Mitsubishi Ecodan-Zubadan in Hybrid /backup configuration with gas boiler
Hello!
I own a Mitsubishi Ecodan / Zubadan ASHP 14kW with a gas boiler attached as backup heat source. It can help in colder periods but it should also switch based on energy price.
Mitsubishi also released this document
Which states that it can be achieved but it is not technical.
The HP has an Intelligent operation mode where it can select Cost based between electricity and gas based on the price/kW of each energy.
I expect as example that at a certain outside temperature,
COP=3 and 3kW of heat are produced from 1kW electricity
1kWh electricity costs 0.6. But it produces 3kWh heat with a cost of 0.2 /kWh heat
1kWh produced with gas costs 0.2 => it produces 1kWh heat with a cost of 0.2
=> it should stay as it is for now. As soon as the outside temperature drops and COP drops => it should switch to gas boiler which becomes cheaper /kWh produced.
Settings:
Service menu / Operation settings / Boiler Operation / Hybrid settings/Priority Mode: Cost
Service menu / Operation settings / Boiler Operation / Intelligent settings/Energy Price / Electricity: 0.6 */kWh
Service menu / Operation settings / Boiler Operation / Intelligent settings/Energy Price / Boiler : 0.2 */kWh
I can force a boiler operation when accessing
Service menu / Heat source setting (Standard/Heater/Boiler/Hybrid *7) : Boiler.
But when i select Hybrid, it only runs on HP, although it should switch based on the Cost setting.
To test, I used a ridiculosly increase price for electricity (1000x) and it does not switch to gas.
I can also force only boiler operation using the settings:
Service menu / Operation settings / Boiler Operation / Hybrid settings /Outdoor ambient temperature: HP-Boiler when under -15 and Boiler to HP when over 1 (deg C). But it does not account the cost variable and it never switches.
The manuals say very little about this topic. They say it should work.
if anyone has this setup and can advice or is an installer that did this before. thank you in advance for helping me out.
- 2,541 Topics
- 59.2 K Posts
- 249 Online
- 6,822 Members
Recent daily electricity bills in kWh.
By bobflux , 41 minutes ago
I've been watching this with interest as I would like s...
By JohnnyB , 59 minutes ago
RE: Aerotherm 12+12kw cascade huge power utilisation
What the hell. There is exactly one reason to use a h...
By bobflux , 1 hour ago
Thanks for such a comprehensive response!!! ...
By errmm , 2 hours ago
By Eliuccio , 6 hours ago
As a full price electricity user (nae smart meter signa...
By Abernyte , 11 hours ago
By gajolos , 12 hours ago
By RobS , 13 hours ago
By Toodles , 1 day ago
By ChandyKris , 1 day ago
By Jonatan , 2 days ago
By Gruff2001 , 2 days ago
By antonical , 3 days ago
