High electricity use – 17kW Grant Aerona 3
Posted by: @jgtukpdI spoke with my electrician just now who told me that the original supply (when hp was installed) was single phase but was upgraded to 3phase just after.
The upgrade to 3-phase was most likely initiated by your DNO.
It's possible that they did stipulate the need for this as a result of communications with your ASHP installer...
... but that he didn't appreciate the significance, and thus proceeded with the work before the supply was upgraded to 3-phase.
That's why we need the correspondence which SPEN sent to your installer.
It should've been included in the documents given to you on completion of the HP work, but there's no problem asking for a copy anyway.
I don't believe Grant offer 3-phase heat pumps.
So if that's what your installer favours, then it's possible he was wary of switching to a different model outside of his comfort-zone.
- 37 Online
By JamesPa , 29 minutes ago
No I dont think you are missing anything. There is def...
By JamesPa , 2 hours ago
By Cleardene-ashp , 2 hours ago
By JulianC , 3 hours ago
By NJT , 5 hours ago
By Toodles , 5 hours ago
By Transparent , 5 hours ago
By Old_Scientist , 11 hours ago
By cathodeRay , 1 day ago
By ASHP-BOBBA , 1 day ago
By Lucia , 1 day ago
By ASHP-BOBBA , 2 days ago
By Tim441 , 2 days ago
By HCas , 2 days ago
By jamespetts , 2 days ago
By GrahamF , 3 days ago
