There’s a growing shift happening in how we think about energy, and it’s no longer just about efficiency or cost. It’s about control.
What happens when power isn’t where you need it? What happens when the grid goes down? And what happens when the “solutions” on paper don’t translate into real life?
That’s where portable power starts to get interesting.
In this video, we take a closer look at one of the most talked-about units in this space, the EcoFlow DELTA 3 Max, in a working rural property, where energy isn’t always convenient, predictable or neatly wired.
Because that’s the real question most reviews don’t answer.
Not “what does it do?”
But “what does it actually change?”
Can a portable power station genuinely replace extension cables stretched across fields? Can it handle the kind of demanding, high-surge loads that tools require? And more importantly, does it make day-to-day life easier, or just more complicated?
This video tackles those questions head-on.
If you’re looking at EcoFlow kit (particularly the DELTA range) these will give you a bit of a saving:
You can buy direct from EcoFlow here: https://renewableheatinghub.co.uk/go/ecoflow
Use code: RHHEF5
Validity: 21 April-31 May 2026
This gives you 5% off all DELTA Series products
Alternatively, if you prefer Amazon UK: https://amzn.to/3QrFMlG
Use code: K4P3S2TG
