22kW MasterTherm Inverter Heat Pump
Here is an installation we completed nearly six years ago in a 326-sqm solid stone, single glazed Manse in the Scottish Borders, that only had insulation in the loft.
We installed a 22kW MasterTherm UK inverter heat pump on a direct heating design (no buffer or system separation) with internal temperature control. We upgraded the radiators only, and the majority of the radiators are fed by 10mm microbore.
The system works faultlessly, maintaining a constant temperature of 20C within the building. As you can see in the main photo, the outside temperature is -15C, well beyond the duty point design temperature, and it is still operating without a hitch.
An analysis of the bills over the six years has shown that the predicted reduction of 40% over the existing oil system promised at sale has been achieved. This is a substantial energy and carbon saving over the existing technology.
This is how well-designed and installed heat pump installations actually can work. Unfortunately, these results are not common in our industry due to the poor design practices stipulated by most manufacturers and merchants.
Mitsubishi Ecodan 11.2kW
Global Energy Systems Thurso ASHP
Vaillant AroTherm Plus 7kW
3 Comments
Alex B
I’ve been told by professional heat pump installers that our microbore (10mm) piping is a big no-no for heating with a heat pump. I’ve tried to find out the reason and it seems a bit off to me.
In reality the microbore in our home appears to be present from the radiators, into the walls and to the 15mm pipes under the floors.
Is this really a problem for a heat pump? Is flow rate the limiting factor?
VincePrince
We have a similar property in the Borders, except we have double glazing, currently running a biomass system, which works well (minimum 15mm piping!).
Was the above example eligible for Scottish Government grant with only single glazing?
