Are frost protectio...
Are frost protection valves triggered by low air temperatures?
2 Users
1 Reactions
(@daveheatpumpowner)
New Member Member
Does anyone know if frost protection valves are triggered by low air temperatures (say below a threshold of 3C), or when the water in the pipe gets to that temp? Its just that they seem pointless if they are triggered by the air, as the water can be kept warm by the frost-protection function running the pump when the air temp outside is below 6.
Mitsubishi told me that I don't need glycol to keep the warranty, as long as I have frost protection valves + the frost protection function enabled. My concern is that when the air temp falls below 3C, if the valves dump the water then I wont have heating, despite the frost-protection function stopping any risk of icing.
Obviously if there is a power cut at the same time as low temps then I'd need the valves to kick in, but this is an unlikely combination, especially as I have batteries. Would rather avoid glycol and its efficiency reduction if possible.
This topic was modified 2 years ago 3 times by Mars
The water temperature is the triggering element:
See: https://www.intatec.co.uk/product/anti-freeze-valves/#:~:text=Designed%20to%20discharge%20when%20the,costly%20damage%20to%20the%20system.
Regards, Toodles.
New Member Member
@toodles Brilliant - thank you so much toodles!!
