									Swedish retrofit product that guarantees heat pump SCOPs of 10! - Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls				            </title>
            <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/</link>
            <lastBuildDate>Fri, 13 Nov 2026 18:07:49 +0000</lastBuildDate>
                        <title>RE: Swedish retrofit product that guarantees heat pump SCOPs of 10!</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61309</link>
                        <pubDate>Sun, 05 Apr 2026 13:28:47 +0000</pubDate>
                        <description><![CDATA[@jamespa seeproposal to improve that Swedish approach: at the electric power supply, swap L and N on warm days to make the heat pump reverse, thus cooling down rooms while converting heat ga...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa <br />see https://en.wikipedia.org/wiki/Indiana_pi_bill<br /><br />My proposal to improve that Swedish approach: at the electric power supply, swap L and N on warm days to make the heat pump reverse, thus cooling down rooms while converting heat gain into electric energy.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>LeJamaisContent</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61309</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61192</link>
                        <pubDate>Wed, 01 Apr 2026 19:53:26 +0000</pubDate>
                        <description><![CDATA[With enough PV and fudging definitions to mean COP = heat output / grid input it&#039;s doable
                        <content:encoded><![CDATA[<p>@jamespa Why not two or more - double your COP to TWENTY!!!!!&#x1f929; Toodles.</p>
<p>With enough PV and fudging definitions to mean COP = heat output / grid input it's doable</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>bobflux</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61192</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61191</link>
                        <pubDate>Wed, 01 Apr 2026 19:19:12 +0000</pubDate>
                        <description><![CDATA[I fear you may be right!
Im still up for supporting the repeal of the second law of thermodynamics.  Now there is a policy for (the many) crackpot politicians to whom the truth means very l...]]></description>
<p>I reads this is not available outside <span>01/04. Best to buy half a dozen, as it will fly off the shelves...</span></p>
<p>I fear you may be right!</p>
<p>Im still up for supporting the repeal of the second law of thermodynamics.  Now there <em>is</em> a policy for (the many) crackpot politicians to whom the truth means very little.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61191</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61188</link>
                        <pubDate>Wed, 01 Apr 2026 18:18:20 +0000</pubDate>
                        <description><![CDATA[I reads this is not available outside 01/04. Best to buy half a dozen, as it will fly off the shelves...
And don´t forget to get a few plug in PV kits as well. It seems Ed found a way to ma...]]></description>
<p>I want one and plan to add it to my Christmas list, along with the repeal of the second law of thermodynamics.</p>
<p>And don´t forget to get a few plug in PV kits as well. It seems Ed found a way to make them 60% efficient.. &#x1f606; </p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Batpred</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61188</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61179</link>
                        <pubDate>Wed, 01 Apr 2026 09:27:41 +0000</pubDate>
                        <description><![CDATA[I enthusiastically started watching the video, even though the 10 seemed way too good, then the size of the valve seemed miraculously small, the concept of reverse wc odd, but I kept going b...]]></description>
                        <content:encoded><![CDATA[<p>I enthusiastically started watching the video, even though the 10 seemed way too good, then the size of the valve seemed miraculously small, the concept of reverse wc odd, but I kept going because I wanted it to be true. Well done Mars, you gave me a good laugh and made my day! </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>MK4</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61179</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61178</link>
                        <pubDate>Wed, 01 Apr 2026 09:23:31 +0000</pubDate>
                        <description><![CDATA[@jamespa Why not two or more - double your COP to TWENTY!!!!!&#x1f929; Toodles.]]></description>
                        <content:encoded><![CDATA[@jamespa Why not two or more - double your COP to TWENTY!!!!!&#x1f929; Toodles.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61178</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61177</link>
                        <pubDate>Wed, 01 Apr 2026 09:20:00 +0000</pubDate>
                        <description><![CDATA[I want one and plan to add it to my Christmas list, along with the repeal of the second law of thermodynamics.]]></description>
                        <content:encoded><![CDATA[<p>I want one and plan to add it to my Christmas list, along with the repeal of the second law of thermodynamics.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61177</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61175</link>
                        <pubDate>Wed, 01 Apr 2026 09:17:21 +0000</pubDate>
                        <description><![CDATA[I looked at the publishing date before I watched the ‘presentation’&#x1f606; Thank you Mars - good on you! Toodles.]]></description>
                        <content:encoded><![CDATA[<p>I looked at the publishing date before I watched the ‘presentation’&#x1f606; Thank you Mars - good on you! Toodles.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61175</guid>
                        <title>Swedish retrofit product that guarantees heat pump SCOPs of 10!</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61171</link>
                        <pubDate>Wed, 01 Apr 2026 07:11:13 +0000</pubDate>
                        <description><![CDATA[A new Swedish retrofit product has been announced guaranteeing a heat pump SCOP of 10 for just £199!
The system combines a heat-recovery TRV with an adaptive outdoor sensor using reverse we...]]></description>
                        <content:encoded><![CDATA[<p class="p1"><span class="s1">A new Swedish retrofit product has been announced </span><span class="s2">guaranteeing a heat pump SCOP of 10</span><span class="s1"> for just £199!</span></p>
<p class="p1"><span class="s1">The system combines a heat-recovery TRV with an adaptive outdoor sensor using </span><span class="s2">reverse weather compensation</span><span class="s1"> to dynamically reduce system demand and recycle internal heat gains.</span></p>
<p class="p1"><span class="s1">Full breakdown here: <a href="https://youtu.be/L_JIcUglbmM">https://youtu.be/L_JIcUglbmM</a></span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/swedish-retrofit-product-that-guarantees-heat-pump-scops-of-10/#post-61171</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-13 18:07:49 by W3 Total Cache
