Wood burning boiler stove installation
Hi all,
After you all helpfully pooh-poohed my idea of a high temperature heat pump (and I'm glad you did as I continue to see horrendous tales all over on heat pumps in general!), I've been looking around at other options.
As I sat today with our existing wood stove pouring out masses of heat and the lounge slowly melted from the few logs I'd put on it, I thought the answer could be burning me in the face.... 😆Â
So I'm now looking at the idea of a stove boiler and would be interested in general thoughts!
1) how easy are they to retrofit? Can you attach them to any part of the radiator system or does it need to be plumbed to certain spots?
2) which are the best brands? We've currently got an insert style stove, so ideally would got with something similar
Any thoughts/advice most welcome!
- 2,809 Topics
- 66.4 K Posts
- 2,778 Online
- 7,215 Members
Potentially the largest data centre hub in Europe and t...
By Jeff , 32 seconds ago
At current oil prices I think you might be able to do a...
By JamesPa , 17 minutes ago
I hadn't realised that but it sounds like another nail ...
By JamesPa , 19 minutes ago
Because, if the boiler has failed, who is going to put ...
By JamesPa , 35 minutes ago
The principal cause of inefficiency if a heat pump is n...
By JamesPa , 13 hours ago
By Papahuhu , 13 hours ago
By bobflux , 17 hours ago
By mk1234 , 20 hours ago
Insolvency is brutal. I have experienced three, two as...
By JamesPa , 24 hours ago
By Watcher , 2 days ago
By trebor12345 , 2 days ago
