14Kw Mitsubishi Ecodan ASHP
no - not the legionella cycle and yesterday it was back to the previous pattern - dhw being heated to over 60*C without any input from the heat pump. Further digging required might try to give mitsubishi a ring...
Thank you Justinsb, I am now running Advanced Auto Adaptation and am very impressed. It's using low power and no cycling. I extended the cable to the little FTC box and moved it into the living room temporarily. I removed the signal wires from IN1 and switched SW2-1 to off. With SW5-2 On, selecting Room Temperature mode gives Advanced Auto Adaptation. The only con is that as there is now no connection from the existing house thermostats to the FTC, I have to keep the living room thermostat set the same as the FTC thermostat so they switch off at the same time when the room temperature target is reached, otherwise the UFH pump will run unnecessarily, although it doesn't use a lot of power. I now intend to order aΒ Mitsubishi wireless controller and receiver. (Β£167).
Any comments?
- 34 Online
RE: Heat Pump Servicing & Maintenance β Good Value or Rip-Off?
Mmm. I have a service package with Mitsubishi which is...
By Abernyte , 44 minutes ago
I couldn't agree more with this. Whilst I still have a...
By JamesPa , 48 minutes ago
RE: Whoβs Caved and Switched the Heating On Already?
Central heating still switched off and will be until Oc...
By AllyFish , 1 hour ago
Please read to the very end of this post, I shift my po...
By JamesPa , 2 hours ago
By Old_Scientist , 2 hours ago
RE: Midea ASHP β how to set weather compensation
By cathodeRay , 16 hours ago
RE: Havenwise App Help & Forum Support β Get the Most from Your Heat Pump
By ASHP-BOBBA , 18 hours ago
By dgclimatecontrol , 20 hours ago
By Lucia , 1 day ago
By ASHP-BOBBA , 2 days ago
By Tim441 , 2 days ago
RE: Heat Pump SCOPs β The Truth Might Not Be What You Think
By HCas , 2 days ago
By jamespetts , 2 days ago
RE: Solar Power Output β Letβs Compare Generation Figures
By GrahamF , 3 days ago
By immunity , 3 days ago
