Route of primary he...
Route of primary heat circuit through block and beam floor
3 Users
0 Reactions
 olly
(@olly)
This is a bit of an odd question, but please bear with me if you can 😀 I am having an extension to my house built. It will have block and beam concrete floors with UFW. The primary circuit or "heat main" needs to run from the "boiler" room in the house about 10 metres to the external wall where the ASHP outdoor unit will be. The question is really whether this should be:
1) somehow buried inside the insulation + screed in the floor. I think the pipes are 28mm, but will need some form of insulation. Any heat loss would be into the house. Also the pipes would have to be placed in such a way to not impact UFW pipes
2) pre-insulated pipes should drop underneath the void in the floor and out. Any heat loss would disappear into the air that flows through the underfloor and out the vents
I have two heating engineers I am talking to, and they come up with different answers. The architect says that the ASHP manufacturer would have an opinion, but that seems fairly unlikely as their installation manual says nothing. It seems that there are so many possible types of buildings that trying to provide this advice for all countries would be a Sisyphean task. The builder seems to think the architect or heating engineer should know.
Has anybody had an installation with block and beam floor? If so, what did they end up doing?
(@william1066)
Posted by: @olly
You need to check the building regs on that.
Posted by: @olly
Not block and beam, but we did have 100mm concrete 150mm celotex and 100mm concrete, this for a polished concreted floor with UFH.Β  I expect with block and beam, you should have a void under the floor and could do something similar.
We have about 5m of pipe under this floor to the boiler room and another 17m to the heat pump.Β  For this we used "Microflex UNO" 32 for the flow and return, mostly because it had the smallest bend radius of anything I was able to find and reasonably priced.Β  We put this 90mm pipe (diameter of the casing) inside two even larger twin wall pipe that was pretty robust.Β  It is in theory, possible to take the microflex pipe out and replace it with limited damage to the boiler room floor.Β  You will also notice I put some 25mm water pipe in as well as conduit for the control cables to the heatpump.Β  It has only been running for 1 month now, but seems to be working well.Β  The picture below is inside.Β  Outside I did put some 100% waterproof connectors on that are pretty expensive, they stop water getting into the insulation.Β  In hindsight, I am not sure thatΒ  I should have used PTFE on the connectors, so don't follow me on that one, I should have probably used hemp and sealer.Β  PTFE seems to work though, no pressure loss in 30 days so far.
Note: I did not fully appreciated the heat loss associated with pipes in the ground, even well insulated ones, so do your research on that front.
(@hughf)
Not B&B, but my builders are doing a class Q conversion at the moment and they laid a couple of lengths of 32mm pex-al-pex in between the layers of 75mm celotex that they used for their floor insulation.
If I was doing B&B (which I would never do, hateful system) then I’d just use microflex uno or duo and route it in the floor void and use a lintel to bridge over the missing block in the footings where It comes outside.
 olly
(@olly)
Thanks for the replies @hughf and @william1066. You have given me food for thought. If I get a definitive answer on the way it should be done from building control, I'll report back.
