									Volumisers in Heat Pump Systems: Does Placement Matter? - Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls				            </title>
            <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/</link>
            <lastBuildDate>Fri, 15 May 2026 02:11:23 +0000</lastBuildDate>
                        <title>RE: Volumisers in Heat Pump Systems: Does Placement Matter?</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/7/#post-45940</link>
                        <pubDate>Tue, 06 May 2025 21:42:17 +0000</pubDate>
                        <description><![CDATA[You’re absolutely right that during defrost the refrigeration cycle reverses, not the flow and return pipes. And yes, the cold water produced by defrost enters the flow side of the system… t...]]></description>
                        <content:encoded><![CDATA[<p class="p1"><span class="s1">You’re absolutely right that during defrost the refrigeration cycle reverses, not the flow and return pipes. And yes, the cold water produced by defrost enters the flow side of the system… that’s exactly the point I was building toward.</span></p>
<p class="p2"> </p>
<p class="p1"><span class="s1">The key issue here is how that cold water interacts with the heating circuit. If there’s no thermal buffer (in this case, a volumiser) on the flow, then that cold slug heads straight into the emitters. Because flow temps are typically what the radiators “see,” this can cause an immediate and noticeable drop in radiator surface temperatures, reducing comfort for the occupants, even if only briefly.</span></p>
<p class="p2"> </p>
<p class="p1"><span class="s1">When a volumiser is installed on the return, it does nothing to moderate this cold influx. It simply adds volume at the cooler end of the system, where flow and return temperatures are already much closer together. In contrast, when the volumiser is installed on the flow, it stores water that is several degrees warmer than the return (typically at the current flow temperature) and this warmer mass helps temper the defrost water before it reaches the emitters.</span></p>
<p class="p2"> </p>
<p class="p1"><span class="s1">This placement mitigates the thermal shock and helps maintain comfort during and after defrost cycles. Temperature is a valuable commodity in low-temperature systems like heat pumps, and conserving that energy (especially during transitional events) is key to performance and efficiency.</span></p>
<p class="p1"><span class="s1">So yes, volumisers can technically go on the flow or return, but in practice, only the flow-side position delivers that buffering effect where it matters,<span class="Apple-converted-space">  </span>before the emitters. That’s the core of my argument.</span></p>
<p class="p1"><span class="s1">I’ve reread my post and my wording isn’t clear so I’ll update it now.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/7/#post-45940</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/7/#post-45912</link>
                        <pubDate>Tue, 06 May 2025 17:51:03 +0000</pubDate>
                        <description><![CDATA[@johnmo are you commenting on @editor s opening post? If it is then I guess you’re commenting on this part of it;
”If the Volumiser is on the Return Side:
Cold water from defrost ...]]></description>
<p>Not sure if you have the defrost cycle and what happens correct. The heat pump reverses the refrigeration cycle not the heating water. The circulation pump runs as normal. Hot and cold refrigerator gases swop roles at the condenser only. So instead of being in heat mode it moves to cooling mode.</p>
<p>So cold water from defrost does not enter the return it enters the flow side. But a big volume of water on the flow side will allow some mixing and less very cold water will hit the radiator. Just slightly cooled water.</p>
<p>@johnmo are you commenting on @editor s opening post? If it is then I guess you’re commenting on this part of it;</p>
<p>”<strong>If the Volumiser is on the Return Side</strong>:</p>
<ul class="wp-block-list">
<li style="list-style-type: none">
<li>Cold water from defrost flows directly into the return pipe, which is already at a lower temperature during heating mode.</li>
</li>
<li>This cold water mixes with the cooler return water, further reducing the temperature entering the radiators.</li>
</li>
<li>Result: Radiators can receive a sudden influx of colder water, causing potential cooling and discomfort.”</li>
<p>The first bullet point is incorrect as you say @johnmo.</p>
<p>interpretation:  What actually happens in the context of this article is the defrost water leaves the heat pump in a chilled state and continues to flow along The Primary Flow Pipe straight into the emitter circuit (ie the secondary flow pipe). This means it passes through all the emitters absorbing heat from the emitters instead of adding heat. The defrost water then enters the volumiser on the return side. Mixing with the existing warmer return water. So this is described as not good… because it has passed through all the emitters in its chilled state. It only mixes with the volume of return water in the volumiser after it has robbed the emitters of some of their heat.</p>
<p>By placing the volumiser on the Flow side the chilled water first mixes with the higher flow temperature store in the volumiser. Before it enters the emitter circuit.</p>
<p>it might be that @editor has already edited this part of the article but I haven’t seen the final copy.</p>
<p>Of course, this is just one view of the intended document. &#x1f913;</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>SUNandAIR</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/7/#post-45912</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-45825</link>
                        <pubDate>Sun, 04 May 2025 15:05:02 +0000</pubDate>
                        <description><![CDATA[Not sure if you have the defrost cycle and what happens correct. The heat pump reverses the refrigeration cycle not the heating water. The circulation pump runs as normal. Hot and cold refri...]]></description>
                        <content:encoded><![CDATA[Not sure if you have the defrost cycle and what happens correct. The heat pump reverses the refrigeration cycle not the heating water. The circulation pump runs as normal. Hot and cold refrigerator gases swop roles at the condenser only. So instead of being in heat mode it moves to cooling mode.
So cold water from defrost does not enter the return it enters the flow side. But a big volume of water on the flow side will allow some mixing and less very cold water will hit the radiator. Just slightly cooled water.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Anonymous 5011</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-45825</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44421</link>
                        <pubDate>Fri, 21 Mar 2025 21:12:22 +0000</pubDate>
                        <description><![CDATA[No not auto adapt running hotter at cheaper times cooler at expensive times.  Off is when demand is met on milder days.  System won’t run below 32c without cycling]]></description>
                        <content:encoded><![CDATA[<p>No not auto adapt running hotter at cheaper times cooler at expensive times.  Off is when demand is met on milder days.  System won’t run below 32c without cycling </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Gary</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44421</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44419</link>
                        <pubDate>Fri, 21 Mar 2025 20:57:41 +0000</pubDate>
                        <description><![CDATA[@gary some the trends you&#039;ve posted show the LWT is at the setpoint.  They also show the setpoint is changing and they show the compressor  frequency at zero (not running).  This makes me th...]]></description>
                        <content:encoded><![CDATA[<p>@gary some the trends you've posted show the LWT is at the setpoint.  They also show the setpoint is changing and they show the compressor  frequency at zero (not running).  This makes me think you're running with a control scheme that's changing the LWT to meet a room temperature demand and then switching off when the demand is met.  Do you have an EcoDan installed with room temperature auto adapt?</p>
<p>Bob</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>BobTSkutter</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44419</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44413</link>
                        <pubDate>Fri, 21 Mar 2025 19:34:21 +0000</pubDate>
                        <description><![CDATA[Yes the examples I gave weren’t when it was at its coldest that week when it didn’t get above zero and dropped to -4 overnight I don’t have data for then but it was running 24/7]]></description>
                        <content:encoded><![CDATA[<p style="text-align: justify">Yes the examples I gave weren’t when it was at its coldest that week when it didn’t get above zero and dropped to -4 overnight I don’t have data for then but it was running 24/7 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44413</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44412</link>
                        <pubDate>Fri, 21 Mar 2025 19:28:00 +0000</pubDate>
                        <description><![CDATA[@gary mine was “designed” to 45, bit system can’t get above 36. That bit was nonsense. 
from looking at your graphs of one day: you’ve got loads of scope to get more energy into  your house...]]></description>
                        <content:encoded><![CDATA[<p>@gary mine was “designed” to 45, bit system can’t get above 36. That bit was nonsense. </p>
<p>from looking at your graphs of one day: you’ve got loads of scope to get more energy into  your house, if you want/need to,  by changing your control strategy. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>davidnolan22</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44412</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44406</link>
                        <pubDate>Fri, 21 Mar 2025 18:07:33 +0000</pubDate>
                        <description><![CDATA[Correct it’s designed to 45 at -2C and can’t get to 45C house isn’t cold but 20 rather than 21C]]></description>
                        <content:encoded><![CDATA[<p>Correct it’s designed to 45 at -2C and can’t get to 45C house isn’t cold but 20 rather than 21C</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44406</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44405</link>
                        <pubDate>Fri, 21 Mar 2025 17:57:54 +0000</pubDate>
                        <description><![CDATA[Hello, I confused about why this is a problem for you.  Is your house not getting warm enough?
Thanks Bob]]></description>
<p>he issue is that the heat pump cannot get to the set flow temperature during the coldest periods</p>
<p>Hello, I confused about why this is a problem for you.  Is your house not getting warm enough?</p>
<p>Thanks Bob</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44405</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44384</link>
                        <pubDate>Fri, 21 Mar 2025 10:58:22 +0000</pubDate>
                        <description><![CDATA[Can I just say that this is what I think too, but I was waiting for @gary to answer the questions before being certain about the conclusion. 
Heat pumps need to be on 24*7 during the height...]]></description>
<p>Hi, </p>
<p>I'm saying this from my experience, not as a heating expert:</p>
<p>Your compressor is turned off for too long periods. You may think the UFH is at temp, but low down its cooling. and when its OAT is cold, needs constant flow going through it. I would turn down the flow temp and run it constantly.  DT 10 the unit straining like mad to heat the screed. I too though my unit was undersized, but after I turned to flow down and ran it constant, I could keep the house topped up with heat for 8kw an hour produced at freezing (heat loss 11) and the pump had lots more in the tank. </p>
<p>My graphs looked just lie yours when was aiming for a temp that the screed could not get to. </p>
<p>In mild weather, I tend to batch heat a bit more until I get a weather comp that I'm happy with</p>
<p>at DT10, your little unit is putting in over 10-11kw of energy, then is idle or just ticking over for large parts in the day. You need to even this out more</p>
<p>Can I just say that this is what I think too, but I was waiting for @gary to answer the questions before being certain about the conclusion. </p>
<p>Heat pumps need to be on 24*7 during the height of the heating season, assuming that they have been correctly sized.  The FT needs to be turned down as low as possible (to be done with thermostats, TRVs etc set well above desired temperature).  In the shoulder season, or with a well oversized heat pump, batch heating may be possible and <em>may</em> work out cheaper, although there is no guarantee. </p>
<p>Operated this way its reasonable to expect the running cost to be similar to gas or oil, or a little cheaper.  If you qualify for OvOs 15p tariff then definitely much cheaper, particularly if you have UFH and so can operate at a max FT of 35C or below. </p>
<p>As a concrete example I am operating with radiators and a max temp of 42C, the heat pump is working out ~12% cheaper than gas.  Im buying electricity for it at an average of 19p by using EON Next Drive which gives 7hrs cheap rate at night in return for a 10% daytime price hike.  I operate 24*7 without setback or set forward, so I'm not exploiting the overnight cheap rate to any great extent.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/volumisers-in-heat-pump-systems-does-placement-matter/paged/6/#post-44384</guid>
