Ecodan controller- one question and one observation
Is there an easy way to tell what version of the Ecodan controller I have and how do the versions differ?
I've been following a number of 'heat curve' threads as I'm in the process of tweaking ours at the moment. I have found that the Ecodan allows you to put three data points into the heat curve which means you can give it a kink in the middle (up or down). I haven't seen anyone else mention this and I've found it rather clunky to use- but it does work. Once you've set up the max and min you can bung an intermediate point in to make the 'curve' less of a straight line. I'm working with just the two points at the moment and may move on to the middle if necessary.
Posted by: @glpinxitIs there an easy way to tell what version of the Ecodan controller I have and how do the versions differ?
If you look on the front case of the FTC there is a model number. FTC6 is PAC-IF073-BE, FTC5 is PAC-IF063-BE. Lower FTCs have lower IF0X.
Not sure of the differences.
Posted by: @glpinxitI've been following a number of 'heat curve' threads as I'm in the process of tweaking ours at the moment. I have found that the Ecodan allows you to put three data points into the heat curve which means you can give it a kink in the middle (up or down). I haven't seen anyone else mention this and I've found it rather clunky to use- but it does work. Once you've set up the max and min you can bung an intermediate point in to make the 'curve' less of a straight line. I'm working with just the two points at the moment and may move on to the middle if necessary.
Yes we’ve noticed and have used a small mid point kink in the WC curve. Our reasoning for trying this is that we have a large expanse of glazing in the form of bifold doors. These give great solar gain in autumn but the angle of sun later in winter means we lose the solar gain.
We have also noticed that the triple glazed panels of the doors are thermally very effective down to about 4c outside temp, but when it gets colder than that the thermal efficiency is not so great and the bifold doors become something of a cold spot in the room space.
So having a steeper slope at the colder end of the curve and a shallower slope at the warmer end of the curve appears to compensate for varying heat loss through the winter variations. I guess this is unique to our specific circumstances and may not apply to most situations.
its also still a work-in-progress. Our overall insulation levels are quite high so the cold spots do stand out a bit More. Another cold spot is the characterful inglenook fireplace we have in one feature room..... large expanse of single brick thick fireback below a massive oak lintel and difficult to insulate without spoiling the authentic character. Yet another compromise. We’ve tried to keep these areas as small as possible but that’s all.
@kev-m Thank you. On the basis that the book of 'instructions' says PAC-IF07 we'll be series 6 then (counterintuitively). (But at least I can read the cover without having to go and find a magnifying glass.)
- 2,781 Topics
- 65.6 K Posts
- 2,099 Online
- 7,187 Members
@old_scientist Don’t forget to keep an eye on what’s ha...
By Papahuhu , 17 minutes ago
this all reminds me of a scene in Blackadder the 3rd wh...
By mrkfm , 2 hours ago
By Andris , 2 hours ago
The source legislation is here and is definitive The ...
By JamesPa , 5 hours ago
Very nice! Congratulations. Big MLC looks neat whe...
By bobflux , 7 hours ago
By Papahuhu , 23 hours ago
By Rob of York , 1 day ago
One thing a spreadsheet based heat loss calculator can ...
By cathodeRay , 1 day ago
By downfield , 2 days ago
By ian33a , 3 days ago
I did, indeed, go with the 12 KW Vaillant unit.  ...
