Is Your Heat Pump the Right Size Based on Your Heat Loss Calculation?
When it comes to heat pump efficiency, one of the most important yet often overlooked factors is ensuring the unit is correctly sized for your property. The foundation of determining this is a precise heat loss calculation, which calculates how much heat a home loses during colder periods. In our latest Homeowners’ Q&A episode, we discussed why getting this calculation right is crucial, and how it impacts both performance and running costs.
What is a Heat Loss Calculation?
As Graham Hendra explained, a heat loss calculation is essentially a way to measure how fast heat escapes from your home on the coldest day of the year. The calculation takes into account elements such as walls, windows, insulation and ventilation. The goal is to ensure the heating system can keep your home warm even when temperatures drop to their lowest.
However, it’s important to note that these calculations are only as accurate as the information used. For example, assumptions are often made about insulation levels, particularly in older homes, where records of insulation upgrades may be lacking. This means that even though the calculation might be mathematically accurate, the data it’s based on could lead to errors.
Why Heat Pump Sizing Matters
Michael Crook, an installer from Heat Pump Installers UK, emphasised the importance of using these heat loss calculations to size heat pumps correctly. A common mistake is to oversize the heat pump to ensure the home stays warm. However, oversizing can result in inefficiencies and increased costs. Conversely, an undersized heat pump may struggle to maintain the desired indoor temperature on particularly cold days.
Michael also highlighted the challenge that comes with interpreting the capacity of heat pumps. The number on the heat pump’s label isn’t always the full story. As Graham pointed out, heat pumps can deliver different outputs depending on outside temperatures. A unit rated for 10 kW might only deliver 8 kW on a particularly cold day, which could lead to an undersized system if not properly accounted for.
Case Study: James’ Experience
James Parker, a member of our Renewable Heating Hub community, shared his real-world experience. Despite having paid for two heat loss surveys, both reports ignored key fabric upgrades he had made to his property. His surveys calculated a heat loss of 16 kW, which he later discovered should have been closer to 8 kW. This significant overestimation would have led to an unnecessarily large heat pump, higher running costs and potentially even the need for planning permission.
James’ story is a perfect example of why homeowners should double-check their heat loss calculations and challenge any inaccuracies. One way to do this is by asking for multiple quotes and ensuring installers factor in all improvements made to the property, such as added insulation or new windows.
Expert Advice for Homeowners
For homeowners, the key takeaway is to ensure that the heat loss calculation is accurate and that the heat pump is correctly sized based on this information. While some installers charge for detailed surveys, it’s a worthwhile investment in the long-term efficiency of your heating system.
Thank You to Our Sponsor
We’d like to extend our thanks to One Heat Loss for sponsoring this episode. One Heat Loss specialises in providing detailed, independent heat loss calculations for both homeowners and installers. Their impartial advice ensures heating systems are correctly sized and operate efficiently. Whether you need a second opinion on a heat loss survey or guidance on radiator and heat pump sizing, One Heat Loss offers flexible, expert solutions. For more information or to take advantage of their special offer for Renewable Heating Hub listeners, email your plans to info@oneheatloss.co.uk.
Home automation and the cloud; is there a better way?
What’s the best heat pump brand in the UK right now?
2 Comments
Thomas Riley
great prize
[…] such as heat pumps, heat loss is a critical factor that should never be overlooked. In a recent podcast episode Homeowners’ Q&A by Renewable Heating Hub – […]
