Households across Wales are being warned that delaying a solar installation could reduce their ability to export electricity back to the grid in future, potentially affecting the long-term financial return of their system.
Solar uptake in Wales has accelerated sharply. According to Microgeneration Certification Scheme (MCS) data, more than 19,000 new solar PV systems were installed across Wales in 2025, up from around 15,400 the previous year. That growth reflects rising energy prices, improved technology and growing interest in energy independence.
But rapid adoption comes with a consequence: local electricity networks are under increasing pressure.
When a homeowner installs solar panels, their Distribution Network Operator (DNO) must assess whether the local grid can accept exported electricity from that system. In areas where capacity is limited, export restrictions (known as export limits) can be applied. These caps restrict how much surplus electricity a home is allowed to send back into the grid.
According to Swansea-based installer Ulex Energy, around half of recent applications it has submitted to DNOs on behalf of customers have resulted in some form of export limitation.
For homeowners, this is not a technical footnote. Export capacity directly affects system value. Many households generate more electricity than they use during daylight hours, particularly in spring and summer. Being able to export that surplus via the Smart Export Guarantee (SEG) can materially improve payback calculations.
If export limits are imposed, excess generation may have to be curtailed unless the homeowner installs battery storage to retain it.
This does not mean solar is no longer viable… far from it. Even with limited export, self-consumption savings remain strong. However, it does change the financial modelling.
The underlying issue is infrastructure. Wales’ electricity networks were not designed for large numbers of decentralised generators feeding power back into the grid simultaneously. As more homes adopt solar, available export capacity in some local areas becomes progressively constrained.
The situation varies postcode by postcode. Some regions still have generous export allowances available; others are tightening rapidly. South Wales, where adoption has been particularly strong, is already seeing signs of constraint.
For homeowners considering solar, timing is now becoming part of the equation.
Installing sooner rather than later may preserve greater export flexibility, particularly in high-demand areas. Waiting could mean facing reduced export allowances or the need to incorporate battery storage from the outset.
That said, homeowners should avoid panic-driven decisions. A proper DNO application will clarify export capacity before installation proceeds. Any reputable installer should explain the export position clearly and factor it into system design.
The broader message is this: solar adoption in Wales has reached a point where grid infrastructure is starting to feel the strain. As deployment accelerates, access to full export capability may become less guaranteed in certain areas.
For households weighing up solar, the decision is no longer solely about whether the technology works. It is increasingly about how local grid conditions shape the long-term return and whether acting earlier secures a more flexible position.
As with much of the energy transition, infrastructure is now racing to catch up with consumer demand.
