Sunamp Thermino Heat Battery
We opted for this Sunamp design as we just don’t have a suitable space anywhere in the house for a conventional DHW tank of the capacity required by the MCS, and I didn’t much fancy enlarging the loft hatch to fit a tank up there.
This siting would have required all the attendant strengthening work to fit a 250-litre tank that bristles with pipes, sensors and pumps. Thus, we avoided any possible source of noisy motors too! (Not to mention the additional wiring and pipework!) We would also have lost the low-level heat source that we regard as always useful heat in the airing cupboard (which is too small to accommodate a conventional 250-litre tank).
There is an LED panel on the front face of the Sunamp Thermino, providing indications of Power Connected and status of charge. Though very granular, three LEDs indicate full charge, half charge and low charge level. In addition, one LED indicates when the unit is charging.
Our unit sits sideways in the airing cupboard, as the depth of the unit dictated this orientation; the LED display is still viewable sideways without much of a problem, though there is very little need to consult it anyway. We are able to monitor consumption via the Myenergi app, where we set our preferences for charging.
The unit is VERY HEAVY, and the installers had three attempts with progressively more powerful methods of stair-climbing sack trucks to take the unit upstairs! The unit sits over two floor joists, and the load is spread by sitting on two 25mm thick boards as a sandwich.
During installation, the top cover is removed, and several layers of vacuum foam insulation are lifted out to access the pipework. The connections to the water supply and hot water feed are made with solderless swivelling joints that may be set to exit to pipes on the left, rear or right of the cabinet.
On the day the old water tank was removed, we were only without hot water for a few hours while the existing pipework was modified, the Thermino placed, and the pipes and wiring connected. Within 30 minutes of powering up via the Eddi, we had hot water on tap again – there are comparisons with a combi gas boiler in that sense.
Now as to the working – well… it just works. Powered via a Myenergi Eddi, that once set, will provide either PV or grid power as required. The unit is ventless and silent in operation, has no pumps, and heats the cold water as it progresses through a few metres of internal pipework that is surrounded by the Phase Change Material storing the heat. It then exits through the hot outlet and goes straight to a tempering valve for safety.
Expected life? As yet unknown, but tested to the equivalent of 20 years and still good, I’m told. I did hear of a failed unit once, and Sunamp replaced the whole system for the owner without a quibble.
I considered several models but opted for the ePV version, as the one that runs from a heat pump input requires a high-temperature heat pump plus electrical ‘top-up’ to ensure the required minimum temperature. There is also a version for thermal solar panel heating in the range. Please see the website link, which provides dimensions, weights, capacities, and the various models available to match different energy sources.
The Sunamp model we have loses less than 0.75 kW of heat in 24 hours, and what is lost is made good use of as it sits on the floor in the airing cupboard. The total heat loss in the whole heating system is less than when we had a gas boiler and 99-litre DHW tank in there, so the airing cupboard is just a little cooler than it used to be. Our system has a 210-litre capacity, so it isn’t imperative that it is charged every day just for the two of us – we could (and have) left it for 2-3 days and still had sufficient hot water as and when it’s required. Currently, our daily charge consumes ~3kWh, but will rise to about ~4-4.5 kWh in mid-winter. I think a full charge for our unit capacity is ~11.5 kWh.
Would I recommend the system? Absolutely, every time!
16 Comments
Johnmo
Several different views on Buildhub. @TerryE on Buildhub has just replaced 2 units with an unvented cylinder due to reliability issues.
Do your due diligence, they are very expensive, do nothing that an unvented cylinder doesn’t do.
Arundalep
We also chose a Sunamp due to space restrictions and have been very happy.
If you are a COP chaser then you probably won’t be happy due to the higher charge temperatures required to run a heat pump to charge the Sunamp (mine costs about 3p/kWh of hot water, happy with that). A suitable mains hot water cylinder would have been a nightmare for us (either loft mounted or loose a wardrobe).
@Arundalep welcome to the forums, and thanks for sharing your Sunamp experience.
For context, what does that roughly equate to for daily hot water consumption costs?
Arundalep
@Mars daily hot water costs about 40-45p / day. Average daily heat pump electricity consumption for hot water is 5.8kWh (taken from months with no heating). All of that consumption is using cheap rate electricity at 7p/kWh.
Giselle
If the phase change material develops a leak, does it end up in your domestic hot water?
PaulD
Hello All. Just found this forum and registered myself so here goes with my first post….
Can anyone please tell me what they paid (supply & fit) for their Sunamp heat battery? We curently have PVs on our outbuilding and are going to get a battery. We also intend to replace our gas combi boiler with an air source heat pump this year. We don’t have a hot water cylinder and I don’t know where we’d fit one. The Sunamp heat battery looks like a great alternative but before I contact one of their installers it would be nice to know what sort of money we’re talking about!
Many thanks in advance
Paul
PaulD
Thank you, Toodles. That’s very helpful.
Best wishes
Paul
The cost of the Sunamp Thermino ePV210 was £2,873.40
Wow, I knew they were pricey, but didn’t expect it to be almost 3k. Interesting.
asoksevil
I am thinking on installing this as well given space constraints.
Is it actually better to let the solar PV or the battery charge the sunamp
for hot water and use the ASHP entirely for heating? (Underfloor heating). Or would you go about this?
Depends on your electricity tariff and in particular your export tariff, also on time of year.
So for example my import tariff is 7p midnight-7am, 25p the rest of the time.  My export tariff is 16.5p.  So for me it makes sense to do DHW heating at night on the heat pump (and as a result export more), even though the heat pump will be less efficient than if I did it during the day.
If I didn’t have an export tariff then self-consuming as much solar as possible makes sense.  In this case there is an argument for a solar diverter (which I guess but dont know you can use with a sunamp) precisely to match the load to the available excess, or alternatively play the numbers game by scheduling the ASHP to do the DHW/sunamp heating from noon-2pm or thereabouts, reckoning that, on average, this will work out better.
In winter all of your solar will be consumed by the ASHP anyway most days, so best just to use the ASHP to heat the sunamp at a COP of 2, rather than the resistance electric element at a COP of 1, whatever your export tarrif.
The other calculation that might be worth doing is payback time for the additional cost of the sunamp with the facility to be heated by the ASHP, relative to an electric-only one.  Its probably a long time!  An electric-only sunamp would invalidate the BUS grant, however, so may not be an option.
We have the Sunamp Thermino ePV210 version which is heated from solar or grid energy; by the way, we did get the £5000 BUS grant, perhaps that is because the solar energy may be used to heat the water. Our ASHP does not heat the DHW
Interesting, I must reread the BUS rules for this combo….
….Ok the relevant rules are below. I can’t see how a heat pump with electric only sunamp meets condition (c) unless previously your dhw was heated on immersion only, which may be the case, but then it falls foul of (b).
Of course that’s all a bit academic!
 A heat pump meets the suitability criteria in relation to the eligible property, or a property to which regulation 14(1)(b) applies, for which it is installed where—
(a)it provides heating—
(i)solely to that property, or to both that property and any related property, and
(ii)for the purpose of both space heating and hot water heating, using liquid as a medium for delivering that heat,
(b)it is capable of meeting the full space heating and hot water heating demands of that property, and
(c)it replaces the heat generating components of the original heating system installed in that property (where applicable), other than any—
(i)supplementary electric heater, including any immersion heater,
(ii)circulation pump, or
(iii)solar thermal collector.
