Connecting Home Assistant to a Midea Heat Pump
@leichat - very useful. It looks like it has a direct modbus connection. From 3:17 in the video:
Modbus RTU / RS485 connections are two wire (and usually earth) and are usually marked A+ / B-, I think the visible A and B (and the mention of a third party controller) are near enough to mean this LG heat pump does have an accessible direct modbus connection, meaning this particular LG heat pump, and possibly other LG heat pumps, can be added to the list of heat pumps that can be monitored, and possibly controlled, over modbus. I didn't watch the whole video, but I get the impression he used modbus over TCP rather than RTU but that's a minor point, the major one is it has an accessible modbus connection.
My midea (clone) config for an esphome board can be found here, https://github.com/Mosibi/Midea-heat-pump-ESPHome if anyone is interested
Just for the record, here is a comparison of the two ways I have tried to connect to a Midea heat pump, firstly all in Home Assistant using the midea_ac_lan add on to make the connection, which sniffs and/or queries the LAN/wifi data Midea sends to their servers, and secondly over a wired modbus connection and saved to a csv file, which, for display convenience here, I have pulled into HA using a file sensor (HA mumbo jumbo for a file reader). The former shows the ambient outdoor air temp as measured by the heat pump, the second the indoor air temp as measured by the MD02 temp sensor I added recently, which, apart from here being displayed in HA, has nothing to do with HA.
Two things I note: (1) the midea_ac_lan/HA record is flaky (not sure why, perhaps the wifi is flaky), the modbus connection is rock solid and (2) a comparison of the outdoor vs indoor temp shows my building appears to have considerable thermal mass (seen here as 'thermal inertia' - the indoor air temp stays pretty steady even as the outside air temp varies). This may or may not be useful when it comes to comparing continuous vs intermittent heat pump running, which I plan to do once the heating is back on (still currently off as it is mild, and as you can see the indoor air temp is still within an acceptable range).
- 2,171 Topics
- 47.8 K Posts
- 67 Online
- 5,744 Members
PS another useful observation from the last chart I pos...
By cathodeRay , 5 minutes ago
Welcome to the forums. Was there any formal in-person...
By Mars , 6 minutes ago
@transparent Morning. Just put a lengthy post on the AS...
By sbm74 , 23 minutes ago
@old_scientist 3. Some pipe work is ...
By GrahamF , 24 minutes ago
Preparing for 2nd winter in new build house.
Firstly, apologies for what is likely to be a long post...
By sbm74 , 26 minutes ago
@jamespa if I remember the insulation has a notch cut i...
By AdamK , 9 hours ago
RE: MCS certificate SCOP vs real-world performance
That may be contributing to lower than expected SCOP. ...
By JamesPa , 11 hours ago
How it does it's job is something of a mystery although...
By Abernyte , 17 hours ago
Yes I was thinking of outdoor, IP65 batteries with buil...
By Temperature_Gradient , 22 hours ago
@jamespa Thanks. Yeah any adjustments Ive made at pr...
By cliffhanger , 1 day ago
By GrahamF , 3 days ago
By bontwoody , 3 days ago
By Scalextrix , 3 days ago
By cathodeRay , 4 days ago
By Toodles , 4 days ago
