Humming sound on new install.
Had a new Vaillant 7kw installed with new 28mm runs for primaries and flow and return. I’ve got a variable pitch humming sound that resonates through the house depending on how hard the heat pump is running. Admittedly this is just a test run I’m doing tonight but it worries me as i can hear it above the TV.
one thing my plumber who ran the 28mm’s did do was clip them against the wooden ceiling trusses. Could this be transferring noise into the house? With the old boiler setup and pump you could only really hear the pump where the pipes were exposed in the kitchen just below the pump in the cupboard above.
- 33 Online
Had a new Vaillant 7kw installed with new 28mm runs for...
By AdamK , 2 minutes ago
Possibly not the answer you might want, but if it were ...
By Temperature_Gradient , 4 minutes ago
By JamesPa , 2 hours ago
By Cleardene-ashp , 4 hours ago
By JulianC , 4 hours ago
By NJT , 6 hours ago
By Toodles , 6 hours ago
By Transparent , 6 hours ago
By Old_Scientist , 12 hours ago
By cathodeRay , 1 day ago
By ASHP-BOBBA , 1 day ago
By Lucia , 2 days ago
By ASHP-BOBBA , 2 days ago
By Tim441 , 2 days ago
By HCas , 2 days ago
By jamespetts , 2 days ago
