14Kw Mitsubishi Ecodan ASHP
no - not the legionella cycle and yesterday it was back to the previous pattern - dhw being heated to over 60*C without any input from the heat pump. Further digging required might try to give mitsubishi a ring...
Thank you Justinsb, I am now running Advanced Auto Adaptation and am very impressed. It's using low power and no cycling. I extended the cable to the little FTC box and moved it into the living room temporarily. I removed the signal wires from IN1 and switched SW2-1 to off. With SW5-2 On, selecting Room Temperature mode gives Advanced Auto Adaptation. The only con is that as there is now no connection from the existing house thermostats to the FTC, I have to keep the living room thermostat set the same as the FTC thermostat so they switch off at the same time when the room temperature target is reached, otherwise the UFH pump will run unnecessarily, although it doesn't use a lot of power. I now intend to order a Mitsubishi wireless controller and receiver. (£167).
Any comments?
- 2,136 Topics
- 16 Online
- 5,662 Members
@old_scientist yes already have a 4kwp array on a vener...
By AdamK , 8 hours ago
Thanks for this. My pipe insulation in my garage has...
By JamesPa , 10 hours ago
I've noticed lots of love for them on YouTube too - I w...
By Old_Scientist , 12 hours ago
By ASHP-BOBBA , 13 hours ago
By DavidAlgarve , 22 hours ago
Forum Handle: EGP01 Manufacturer: Samsung Model: 8K...
By EGP01 , 2 days ago
By bontwoody , 2 days ago
By DavidAlgarve , 4 days ago
By Old_Scientist , 5 days ago
By robinlawrie , 5 days ago
By NJT , 5 days ago
By DavidAlgarve , 6 days ago
By Transparent , 7 days ago
By PatrickVito , 1 week ago
By Mars , 1 week ago
By Tim441 , 1 week ago
