@editor Have gone with Octopus Energy in the end. Comparing the two quotes, I don't see anything significantly different in terms of what will be installed. So, I assume the extra Aira cost is for the 15 year comfort guarantee. Octopus obviously have the economies of scale, and average the costs over the many thousands they install.
Mrs had to be convinced about the looks though! The Daikin heat pump doesn't look much different from a heat pump we used to heat the above ground pool with, until it was turned off for good. Agreed Aira looks good, but not worth paying almost double what Octopus quoted us.
16 * 435 watts PV
13 kWh Growatt battery
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Sorry, forgot to add the thought process.
The primary factor being how long the heat pump manufacturer has been in the sector, installation costs and reputation of the installer. Would have loved to go with a HeatGeek assured installer, but couldn't justify the cost differential. As ours is a relatively new build and standard installation, couldn't justify the need for the assurity in terms of top notch performance. Would have gone with Aira has the quote been just 1.5 times, but 2X is simply too much to ignore just for the looks.
Also, the fact that Octopus being a big player would have the resources to service and emergency repairs, all adds up. Good reviews from the likes of Speak to the Geek and Jonathan Tracey on YouTube helped with any concerns over quality. In general, I haven't seen any horror stories on the media about heat pump installations by Octopus. So, they are doing something right. It may not be the most efficient, but seems to work.
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
Posted by: @chandykris
If it is just a heat pump install and the number of radiator changes are the same then I can see why Octopus will be cheaper. Aira replaced a lot more of my radiators than Octopus proposed. The improved efficiency of the radiators, the look and size of the outside unit and factoring in a yearly maintenance contract over 15 years made the Aira quote competitive.
Personally I think Aira will be around for many years to come because of the money that has been invested in them to grow in a number of European markets. On the other hand heat pumps are not Octopus's core business, so I do wonder if that part of their business will be sold off in a few years time.
I look forward to following your install journey.
I noticed a few days ago on the Aira app that there is now an option to drop the thermostat target temperature by up to 3°C during the night (user configured time boundaries). Certainly resulted in a more comfortable nights sleep at Chez npru.
@npru Aira proposed 7 radiator changes, so need to see how many Octopus propose to change. Highly likely at least the radiators in four bedrooms need changing.
Will keep you posted on the progress. It would be good to get it installed this winter season, as our heating is usually turned off towards end of March. I want to test the system over colder temperatures if possible rather than wait until next October.
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
@toodles Yes, read on Octopus website that the annual maintenance plan is about £108. That's less than 1/3 what British Gas charge us for boiler servicing. All these savings stack up!
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
@chandykris Indeed, and I think that it is likely the service will be somewhat more thorough than any gas boiler service that BG ever carried out for me! (At well over £400 per year at that!) Toodles.
Sorry to circle back to this discussion again. I may need only a couple of radiators (or less) to be changed if Octopus insist on 50 degrees flow temperature. Playing around with HeatPunk, I see that even at 45 degrees flow temperature I may need only two radiator changes. That kind of skews my decision matrix as I would be comparing apples to oranges if Octopus aren't going to change any radiators vs Aira offering as many changes as my system design demands. Aira is also happy to offer two changes as part of their discounted quote which is about 1.5 times Octopus' quote. Aira's original quote was double Octopus' quote.
Could anyone with an Aira heat pump installation please confirm that they haven't taken any annual maintenance or servicing plan, and it's all covered until the 15 year warranty. Appreciate your thoughts on the same. If that's the case, Aira is still slightly more expensive, but then I don't have to pay any annual servicing for 15 years. That can justify the slightly higher upfront investment costs.
16 * 435 watts PV
1 EV - Mercedes EQB
6 kW Aira Heat Pump
@chandykris we have a AIRA HP and they told me that everything is covered. We can clean the magna filter ourselves and they show you how to do it. Any problem then they will just come out and fix or replace.
@chandykris we had an Aira HP installed early November and have also been told that everything is covered under the 15 year warranty.
We had a slight issue with a fault after installation too and they came over numerous times to sort it out and were very helpful
- 2,131 Topics
- 20 Online
- 5,656 Members
@transparent - as a matter of interest whats 52V for? ...
By JamesPa , 6 hours ago
By dgclimatecontrol , 10 hours ago
By PatrickVito , 15 hours ago
By Mars , 16 hours ago
By Tim441 , 2 days ago
By Tim441 , 3 days ago
By Abernyte , 3 days ago
By Eliuccio , 5 days ago
By Scalextrix , 5 days ago
By Mars , 6 days ago
By Scalextrix , 7 days ago
