The Changing Jet Stream Could Challenge UK Air Source Heat Pumps
Changing Jet Stream and Its Implications for Heat Pump Installations in the UK
Climate change is not just an abstract, distant threat; it is an ongoing process with tangible impacts on our weather systems. One crucial element of our atmospheric dynamics that climate change is influencing is the jet stream – a fast-flowing ribbon of air high in the atmosphere that plays a pivotal role in shaping weather patterns. Recent studies indicate that the jet stream is becoming more erratic due to climate change. This shift has profound implications, particularly for regions like the UK, where the jet stream’s behaviour directly affects temperature and precipitation patterns.
The Jet Stream, AMOC and Climate Change
The jet stream is driven by the temperature difference between the polar regions and the equator. As the Arctic warms at an accelerated rate – a phenomenon known as Arctic amplification – the temperature gradient that powers the jet stream weakens. This can cause the jet stream to slow down and become more wavy, leading to prolonged weather patterns, whether they be cold spells, heatwaves or storms. In the UK, this altered jet stream behaviour can result in more extreme and unpredictable weather conditions.
A related and critical component of this climatic interaction is the Atlantic Meridional Overturning Circulation (AMOC). The AMOC is a system of ocean currents, including the Gulf Stream, that circulates warm water from the tropics to the North Atlantic. This circulation plays a significant role in regulating the climate of the North Atlantic region, including the UK. As the planet warms, there is concern that the AMOC could slow down due to an influx of freshwater from melting ice caps and increased rainfall, which disrupts the salinity-driven component of this circulation. A slowdown of the AMOC could further destabilise the jet stream, exacerbating the climatic impacts on the UK.
Multiple studies have shown the link between climate change and alterations in the jet stream. Research published in Nature Climate Change has demonstrated that the jet stream is becoming more wavy, which can lead to prolonged periods of extreme weather. Another study in Science indicated that a weakening AMOC contributes to these disruptions by reducing the thermal gradient between the equator and the poles, a crucial driver of the jet stream’s strength and stability.
The jet stream has traditionally acted as a protective barrier for the UK, moderating its climate by steering severe cold and hot air masses away from the region. The UK’s relatively mild winters are, in part, due to this influence. For example, the jet stream helps to keep the frigid Arctic air at bay, ensuring that the UK’s winter temperatures remain relatively moderate compared to other locations at similar latitudes.
Comparison with Other Regions on the Same Latitude
To understand the jet stream’s protective effect on the UK, it’s insightful to compare it with other regions on similar latitudes:
Midlands, UK (Latitude 52°N): Average winter temperature: Around 3°C to -3°C.
Calgary, Canada (Latitude 51°N): Average winter temperature: Around -9°C to -15°C. Calgary experiences significantly colder winters compared to the Midlands due to its continental climate, which is not moderated by the Atlantic Ocean or the jet stream to the same extent as the UK.
Warsaw, Poland (Latitude 52°N): Average winter temperature: Around -2°C to -6°C. Warsaw, while also benefiting from some moderating influences, tends to experience colder winters than the UK Midlands, illustrating the protective role of the jet stream over the British Isles.
Minneapolis, USA (Latitude 45°N): Average winter temperature: Around -10°C to -15°C. Despite being at a lower latitude, Minneapolis experiences much harsher winters than the Midlands. This further emphasises the unique moderating effect the jet stream has on the UK.
Challenges with Colder Spells & Their Impact on Air Source Heat Pumps
Given that most heat pumps in the UK are designed and sized based on the national average winter temperature of around -3°C (colder as you head north into Scotland), if the UK were to experience a month of -10°C or -15°C, would many air source heat pump systems struggle to reach and maintain target temperatures? To explore this, we asked several heat pump installers whether this was a fair assessment. Here’s what they had to say:
David Alston explains that some high-quality ASHPs can maintain their output even at very low temperatures, such as -17°C, by artificially running the compressor at higher frequencies through the inverter. However, he points out, “the colder it gets, the more kilowatts the house will need, often requiring built-in immersion heaters to supplement the heat.” Alston notes that during the cold snap in 2011, while many boilers failed, ASHPs continued to operate. “Customers did understand they would have to wait a little longer for domestic hot water as a lot of the energy was focused on the heating circuit a lot of the time, but it was an interesting experiment,” he says. He also highlights that colder conditions typically mean less wind, which can reduce ventilation losses, and that snow acts as an insulator, enhancing the thermal envelope of buildings.
Brendon Uys states that while theoretically ASHPs might meet design temperatures they are often oversized in the UK due to the calculations used. “Sufficient secondary flow rate on the house side of a buffer can maintain good performance below -3°C,” he explains.
Damon Blakemore expresses concern about operational challenges at extremely low temperatures, such as difficulty in defrost cycles and potential system freezes. “You wouldn’t be able to get out of defrost, and the system would probably freeze,” he says. Blakemore emphasises the importance of backup heaters, like those built into Viessmann units, and suggests that for such extreme temperatures, different design considerations, including the use of glycol, would be necessary.
Sune Nightingale emphasises that extreme cold events, such as temperatures below -3°C, are still rare in many parts of the UK. In London, for instance, temperatures reached -9°C for only two hours over a 20-year period. “The real issue is not the few hours of extreme cold but rather the potential for oversizing heat pumps, which leads to inefficiencies and higher running costs,” Nightingale argues. He notes that outdoor design temperatures vary significantly across the UK, from 2.5°C in the Scillies to around -8°C in Scotland. He suggests that understanding historical weather data and considering climate change impacts are crucial in accurately assessing heat pump performance.
Jason Perry acknowledges that while most systems might struggle during extended cold spells, many heat pumps are unintentionally oversized, which could mitigate some of the potential issues. “The assessment is correct, but it’s not as big an issue as the theory tells us,” he adds.
James Law confirms that heat pumps would struggle to reach their target temperatures at -10°C to -15°C. “The answer is very simply yes, they would struggle to reach their target temperatures,” he says, offering to demonstrate the performance of heat pumps under such conditions using software simulations.
Heat Pump Design and Efficiency: Adapting to New Realities
The design of heat pump systems is crucial in determining their efficiency and effectiveness, especially in the face of potentially more extreme weather conditions. Moving from traditional gas and oil boilers to heat pumps necessitates a fundamental shift in how we heat our homes – transitioning from short bursts of high heat to a “low and slow” approach that maintains a consistent, moderate temperature.
With traditional gas and oil boilers, many households, especially those in fuel poverty, rely on short bursts of heating to quickly warm their homes, often leaving the heating off for several hours to save on fuel costs. This method, while potentially cost-effective with boilers, is far from optimal for heat pumps. Heat pumps are designed to operate most efficiently when maintaining a steady temperature, as frequent on-off cycling can lead to higher energy consumption and increased wear and tear on the system.
For households in fuel poverty, the challenge is significant. If maintaining a set point of 19°C over above becomes unaffordable, the fallback option might be to lower the set point to 16°C or 15°C. While this wouldn’t result in the same cold temperatures experienced when a boiler is off for long periods, it would also mean that the home wouldn’t reach the warmer bursts typical of boiler heating.
Lowering the thermostat set point by even a few degrees can have a significant impact on energy consumption and heating costs. Studies suggest that for every degree Celsius reduction in the set point, households could save approximately 6-10% on their heating bills. This means that lowering the temperature from 19°C to a more modest 16°C could result in a reduction of heating costs by as much as 18-30%.
This cost-saving measure can be especially appealing to households facing fuel poverty, where heating expenses form a substantial portion of the budget. For these households, reducing the set point by a few degrees might mean the difference between being able to afford heating throughout the winter and facing financial hardship.
However, these savings come with trade-offs. Lowering the set point to save on heating bills can lead to a cooler indoor environment, which may not provide the same level of comfort, especially during the coldest days of winter. The impact is particularly concerning for vulnerable populations, such as the elderly, young children or those with pre-existing health conditions. Prolonged exposure to lower indoor temperatures can increase the risk of cold-related illnesses, such as hypothermia, respiratory issues and even cardiovascular problems.
Furthermore, a lower set point may also affect the overall livability of the home. Reduced temperatures could lead to increased condensation and dampness, potentially fostering the growth of mould and mildew. This not only poses health risks but can also lead to additional costs related to home maintenance and repairs.
In balancing these factors, it becomes clear that while lowering the set point can offer financial relief, it is not without its downsides. The decision to reduce the thermostat setting should be carefully considered, taking into account both the potential savings and the health and comfort of the household members. For those in fuel poverty, finding the optimal balance between energy efficiency, cost savings, and maintaining a safe, comfortable living environment is crucial.
Closing Thoughts
The potential for a disrupted jet stream to bring more severe cold weather to the UK presents a significant challenge for the design and efficiency of air source heat pumps. As climate change continues to alter weather patterns, it is increasingly important to question whether current ASHP designs and sizing practices can handle abnormally cold, sustained spells that could last for weeks or even months.
Heat pumps are typically sized based on the assumption of “design temperatures,” which represent the coldest conditions a location is expected to experience under ‘normal’ climate patterns. In the UK, where winters have traditionally been relatively mild, these design temperatures have informed the standard practice of sizing heat pumps to provide adequate heating in typical winter conditions. However, this approach may not account for the potential of extended periods of extreme cold, which could become more common as climate change disrupts the jet stream and leads to harsher winters.
The efficiency and capacity of ASHPs diminish as outside temperatures drop, and if a heat pump is sized just to meet the needs of a home under average cold conditions, it could struggle to maintain adequate heat during prolonged extreme cold spells.
Even heat pumps that are correctly sized according to current standards may turn out to be undersized if future winters bring more sustained and severe cold temperatures than those experienced historically. In such scenarios, the heat pump may run continuously without ever reaching the desired indoor temperature, leading to uncomfortable living conditions and potentially higher electricity bills as the system works overtime.
I’d love to hear your thoughts on this – how do you think we can best prepare heat pumps for the challenges of a changing climate?
The myth that old, leaky houses can’t be heated by heat pumps: a homeowner’s perspective
The Big Heat Pump Survey 2025 – Have Your Say & Shape the World of Renewable Heating
No-code, plug-and-play monitoring for your heat pump
17 Comments
Well, what a bringer of doom, gloom and despond you are today Mars! I feel we have passed the point of ‘no return’ and any form of rectification would be measured in centuries or even a millennium or two.
It is said that the only other similar land mass to experience a similar climate to the UK is the Falkland Isles; being surrounded by a large mass of water provides unique weather conditions. So it looks as though for the foreseeable future, we can look forward (if that is the appropriate term) to greater variability in weather conditions – with greater extremes than experienced in living memory or even within documented historical weather records. When speaking to meteorologist friends, they have always talked in terms of centuries as being but a ‘blip’ in terms of the world’s history –  the last ice age being a relatively recent event.
At school (in the 1950’s) we were taught that the gulf stream influenced our weather by bringing warm ocean currents in our direction – and less seems to have been known about the influence of the jet stream, or if it was known, it had not filtered down to the curriculum as far as I know.
The Scilly Isles have had the ‘buffer’ provided by the gulf stream and this has allowed the islands to enjoy a mainly free of freezing conditions climate for many years (might this now be threatened I wonder?) With the jet stream wobbling or modulating erratically, I suppose we can look forward to even greater truth in the saying “The UK doesn’t have a climate, it just has weather!’
The changing weather conditions might well add more strength to the argument to phase out fossil fuels and ‘come clean’ ASAP (and the ‘P’ needs to be far sooner than 2050 as well! Weather conditions could see a dramatic increase in pollution from fossil fuels with descending winter temperatures – we can hardly afford to sit back and think ‘well it might go the other way and we will be fine’. I’m nearly 77 now and will have to weather it out, but my grandchildren surely have a right to a better and more optimistic forecast than we are hearing about?
One more observation: Methinks that a lot of thought went into contriving the acronym ‘AMOC’!😉
Regards, Toodles.
Derek M
@Toodles
I seem to remember reading once that an ice age occurs every 10,000 years. I think the next one is due a week next Wednesday. 😋
Could you be a little more precise please, is that a.m or p.m.?😉 Toodles.
Massive global events usually happen in the morning. 😆
…but in this case you’ll be fine for a bit of lunch but it’ll ruin your barbecue. You’ll need a rib-sticking hearty slow-cooked stew instead but if you time it right you can cook it for free from the solar leccy generated in the morning.
… how do you think we can best prepare heat pumps for the challenges of a changing climate?
Reverse the change.
Yes, I know that’s flippant and far easier said than done but it feels like preparing heat pumps for a changing climate is tinkering with the symptoms instead of tackling the blindingly obvious cause.
Johnmo
Not saying the content of the article isn’t facts, but it is sensationalising.
Not only heat pumps, most boiler systems are also to have the room radiators sized for -3 deg. They are generally designed for dT50 so very little wiggle room if you start to get -9 degs.
Not really that simple, mine will do -20 on paper, BUT as temp drops to -10 and below the output temp reduces, by -20 the max output temp is 40 degs.  Systems designed to 45 or even the latest trend 50+ at -3, stand zero chance with backup heating.
Last heating season, we had 2 weeks at end of Nov/Dec at between -7 and -9 and again the same in January.  Not really an issue, little shocking seeing the bills, but the house was warm enough
BUT
So for perspective that is about 7% of the year.
For those that have MCS installations, this is what design guide says
Standard MIS 3005, requires the unit to achieve 100% of the duty at an external temperature condition exceeded for 99.6% of the year.
So in my case an MCS install should be designing to meet those temps – i.e. -9 degs in my area, NE Scotland, same is also true for Highlands which can get colder for longer.
Not really sure that is true if the design follows MCS guidelines, if it designed for -9 (our case) it doesn’t matter if its day or several months, its designed to cope.
My reaction is that this is great news for the fossil fuel industry, yet another reason to delay change.
More sanely, the  prediction for the shutting down of the gulf stream is between 2025 and 2095 with a core value of 2050.  If we ignore the extreme because we can’t do anything about it, 2050 is far enough in the future that heat pumps and other central heating systems being fitted now will be due for an update and also far enough that most of our energy will come from renewables.  But even if it’s earlier just add in a 3kW willis heater and that will give enough extra oomph to cover the colder days.  Turn up the ft 5C and the emitters will emit sufficient heat.  Yes it will cost more, but colder days will cost more whatever the heat source.
Ironically the many over-specified ashp systems that seem to be a feature of the industry will perform better if the climate is colder.
It’s probably less of a problem for a system designed for heat pumps than for one designed for dt50, as @johnmo says.
Of course that won’t stop the fossil fuel industry exploiting fear to delay change.
In summery I think this is scare mongering, tells a one sided and distorted story and is probably encouraged by the fossil fuel industry.  Whist the underlying science about the gulf stream is presumably true, the  conclusions reached in relation to heat pumps (when compared to fossil fuel heating) are largely Bow Locks.
Johnmo
However, oversizing also brings inefficiencies and higher running costs in the short term, which we must weigh against the potential long-term benefits. This is what makes this so complicated
With good system design it need not be the case. Our house is new well insulated and pretty airtight with MVHR. Heat pump sizing was done my me on a self install. I chose the heat pump being close enough and it was a really good prices – but it kicks out 6kW at -3 when my heat load is around 3kW. And at an average outside temperature of 10 degs I don’t need heating. Getting a suitable heat pump not that easy and at the time none on the shelf. So not really by design I have a heat pump that’s still ticking over at -9. But I needed to work smart to get it all to work. So no zones, no additional pumps just simple and open. And about 60-70L of system volume.
To support a given kW and not suffer short cycling you need a defined volume of water of 10 to 15L per kW output. Then a bit of fine tuning the running parameters.
I am currently running cooling via UFH – have been for the past month, the heat pump runs for 10 to 13 mins then compressor stops, for an hour or so based on floor return temperature (dictated mostly solar gain) and so overnight there is 3 or 4 hrs between runs.  When the compressor runs it has a starting spike of about 1kW and quickly settle down to about 6-700W. The pattern is pretty similar when I start to need heating. As it gets colder the compressor runs longer.
Low flow temperature is key to flexibility for falling temperature, you need headroom to increase flow temps as needed.
You can live with a perceived oversized heat pump. But you need big volumes of water with large heat pumps. So a 12kW heat pump is needing 120 to 180L. So a big system and/or volumiser or a big 2 port buffer, with hydraulic separation, suitably controlled.
Lucia
Warsaw gets colder winters because it’s further in land. From living in Spain which is 80% mountains I saw how in the summer it is so much hotter inland than the coasts and so much colder in the winter.
We could go snow boarding in Granada on a winter morning and the same day go lie on an Andalucían beach in a bikini in the afternoon. Germany, Romania Poland and Ukraine are good examples of really cold winters and hot summers.
That’s not to deny the impact of the gulf stream on the UK of course but a Spanish meteorologist once told me that the biggest impact on British weather was being a little rock in the sea alongside the major landmass of Europe. He drew me charts of Atlantic weather patterns and how they hit our little rock. 😁
17
