator or underfloor heating outputs and the exact unit model. After installation, ask for the commissioning record and a handover showing you how to run the system, read its energy use and get support. If something is going wrong, gather those documents alongside a short log of the symptoms. Use the homeowner commissioning checklist.
Get help with your own system
When you ask for help, include the model, whether you have radiators or underfloor heating, when the problem occurs, and the readings or fault code you can see. A screenshot of the relevant graph is useful after you remove personal details.
Ask the Renewable Heating Hub community for help interpreting your readings or comparing experiences.
