The Reality Behind a Failed Heat Pump Installation – and an IWA Insurance Rejection
We are an unremarkable couple in our 60s, living in a 1900 three-bedroom terraced house in South Manchester. In 2022, after receiving a small inheritance from our parents, we decided to take the plunge and invest in a new central heating system to replace our temperamental 30-year-old boiler.
After much research and deliberation, we decided to ‘do the right thing’ environmentally and invest in an air source heat pump. The environmental credentials were appealing (roughly four units of electricity generated for every unit consumed), as was the government’s support in the form of a BUS (Boiler Upgrade Scheme) grant which, at the time, was £5,000. We would also be able to get rid of the gas supply completely and save additional costs by not having to pay the monthly gas standing charge.
We didn’t know of anyone else who had installed an ASHP, so we were in unfamiliar territory and learning one step at a time. There were so many acronyms to come to terms with (EPC, MCS, NAPIT, BTU values, BUS grants, CWI…).
It was complicated and confusing, and we felt quite overwhelmed and lacking in confidence. It would have been so helpful to have had some independent, easy-to-understand overview of the process… a metaphorical ‘holding of our hand’ through it all. We didn’t know where to look. Advice seemed patchy and far too technical for us newbies to understand. We were both working full time, still supporting adult children, having building work done and had very little spare time to deep dive into the world of heat pumps. But we took it one step at a time, researched as much as we could, and kept asking lots of questions.
The first step was to find an ASHP installer. We knew from online research that it was important for the installer to be MCS registered. We contacted ten installers based in and around Manchester, all of whom were MCS registered. After asking some basic questions as part of the initial enquiry, we shortlisted these down to five. We invited them to come and look at our property with a view to providing advice, a quote and a recommendation for which model of ASHP they thought would best suit our home. From the quotations received, we chose RA Renewable Solutions. We discussed the pros and cons of different ASHP models and settled on the 11kW Vaillant aroTherm. They were also happy to install underfloor heating in the kitchen as part of the installation, which some installers were not willing to do.
To qualify for a BUS grant, we had to commission an EPC (Energy Performance Certificate) assessment and implement any recommendations, particularly in terms of insulation. The assessment recommended cavity wall insulation (CWI). However, because of the age of the house (1900), our walls only had finger cavities which were too narrow to accommodate regular insulation. This all had to be proved and documented.
Firstly, we had to commission a chartered surveyor to inspect our walls. He asked us to commission a CWI installer to inspect the walls with a borescope and send him the photos, which we did. Three reports later (and a rapidly depleting budget), we were finally able to complete a ‘Cavity Wall Insulation Exemption Form’. Instead of CWI, we committed to removing the existing plaster on the two external walls (front and back) and replacing it with new thermally insulated plasterboard, which would have the same effect. With this in place, we were finally eligible for the Government’s BUS grant.
The next step was to buy radiators so that the builders knew where to put the pipe centres when installing the plumbing first fix. The ASHP installer commissioned an assessment of the BTU values required for each room. This came to us in the form of a rather blurry, difficult-to-read WhatsApp screenshot, rather than the detailed report we were expecting. However, we took it along to a radiator retailer and asked them to interpret the values for us so that we could properly size the radiators. Radiators were ordered and pipe centres marked on the plans.
An ASHP system needs a large water tank. We had originally specified a Vaillant uniTower hot water cylinder. However, after discussions on site, the installer suggested we change this to a horizontal hot water cylinder, which would fit under the eaves in the loft and be a better use of space. We emailed the installer to ask if the new cylinder (Joule) was compatible with a Vaillant ASHP system and whether it had a warranty comparable to the Vaillant uniTower. We received a reply confirming that the Joule cylinder was compatible with our ASHP system and had a 25-year guarantee.
There were some delays to the building work. Some were the fault of the builder (subcontracted suppliers were not organised in a timely manner). Others were caused by unforeseen structural issues. After removing the old plaster to replace it with thermally insulated plasterboard, it was discovered that the front elevation of the house was structurally unsound and had to be rebuilt. We provided the ASHP installers with the builders’ contact details and vice versa so they could coordinate timescales. We asked the installers whether the delays would affect the BUS grant (given the three-month expiry period) and were assured that it would not.
Once the installation was completed and we had paid in full, we received an MCS certificate and an IWA Insurance Certificate by email. The installers received a £7,500 BUS grant as part of the final payment. We did not receive a formal ‘handover pack’ explaining how to use and maintain the system, which we later learned should have been provided. Instead, the installer verbally explained the controls. There was no independent verification that the system met required standards, and as homeowners, we were not qualified to assess whether everything had been done correctly.
Four months after completion, we experienced a serious water leak from the area of the water cylinder. The leak was severe; water came through the ceiling and ran down the walls below. We tried contacting the installers via WhatsApp and email but received no response.
Following guidance from Ofgem and MCS, we contacted the MCS helpdesk. They advised us to write to the installer by letter and allow 14 days for a response. NAPIT provided the same advice. We were also warned that using another installer could invalidate warranties and insurance.
This advice was impractical. We had to turn off the water to prevent further damage and could not realistically live without heating or hot water for two weeks. We eventually found another engineer who agreed to help as an emergency. He fixed the immediate issue (a failed automatic air vent) and identified multiple problems with the installation. We commissioned a report detailing faults, non-conformities and recommendations.
The scale of the issues was a shock. We followed the formal complaints process, but the installer denied any problems. One key issue was the hot water cylinder, which was not a high-gain model suitable for a heat pump system. The installer claimed it was. We contacted the manufacturer directly, who confirmed it was not suitable.
We then commissioned a second independent report from a Vaillant engineer, which corroborated the findings and identified further issues, including electrical faults.
Shortly afterwards, we discovered the installer had ceased trading. We submitted a claim to the insurance provider (IWA), which was rejected because we had not contacted them within 30 days of the issue arising, despite following official guidance at the time.
After escalating to the Financial Ombudsman, we initially won our case, but the insurer rejected the claim again under a different clause. Ultimately, only two minor issues were accepted for coverage. The majority were deemed ‘upgrades’ rather than defects.
After months of further reports, evidence gathering and correspondence, we were left with an expensive, poorly installed system and no meaningful recourse.
We didn’t know where to turn until another engineer pointed us towards Mars and Renewable Heating Hub. For the first time, we felt we had found someone willing to listen and help. It became clear that our experience was not unique. There are systemic issues: poor oversight, weak enforcement and inadequate consumer protection.
We have now contacted our MP, Jeff Smith MP, and will be meeting him in April 2026 to discuss our case.
26 Comments
Thanks for the post @Ian and I find stories like yours deeply frustrating.
What stands out most isn’t just the installation issues (which are serious enough), but the complete breakdown in consumer protection once things started to go wrong. The fact that you followed the prescribed process (MCS, NAPIT, Ofgem guidance) and still ended up effectively locked out of any meaningful support is a real concern.
That said, I’d be really keen to understand a bit more detail on the insurance side, if you’re happy to share.
Specifically, do you have clarity on exactly which clauses IWA relied on when rejecting your claim, both the initial 30-day notification issue and the later “upgrades vs defects" argument? And did they provide any detailed justification as to why something like an incompatible cylinder wouldn’t be considered a fundamental installation defect?
Also, when they re-rejected the claim after the Financial Ombudsman ruling, did they explicitly reference different policy wording, or was it more of a reinterpretation of the same terms?
I’m asking because I’d like to dig into this further and because I’ve heard some really dodgy things about IWA. There are some pretty serious implications here around how these policies actually function in practice (particularly when installers cease trading) and whether homeowners are being given a false sense of protection. Just another policy blunder IMO with no real backbone.
Once I have the reasoning, which I would like to document publicly, I will take this up with the chiefs at IWA because it’s simply unacceptable.
Firstly can I say how sorry I am to hear your story.  Water leaking isn’t bad design or anything to do with ASHPs, its just shoddy workmanship which (sadly) can happen with any plumbing work, which is neither a comfort nor an excuse.  Poor oversight and weak enforcement/consumer protection is, sadly, true of the construction industry generally, its not confined to heat pumps.
Often in these circumstances self help (or an element of self help) is the best help.  If you would like to post the report on the problems (redacted if you choose) and summarise those that actually remain, we may able to give some simple pointers/advice.  It can almost certainly be broken down into several individually fairly easy changes, which it may well be possible to advise on.  The basic kit you have, a Vaillant 10/12kW heat pump, is a very good piece of kit indeed and, connected directly to a heating system, should be returning about 4* the energy you put into it and keeping the house much more comfortable than you can ever achieve with a conventional boiler set up.  As you have swapped from a 30 year old boiler you should be saving money and be more comfortable, as well as doing ‘the right thing’.
Your alternative is a long complaints process.  If you paid anything on Credit Card then section 75 protection may well apply and at least one person here has been successful in using that.
If you would like to explore ‘self help’ or even just receive a commentary on the severity of the problems that remain, please do post further.
@Ian, thank you for the detailed update and for not letting this drop after two long years. Reading through the contradictory rejections again, the ‘upgrades not faults’ line, the buried small print and the mountain of effort you’ve put into independent reports (Vaillant + specialist + manufacturer confirmation on the incompatible cylinder), it’s exhausting just to follow. You’ve done everything right, followed the advice and still hit a brick wall. That’s not bad luck … it’s a symptom of how broken the safeguards really are, and the forums and my inbox are filled with similar cases.
I’m taking a straight stance here… successes in these complaints are slim. The system is hideously broken. Your “no win” situation with the 30-day clause, the Ombudsman nudge and then the pivot to other exclusions is classic. Many people simply give up because of the time, stress and extra cost involved, and I suspect that’s exactly what some in the chain are banking on. It’s a ridiculous system.
We’ve helped hundreds of homeowners tackle similar issues with different installers, warranties and faults over the years, and the honest truth is that very few of the overseeing organisations have been of any real assistance. The responses are often slow, defensive or pass-the-buck, which only adds to the frustration.
The IWA model (which I’ve not really dealt with much) feels particularly flawed. Installers hand over a policy customers never shopped for, with the reassuring “user-friendly, no hidden small print” claim on the old homepage (now removed). MCS itself stopped allowing IWA policies to be bought through the MID back in December 2024, and the whole Insurance Backed Guarantee (IBG) approach is being phased out during the 2026 redevelopment of the MCS scheme. The new setup brings in mandatory MCS-approved financial protection products with a minimum 6-year workmanship cover, simpler claims routes, stronger consumer focus and even direct outreach from MCS to households after installation. I’ll caveat that by saying it looks lovely on paper, but MCS do not have a great track in implementing anything of substance.
On the wider picture, we’re funnelling public money into this transition at a time when energy security and genuine Net Zero progress is more vital than ever. Underperforming or non-compliant systems don’t cut emissions efficiently, they drive up running costs and they undermine confidence in clean heat exactly when we need it most. Your fight isn’t just about getting your own installation sorted properly at no extra cost to you… it’s about forcing accountability so others don’t have to go through the same ordeal.
I will personally bring this thread to the attention of the organisations responsible for oversight (MCS, DESNZ/BUS team, Ofgem) and see what they say.
Out of interest, who was your installer’s consumer code… was it HIES or RECC? That can open up another route for escalation and arbitration, even if the main warranty battle is with IWA.
Tbh I’m very surprised that you suggest we pursue a ‘self help’ option.
Noted.
Im being pragmatic, recognising the reality that (a) you presumably want working heating and (b) the complaints path is long and tortuous (and not always successful) and you appear to have hit a bit of a brick wall (c) you appear to have no section 75 protection which can be an option of last resort and (d) the insurer is being uncooperative.
Im not defending the position, just saying it as it is.  Unfortunately there are scum out there who will rip people off and, whilst we have much better consumer protection than many countries, it is still not bombproof.
Given that the ombudsman suggested that IWA should reconsider the claim and they did but still rejected it, is it open to you to go back to the ombudsman?  Presumably you could take IWA to court if you believe that they are in breach of contract?
I completely understand your entirely reasonable desire to get it fixed at no cost to yourself, and wish you the best of luck in doing so.  Like you I have recently been the victim of poor workmanship by the construction industry (which, lets face it, is notorious for poor workmanship) and know just how frustrating it is.
I have just dug out my own guarantee (which is by IWA) and read the conditions, which I reproduce below.
Its pretty limited.  Its cover applies only if the supplier has ceased to trade.  Faults must be notified within 30 days otherwise they are not covered.  Faults which occurred before the supplier ceased to trade are not covered, whether or not they were notified.
The effect of this in practice is to exclude pretty much any poor workmanship (because the fault occurred before the supplier ceased to trade).  Essentially, as I read it, it would cover only failed parts occurring after cessation of trading, which would probably anyway be covered by manufacturers warranty.  So it’s only obvious value is cover for fitting the parts.  Also crucially it won’t cover anything if the fault occurs before a supplier ceases to trade, they fillibuster, and then cease.  This is another hole in something that is already a collander masquerading as a saucepan.
I would personally rate this insurance as near worthless.
I must admit the very strict limits of cover, some of which I can understand but some of which I can’t, have come as a surprise to me.  Its not positioned this way by the industry imho.  The old saying ‘insurers never take risks’ certainly applies here!
Nevertheless, shocking though it may seem, I can see no way that this can be reinterpreted to cover poor workmanship occurring before the supplier ceased to trade.  @Ian it might be worth your while reviewing your list in case there are further elements you could dispute.  I’m presuming the installer went into administration in which case you may have a claim on that, but you are not a preferential creditor so in practice the probability of getting anything is small.
I know this is not what you want to hear but it’s probsbly better to be realistic about the prospects, as @Mars says above.
I’m sorry to have to say this, it shouldn’t be this way!
I would personally rate this insurance as worthless, in the sense that I would not pay even a penny for it.
I know you have a pretty good eye for detail, @JamesPa, but even then I wonder if you spotted at the time of install just how toothless the guarantee was.
It highlights to me something I’ve seen plenty of times before – and been guilty of myself plenty of times too – which is that no matter how rigorously you try to research something new before committing to it there will still be a lot of important things you don’t know you don’t know. I was just plain lucky when we had our install that, each time I learned something new on this forum, I went back to my system to check and found the installers had followed best practice. I was far less prepared than @Ian and it’s pure good fortune we managed to pick an honest and competent installer.
IMHO, industry bodies (like MCS) should be protecting the customer from the consequences of ignorance in things only a professional should be expected to know, but as we’ve seen so many times before that simply doesn’t happen. I know I’m not saying anything new, but it’s such a significant failing within the industry that it bears repeating again and again. As things stand, it seems customers are expected to be heating system experts to spot design flaws, project managers to keep installers on track, professional negotiators to avoid unnecessary hidden costs, contract solicitors to ensure the safety nets are actually fit for purpose and clairvoyants since even the best installers may well encounter the unexpected.
Simply put, no I didn’t.
That said I didn’t place much mental value on the insurance element.  I watched the installer carefully to ensure that they did what they contracted to do, and made sure I had the manufacturer guarantees.  I was confident in the design so this element wasn’t a consideration.
Agreed, @Ian.
And, to do the point justice, that systemic failure extends way beyond the insurance. It often seems as if all the involved parties are united AGAINST the consumer. Every instance of a happy customer I’ve ever heard of has been the result of the chosen installer doing what they’re supposed to. I have not yet heard of an instance of a customer successfully overcoming a botched install except either by their own efforts or with the help of communities like this forum.
Thanks for the contributions on the issue of IWA Insurance everyone. I think we are all agreed that this insurance company is not fit for purpose (personally I feel that we have been scammed by IWA).
We just received an initial guestimate from EDF for a BUS heatpump install. It included an IWA leaflet…
This is an extract of what it says for deposit protection:
At the time of paying a deposit you should be issued with a Deposit Protection certificate from IWA. This document will protect your deposit, prior to the commencement of the contract for up to 25% of the contract value, subject to the terms and conditions on the certificate
Also, for the IWA Guarantee Insurance:
Your contract will be insured for a period of up to ten years and is underwritten by FCA authorised Insurers,subject to the terms and conditions on the Certificate.
Then, under Warning:
In the event of an insurance claim refer to the Certificate for the procedure. If you have not been issued with a policy you do not have insurance cover.
And EDF did not include the terms and conditions for neither the IWA Deposit protection nor the Guarantee when they send the IWA leaflet…
Interesting, my protection was only for 2 years and, as I post above, essentially worthless.
I didn’t even get the terms of the insurance when I contracted, I only got them after completion.  Given the wording of the insurance itself (if yours is similar to mine) this is arguably mis-selling by the installer (who has probably never read the terms himself).
… perhaps the main reason why, when people come here with tales of woe, I fairly soon suggest self-help with the assistance of this forum.  Its the only proven way to get botched instals fixed once the installer has vanished, and certainly the only way likely to yield results within a heating season.
There is one exception I know of, @DREI, who had the good sense/good fortune to pay in part on credit card, has succeeded (after a long battle) in getting money back under section 75 of the Consumer Credit act.  Thats no credit to the industry though.
@JamesPa In a different but somewhat similar situation, I had bought kW’s in Ripple Energy’s Project 4 Wind Farm. Due to poor management,  and possibly worse, this project collapsed but as I had paid by credit card, I was able to claim full reimbursement from my bank under a section 75 claim. Regards, Toodles.
ASHP-BOBBA
Also, for the IWA Guarantee Insurance: Your contract will be insured for a period of up to ten years and is underwritten by FCA authorised Insurers, And EDF did not include the terms and conditions for neither the IWA Deposit protection nor the Guarantee when they send the IWA leaflet…
Interesting, my protection was only for 2 years and, as I post above, essentially worthless. I didn’t even get the terms of the insurance when I contracted, I only got them after completion.  Given the wording of the insurance itself (if yours is similar to mine) this is arguably mis-selling by the installer (who has probably never read the terms himself).
We send the insurance as soon as someone pays the deposit, if they dont have deposit insurance as they didnt pay they get the work insurance after the installation.
 … perhaps the main reason why, when people come here with tales of woe, I fairly soon suggest self-help with the assistance of this forum.  Its the only proven way to get botched instals fixed once the installer has vanished, and certainly the only way likely to yield results within a heating season. There is one exception I know of, @DREI, who had the good sense/good fortune to pay in part on credit card, has succeeded (after a long battle) in getting money back under section 75 of the Consumer Credit act.  Thats no credit to the industry though.
  I would advise everyone to pay for the booking deposit on a credit card, we actively encourage this, if you pay over £100 on Visa for example the whole job is insured by them or they will at least help you with compensation.
However, my point remains that this is a systemic issue. The person that chooses the IBG is the installer who will not be affected if they turn out to be rogues. The person that stands t
Afo lose out financially by this inadequate insurance cover is the customer who has no say in the choice of the insurer. This disconnect enables insurance companies to act with impunity as there’s no consequences for them in terms of business loss due to poor reviews.
Completely agreed.  Unfortunately this sort of situation is not restricted to heat pumps.  As I say above, our consumer protection is better than some countries, but nothing like bombproof.  Caveat emptor!
I am going to say again that, as voters, we must bear some responsibility.  For 53 years out of 80 since the second workd war the government we have voted for has been overtly ideologically disposed towards low/no regulation.  MCS, the industry watchdog, is a product of that.  It was originally established by Government, but in 2018 it was spun off as a private organisation funded by the industry.  He who pays the piper calls the tune.  That is no consolation for affected individuals, but we may all need to adjust our expectations given our collective voting habits, whilst of course continuing to campaign for better.
@Ian. If there is any way we can assist with pointers to things you could do (or have done fairly cheaply) to improve your system I, and I’m sure others, am/are happy to try.
The installer’s consumer code was RECC.
RECC are abysmal. I was hoping it’d be HIES.
Temperature_Gradient
I’m not convinced that quite captures the problem because we do have a lot of regulation, we’ve got volumes of Building Regulations with reams of requirements and legal obligations to fulfil when doing pretty much anything on our own homes, which now restricts what work the average person can do legally. We’ve got numerous Competent Person Schemes with all of their training, registration and on-going membership requirements, more industry bodies and schemes than you can shake a stick at.
It’s not that Britain has too little regulation, in some areas I’d argue we have too much, but rather it’s that a lot of the regulation is poorly defined and inadequately enforced. Britain also seems to have a serious problem with regulation creep, where because regulation is itself now a profit-making industry, all of those bodies involved with regulation are continually pushing to expand their power, expand their responsibilities, introduce new requirements to then require further training, further accreditation all with more fees and incomes to those bodies and training providers. It isn’t clear whether this is actually raising standards and beneficial to the end consumer.
Britain has far too much regulation, with so much that it is unenforceable, we need less regulation, cut it back to the really important things but with much more rigorous enforcement processes for those critical regulations.
@Temperature_Gradient
The problem with this argument is, what is critical/important?  Obviously people will disagree.  So if you start of with the ideological principle of little regulation, as you propose, you will almost certainly not get the regulation that is critical to you.  Whatever you may think someone else wont want it/wont deem it critical and, if the principle is little regulation the arguments against hold more sway than arguments for.
However, as I say, low regulation has been the argument for 53 out of 80 years since the second world war, and what we have is the result.  I’m not saying that’s wrong or right, just how it is.  With this approach don’t expect bombproof consumer protection or even building regulations that stop 72 people dying in a tower block fire.
Also I disagree that regulation is unenforceable, it is enforceable through the courts.  The problem with this is that going through the courts is a slow process which most individuals wont be willing to do.  Of course one could set up some state backed ‘regulation police’ as an alternative individuals going through the courts, but thats effectively more regulation which you oppose.
Your point about regulation being industry led is something that I wouldn’t argue with.  However this is also a consequence of our choice to elect governments committed to low taxes and a reduced civil service.  The consequence is a civil service that is reliant in part on industry for technical advice, and less capable of challenging the (almost inevitably partisan) advice when its given by the industry.  Thus there will inevitably be an element of regulation that ‘suits’ industry, even in a ‘low’ regulation regime.   As I say above MCS is a great example of this, set up, arguably for good reason, by Government but then privatised and funded by the industry.  What outcome do you expect?
Again I’m not saying that any of this is wrong or right, just that we have to own the real-world consequences of our decisions, rather than blaming everything on others, remembering always that human beings will, for the most part, act in their own self interest.
Of course it is easy just to blame everything we dislike on ‘others’ and deny any personal responsibility.  Elections are won that way so its also very powerful.
@Temperature_Gradient, @JamesPa, I think there is a significant trap that is easily overlooked. “Unenforced” and “unenforceable” are linked but not the same thing. Eventually, we have a lot of regulation that is perfectly enforceable but is to all intents and purposes not enforced. That has the effect of removing that regulation entirely since, if it’s ignored, it might as well not exist.
I don’t have all the solutions but the answer cannot be more regulation that is similarly ignored. A good start, IMHO, would be improving enforcement of existing regulations and pressuring MCS etc. to do their job seems an obvious first step. However, that requires political cohones and I see precious little of that in any of the parties on offer.
Before worrying about cohones you need to have the political desire.  A low regulation environment also comes with a presumption against special government-sponsored systems to enforce regulation, because these are themselves more regulation and of course raise taxes.  We have a system, the courts, it works if we choose to use it.   That is entirely consistent with a low regulation mindset and I think those who espouse that mindset would argue that nothing else is needed
I would argue that the current government may well have the political desire, but as you say doesn’t (by and large) currently have the cohones and, like you, probably doesn’t currently have a solution even if it did.  I would also argue that, in a political environment where the electorate predominately vote for low regulation, that is something we cant reasonably expect in a first term, its more a second or even third term thing.
So IMHO we have to make a choice.  Low regulation and enforcement through the courts only (= low enforcement) or higher regulation and maybe, if we give a government sufficient time and make our desires clear, a more stringent enforcement regime (albeit at the cost of higher taxes).
Yet again we need, IMHO, to own the consequences of our decisions.
The current Government has clearly indicated it intends to monitor MCS more closely from a consumer protection standpoint than was the case under previous governments.  It remains to be seen whether this will have any effect in the remaining approx three years of the current term.  I would argue that this is barely long enough for any major effect to be visible, so our expectations should be fairly low however hard the government may try.  If, at the next general election, we choose a government which has a similar political desire, then I think we can reasonably expect greater change.  If we again opt for low regulation, then not so much.
That said it is unclear to me what the job of MCS actually is.  Since 2018 it became a private body sponsored by the industry and as such is primarily answerable to industry not to the electorate, the Government or consumers.  It does have a privileged position, which is the leverage the Government has over it.  That leverage only applies (since May 2025 in England) when the BUS grant (or other grant that requires MCS) is in play, not to any case where there is no such grant.  That’s significant but not absolute.
The fact that MCS is a private body sponsored by the industry is, you surely cannot deny, a more or less direct consequence of our collective preference, expressed through the ballot box, for low regulation and low taxes.
Once again Im not advocating any particular position, but I do feel very strongly that we need to accept that we make choices when we cast our votes, and own the consequence of those choices even when that works against us.
Risk based – does a particular activity/product pose a significant risk to people, in terms of harm, requiring regulation to bring that risk down to a tolerable level.
There’s a difference between the quantity of regulation and the quality of that regulation. I disagree that Britain is a ‘low regulation’ country, in terms of the quantity of regulation, Britain has masses of regulation. I would argue the problems lies not with the quantity and the broad scope of activities covered, but rather the quality of that regulation and the enforcement of it is where the problem is.
We need less quantity, but better quality and better enforced regulation. That has been the issue with building fires, we have lots of regulations covering this, and testing houses and processes but the quality of that regulation, its effectiveness and enforcement is where the problem lies.
If the mechanism for enforcement is highly slow, inefficient or unworkable then the outcome is the same as if it’s unenforceable, because effectively it is.
It wouldn’t be a state ‘regulation police’ rather it would be likely be a reversion back to more local building inspection and a much tighter, more crisply defined regulations on what building products can be used, product testing, minimum acceptable designs etc.
I agree there’s a real problem about the UK Government and civil service and it’s lack of technical expertise, which affects a vast number of policy areas.
Again though it’s the difference between quantity of regulation and quality, we do have significant quantity of regulation around these areas. For a heat pump, it needs to meet and be signed off against the Building Regs to be legal, which in practice (for almost all installs) means it needs to be installed by a installation company registered in a Competent Person Scheme, in theory the company and its staff need to have been adequately trained, follow the standards, they’re tested, the company is accredited, they’re part of consumer redress schemes etc etc.
There’s a very large amount of regulation here, no lack of quantity we don’t need more, any issues lie in the quality and the enforcement and the regulation we’ve already got.
Posted by: @JamesPa
So does that excludes consumer protection (which is what triggered this discussion) other than safety matters (which weren’t involved in the trigger)?
If it does include consumer protection what is ‘significant’.  To someone with little money every £ is significant.  To Jeff Bezos £1M is small change?   This particular case is £10-20K, nothing to Jeff Bezos, an annoyance but ultimately bearable to many, life changing to many others.  Where do you draw the line and more importantly how do you get agreement on that and the tax/cost implications?
As I say people will disagree and if the disposition is to low regulation then you wont get the regulation you want, because others will have different priorities.
I didn’t originally say we were a low regulation country, what I said originally was that for 53 out of 80 years we have elected governments that are ideologically disposed towards low government intervention/regulation.  That disposition could manifest itself in ineffective regulation (ie regulation in name only – there for appearance but deliberately near useless in practice) just as it could manifest itself in low regulation.  I would argue it has in fact done a mix of both and that MCS is (possibly by design) actually a shining example of a regulator that may not be useless, but clearly doesn’t fulfill people’s expectations.
The first point is undeniably true for those with little money.  Unless the issue is life threatening its not true for people who can afford to wait for the courts.  For them its just a manageable cash flow matter because they will eventually recover by suing the culprit.  Again it depends on your perspective.  For those with the money to sue, regulation (other than for life threatening things) is largely unnecessary.  This itself has consequences which I will touch on towards the end.
Local building inspection is a form of state regulation police, ie its a government sponsored/defined organisation which polices regulations.  If the electors express a preference for low regulation/low tax then expanding this force this runs contrary to the preferences expressed by the electorate.  It has to be paid for one way or another and if we dont want to pay for it we cant expect to have it.
Who will write this?  Who will do the product testing.  If its to be independent of the industry it will need to be state supported or a tax on the industry which is then used by one level of Government or another to sponsor independent work.  The building regulations are already pretty crisp from my reading so we are going to need some even better people and thus we will have to pay them more.
This whole discussion started because of a clear example where this doesn’t work to protect the customer.    So everything you say in the above quote may be true, but it doesnt address the point that triggered the discussion.
IMHO the other thing to bear in mind is that regulation, other than for life threatening matters, doesn’t materially advantage those who have the means to sue.  In fact it probably disadvantages them because effective regulation enforced other than through the courts costs money and they are quite likely to end up paying more (through taxation, levies or restrictions on what they can do to rip other people off) than it would cost them simply to sue on the occasions when things go wrong for them.  It may advantage such people if there is some ineffective regulation, it doesnt cost much, fools a good proportion of people for long enough to secure their vote, and provides a reason to argue against regulation in the future!
Thus the only thing that almost everyone has a shared motivation to regulate well is life threatening matters.  Even that isnt quite as simple as it first seems, those who are unlikely to live in tower blocks in Kensington and Chelsea have little motivation to regulate well even life threatening things that only affect such tower blocks!  Ultimately it comes down largely to an argument about the extent we should, as a nation, protect those who do not have the means, at the expense of those who do.  Answers to that one in the ballot box please!
My fundamental point though is that we, by and large, get what we vote for, within the constraints of the real world, which is populated by imperfect people most of whom act largely in their own self interest.  Therefore we have to take some responsibility for that.  Put another way Disgusted of Tunbridge Wells should IMHO consider whether their own voting choices have contributed to the situation with which they are expressing disgust and, if they have, should recognise that their moral right to complain is severely curtailed.  I am not referring to anyone in particular, but I would be fairly certain that some who complain about the situation both here and elsewhere fall into this category.
@ian-w  Getting back to the problem in hand, what do you plan to do next?
If there is any way we can assist with pointers to things you could do (or have done fairly cheaply) to improve your system I, and I’m sure others, remain happy to try.  As I said earlier your principal component, the Vaillant 10/12kW heat pump, is a good piece of kit so this situation is surely recoverable quite possibly at modest cost.
Even if all you did was to work out, with the help of those here, what actually must be done (and what could be left) that might well help your next steps
