Air source heat pum...
[Sticky] Air source heat pump roll call – what heat pump brand and model do you have?
72 Users
51 Reactions
23 K Views
Posted by: @agentgeorge
Buffer Tank or Low Loss Header: Yes
I'm surprised by this.  Is it 2 port or 4 port?
(@brucer)
New Member Member
Forum Handle: @BruceR
Manufacturer: Vaillant
Model: Arotherm Plus 7kW
Type: ASHP
Arrangement: Mono
Area of Country: Southern England
Home Type: House
Size: Square Metres: 227
Insulation Level: Scale of 1 to 10 possibly ~7
Heat Loss Calculation: 8-11kW @ -2C, depending on who did the calculation
Type of Controller: 1 Zone with TRVs on all rads
Type of Control: Weather Compensation
System Type: Radiators
Total Output of Heat Emitters: 13 kW
Buffer Tank or Low Loss Header: No
Secondary Pumps: No
Solar PV System: 1.5kWp
Power Diverter: Yes
Battery System: small 2kwh 500w peak output
trebor12345
(@trebor12345)
Hitachi Yutaki SCombi Heat Pump
(Indoor Unit ) RWD-3.0RW1E-220S-K
(Outdoor Unit) RAS-3WHVRP1
2024 build bungalow
200m2
High level of insulation
Underfloor heating
All 12 circuits are fully open all the time
1 thermostat in family room
3kw heat pump
50 litre buffer tank
2024 build bungalow
Southern england
179 m2
Underfloor heating
7KW heat pump
50 litre buffer tank (4 port)
3.6KW solar panels
Energy used by heating 2527 KWh - 7527 KWh (SCOP 3.5 approx)
 Nell
(@nell)
New Member Member
Mitsubishi 8.5 kW Ecodan Standalone (PUZ-WM85VAA)
(@dowallydrifter)
Forum Handle:@DowallyDrifter
Manufacturer: Samsung
Model: AE160CXYDEK (MCS: EHS R290 16KW)
Type: ASHP
Arrangement: MONO
Area of Country: PERTHSHIRE
Home Type: House
Size: Square Metres: 240
Insulation Level: 7?
Heat Loss Calculation: 13.3kW @ Amb. Temp, of: ?C
Type of Controller: Thermostats (for original UFH on oil))
System Type: UFH both floors (under slate/hardwood)
Total Output of Heat Emitters: unknown kW
Buffer Tank or Low Loss Header: BT 40l
Secondary Pumps: one on one UFH manifold (if I understand the question)
Solar PV System: No
Power Diverter: No
Battery System: No
Commissioned mid May, trying to get to grips with it for summer conditions.
Posted by: @dowallydrifter
What, if anything, are you finding difficult.  What are the weather comp settings?
(@dowallydrifter)
@jamespa
Hi,
No major issues just learning to live with it I guess.  Not sure how to answer the weather comp question
20250625 110710
 Hot water temp is fine at 50C though lower at the tap than we had with oil - no problem.
Just been experimenting with turning heat off in hot spell and monitoring energy use to provide HW for two at-home adults (washing up/showers only).  Noticing bathroom floors distinctly cooler with heating off for 4 days, outside temp has dropped the last few days to mid teens.  Room stats not calling for any heat but bathroom floors on (I believe) open circuits that used to be on timer combined with room demand. (26yo UFH system and controls).  Heat turned back on to auto this a.m. so will see how that goes.
We use the away setting if away for 2-3 days at a time as you'll see on the energy use below.  EDF standard rate as no smart capability here due to poor wireless singals.
Screenshot 20250625 113554 SmartThings
@dowallydrifter
OK.
I would recommend you read this introduction to ASHPs to help you understand a bit more about them and explain the terminology.
Weather compensation ('WC') (Samsung call it 'water law') is the function of heat pumps that adjusts the flow temperature of the water from the heat pump according to the outside temperature, in order to match closely the energy emitted by the emitters with the loss from the house.  This is an essential feature of heat pumps and important to understand.  It also exists on many boilers, but rather stupidly we rarely use it for boilers in the UK.
As the introduction explains heat pumps should, in most cases, be operated (for greatest efficiency) in almost the polar opposite way to the way we operate boilers.  Typically they are most cost effective when left on 24*7 during the heating season, with TRVs/Thermostats set 2 degrees above target temperature so they act as limiters (eg in the case of solar gain) not controllers and are essentially always calling for heat.  The WC curve is then adjusted down so it just heats the house to the desired temperature.  It may be necessary to 'balance' the zones/loops on the LSVs/zone valves.  Again in most cases (there are always exceptions) departing too far from this will significantly increase running costs.  Obviously you wont notice that so much now, but you will in winter!
DHW is generally best reheated once or max twice per day on a schedule, not continuously reheated.  Heating to 50 or even a bit lower is normal with ASHPs - again for efficiency.  I have mine set at 48 which is still hotter than I ever need, so its always diluted in practice with cold water.
Feel free to ask any questions or for more detailed information but I do recommend you read the ABC guide.
(@marcinwloch69gmail-com)
New Member Member
Ebac 5kw - Monobloc R32. Developed and made in UK - Mitsubishi inverter and compressor (twin rotary).
All radiators, - heating not on yet
50Buffer+300L DHW cylinder - combination Cylinder on top of buffer - Also UK made in Telford cylinders.
Controller + Homely app.
For now it works great, but can not say much as i only have it over 6wks.
According to homely DHW COP is around 5.6-5.7 - but i have to add separate electric meter - as even homely say it will show accurate heat energy from DTxflow rate but it has no way to read proper energy consumption. but what i can see - energy usage is negligible now.
(@egp01)
Forum Handle: EGP01
Model: 8Kw R290
Type: ASHP
Arrangement: Mono
Area of Country: Wiltshire
Home Type: House, detached 3 storey
Size: Square Metres: 153
Insulation Level: 2006 standard insulation levels EPC rating A
Heat Loss Calculation: Depends who I asked :-/ Est 5.2 kW @ -1.9C
Type of Controller: Adia
Type of Control: Adia hub with weather compensation Adia flow balancing TRV's and room temperature sensors
Buffer Tank or Low Loss Header: Volumiser only
Secondary Pumps: 1 in Adia hub I believe
Solar PV System: 5.4Kw
Power Diverter: No
Battery System: 2x 8.2 Kwh Gen 1 GivEnergy
GrahamF
(@grahamf)
@editor  Hi Mars, We have just installed a Grant Aerona 290 15.5kW air source heat pump.
Graham
Page 9 / 9
