Damage (by installers?) on back of brand new heat pump
Posted by: @bob77I was more annoyed that the builders (doing other work, nothing to do with the installation) scratched the top cover of the outdoor unit. I don't know what metal the covers are made out of but I wonder if it might corrode as the scratches go right through the paint in a couple of places.
They will be steel, zinc plated then powder coated. The powder coat will be polyester rather than epoxy, for better UV stability.
Â
- 23 Forums
- 2,098 Topics
- 46.2 K Posts
- 241 Online
- 3,385 Members
By JamesPa , 10 hours ago
By Damon Blakemore , 17 hours ago
Hmm Before doing that I would want to be certain that...
By JamesPa , 22 hours ago
By Majordennisbloodnok , 22 hours ago
By downfield , 2 days ago
By Sune , 2 days ago
By Aventus Eco , 3 days ago
By Tim441 , 3 days ago
By abam48 , 5 days ago
