Is a heat pump sized in the same way as a fossil fuel boiler?
Cold House
There is a lot of confusion about heat pump sizing, especially in relation to existing gas or oil boilers. Graham Hendra explains whether heat pumps should be sized on the same way as fossil fuel boilers.
How Do Compressors and Frequency Affect Heat Pump Efficiency?
Brendon Uys
Is Your Heat Pump the Right Size Based on Your Heat Loss Calculation?
