									Wet Wall Heating - Wood Burners, Biomass, Small Scale, Biofuels &amp; Other Heating Alternatives				            </title>
            <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/</link>
            <lastBuildDate>Tue, 08 Sep 2026 18:12:29 +0000</lastBuildDate>
                        <title>RE: Wet Wall Heating</title>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7920</link>
                        <pubDate>Sun, 03 Apr 2022 10:58:29 +0000</pubDate>
                        <description><![CDATA[No, definititely wanted to link the heating to my heat pump. Thanks for all the help and advice :-)]]></description>
                        <content:encoded><![CDATA[<p>No, definititely wanted to link the heating to my heat pump. Thanks for all the help and advice :-)</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/">Wood Burners, Biomass, Small Scale, Biofuels &amp; Other Heating Alternatives</category>                        <dc:creator>bontwoody</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7920</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7913</link>
                        <pubDate>Sun, 03 Apr 2022 09:40:52 +0000</pubDate>
                        <description><![CDATA[@bontwoody No need for air valves as long as the run lengths are not too long. You can tell if there is an air lock, there would be no flow on that circuit and it is easy enough to get it ou...]]></description>
                        <content:encoded><![CDATA[<p>@bontwoody No need for air valves as long as the run lengths are not too long. You can tell if there is an air lock, there would be no flow on that circuit and it is easy enough to get it out, just close all the others.</p>
<p>Infra red, paint on heating and in plaster low voltage heaters are all direct electric heating. If you want that, go and buy a fan heater, it will cost a lot less and cost the same to run, a lot.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/">Wood Burners, Biomass, Small Scale, Biofuels &amp; Other Heating Alternatives</category>                        <dc:creator>BU</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7913</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7909</link>
                        <pubDate>Sun, 03 Apr 2022 09:07:04 +0000</pubDate>
                        <description><![CDATA[@bontwoody, I thought I saw reference that 3Thermo was waterless, but I could be wrong. 
I know that there are also infrared matts that you can place over your drywall, but that would also ...]]></description>
                        <content:encoded><![CDATA[<p>@bontwoody, I thought I saw reference that 3Thermo was waterless, but I could be wrong. </p>
<p>I know that there are also infrared matts that you can place over your drywall, but that would also require plastering – I think the running costs of those may be quite high.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/">Wood Burners, Biomass, Small Scale, Biofuels &amp; Other Heating Alternatives</category>                        <dc:creator>Mars</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7909</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7908</link>
                        <pubDate>Sun, 03 Apr 2022 08:58:34 +0000</pubDate>
                        <description><![CDATA[@editor I did see those, but wanted a system for a drywall rather than one you need to plaster over. What makes you think it is waterless?]]></description>
                        <content:encoded><![CDATA[<p>@editor I did see those, but wanted a system for a drywall rather than one you need to plaster over. What makes you think it is waterless?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7908</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7906</link>
                        <pubDate>Sun, 03 Apr 2022 08:18:01 +0000</pubDate>
                        <description><![CDATA[@editor Be very cairfull, I have requested the data for the 3THERMO product as it is not on their website. Why, makes me question the capabilities of it. Theoretically it looks a good idea, ...]]></description>
                        <content:encoded><![CDATA[<p>@editor Be very cairfull, I have requested the data for the 3THERMO product as it is not on their website. Why, makes me question the capabilities of it. Theoretically it looks a good idea, if it works. I will update here when and if I get a reply.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7906</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7902</link>
                        <pubDate>Sat, 02 Apr 2022 20:33:56 +0000</pubDate>
                        <description><![CDATA[Another installer we know says he fitted a 3thermo unit with an ASHP and it worked really well. I think (but I could be wrong) it&#039;s waterless. The UK 3Thermo website, however, appears to be ...]]></description>
                        <content:encoded><![CDATA[<p>Another installer we know says he fitted a 3thermo unit with an ASHP and it worked really well. I think (but I could be wrong) it's waterless. The UK 3Thermo website, however, appears to be compromised so I won't share the link here. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7902</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7899</link>
                        <pubDate>Sat, 02 Apr 2022 20:04:17 +0000</pubDate>
                        <description><![CDATA[@heacol, that&#039;s a great tip. I shudder to think of the upheaval that driving a nail through piping in the wall would be. Nightmare situation.]]></description>
                        <content:encoded><![CDATA[<p>@heacol, that's a great tip. I shudder to think of the upheaval that driving a nail through piping in the wall would be. Nightmare situation. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7899</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7897</link>
                        <pubDate>Sat, 02 Apr 2022 19:05:09 +0000</pubDate>
                        <description><![CDATA[Thats great Brendon, thank you for the advice. Do you think there is any need for an air release valve? I could put the spreader plates on at a slight angle to make sure one end was higher a...]]></description>
                        <content:encoded><![CDATA[<p>Thats great Brendon, thank you for the advice. Do you think there is any need for an air release valve? I could put the spreader plates on at a slight angle to make sure one end was higher and put it there?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7897</guid>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7894</link>
                        <pubDate>Sat, 02 Apr 2022 17:04:41 +0000</pubDate>
                        <description><![CDATA[Hi Mark
It is very possable to install under floor heating on a wall. Spreader plates are a good idea, use 16mm pipe and keep the run lenths to arround 60 meters. This will allow a higher v...]]></description>
                        <content:encoded><![CDATA[<p>Hi Mark</p>
<p>It is very possable to install under floor heating on a wall. Spreader plates are a good idea, use 16mm pipe and keep the run lenths to arround 60 meters. This will allow a higher velocity which will increase the efficiency and reduce the posibility of air locks. With a little planning it will be a relitivly easy install. I would install 1/2 inch battens on the current wall, attach the spreader plates to them and then put plaster board on top of that to finish the wall.</p>
<p>Just do not hang any pictures without the help of a thermal camera :)</p>
<p>Brendon</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7894</guid>
                        <title>Wet Wall Heating</title>
                        <link>https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7878</link>
                        <pubDate>Fri, 01 Apr 2022 17:23:51 +0000</pubDate>
I looking for a way of heating upstairs rooms with a suspended timber floor. The downstairs room will have UFH in a screed slab powered by an ASHP.
Ive considered oversized radiators an...]]></description>
<p>I looking for a way of heating upstairs rooms with a suspended timber floor. The downstairs room will have UFH in a screed slab powered by an ASHP.</p>
<p>Ive considered oversized radiators and even air to air AC units, but like the idea of using an UFH system in a timber framed wall.</p>
<p>There are systems out there for doing this (https://surfaceheating.co.uk/product/drywall-wall-heatingcooling-system/) but I cant find anyone who stocks them.</p>
<p>I wondered if it might be possible to mimic such a system with aluminium speader plates under plasterboard. Ive seen comments from people about air locks and wondered how the proprietary systems solve this problem? Perhaps just place an air release valve at the top.</p>
<p>Has anyone out there tried to do this?</p>
<p>Thanks in advance</p>
<p>Mark</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/unusual-heating-alteratives/wet-wall-heating/#post-7878</guid>
Served from: renewableheatinghub.co.uk @ 2026-09-08 19:12:29 by W3 Total Cache
