How to DIY Fix a Heat Pump Flow Error?
Fixing Heat Pump Flow Errors
If your heat pump is suffering from persistent flow errors, this quick video provides a potentially easy DIY fix. Learn to identify and clean a blocked central heating water filter or Y strainer, which could be causing the issue. This is a recurring issue faced by homeowners on the forums, and in most cases it has been caused by a gunked up filter. Should the errors continue despite a thorough cleaning, it may be necessary to consult with your installer for further assistance.
Biomass, PV-T, Pellet Boilers or Heat Pump?
Is Your Heat Pump the Right Size Based on Your Heat Loss Calculation?
1 Comment
Michael Floyd
Low loss header why is the flow in and the return almost the same temperature as the flow to the radiators takes ages to heat up the return at the header heats up quicker.How do I balance this heat pump has high medium low settihgs as has the other pump any suggestions please.
