Home / UncategorizedWhere are UK heat pump installs really heading in 2025?By Mars · 29 December 2025 Please enable JavaScript in your browser to complete this form.Please enable JavaScript in your browser to complete this form.We’re running an anonymous, installer-only survey to understand how heat pump installations are evolving in the UK, particularly around disruption, system design and long-term performance. There are no right or wrong answers. All responses are anonymous and will be published only as aggregated results to reflect the collective direction of travel across the installer base. This is about understanding trade-offs in the real world, not calling out individuals, brands or approaches. How would you describe your primary role? *Sole trader/small businessRegional installer (10+ installs/month)National installerOtherIn 2025, how would you describe your typical customer priority? *Lowest upfront costMinimal disruption to the homeSpeed of installationLong-term running costSystem performance / efficiencyCompared to 2-3 years ago, how has your approach to radiator upgrades changed? *We now upgrade more radiators than beforeAbout the same as beforeWe upgrade fewer radiators than beforeWe actively try to avoid radiator changes where possibleWhen planning a system today, which statement best reflects your approach? *Design first, disruption follows if requiredBalance design and disruption case-by-casePrioritise minimal disruption wherever possibleAim to fit heat pumps into existing systems with minimal changeIf a heat pump system requires significant emitter upgrades to run at low flow temperatures, what usually happens? *We explain the benefits and proceedWe redesign to reduce disruptionWe increase design flow temperatureThe customer usually opts outFor a “typical” retrofit, what design flow temperature do you most commonly work to? *≤35C36–40C41–45C46–50C+50C usually industry How How often are weather compensation curves adjusted post-installation? *Always/almost alwaysSometimesRarelyNeverLeft at manufacturer defaultsWhich statement do you agree with most? *Lower flow temperatures are the single biggest driver of efficiencyFlow temperature is important, but secondary to ease of installModern heat pumps can perform well even at higher flow temperaturesEfficiency differences matter less than customer experienceIn your view, the industry is currently moving towards: *More bespoke, house-specific system designA split market: bespoke at the top, standardised elsewhereMore standardised, repeatable installsHeat pumps as “boiler replacements”UnsureWhich trade-off do you think the industry is implicitly making right now? *Installation speed over lifetime efficiencyCustomer convenience over system performanceVolume over optimisationNo trade-off: improvements across the boardDepends entirely on the installer Looking ahead 5–10 years, which approach do you believe will age better? *Low-temperature, highly optimised systemsHigher-temperature, low-disruption installsA mixed estate of bothIt’s too early to tellCommentIf you’d like to add anything, please feel to leave a comment here, and if you’d like to be quoted on what you said, please leave your name.Submit
Join the conversation
