									Heat Pump Manufacturers Recommending Buffer Tanks - Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls				            </title>
            <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/</link>
            <lastBuildDate>Sat, 13 Jun 2026 21:18:35 +0000</lastBuildDate>
                        <title>RE: Heat Pump Manufacturers Recommending Buffer Tanks</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63412</link>
                        <pubDate>Fri, 29 May 2026 19:49:39 +0000</pubDate>
                        <description><![CDATA[How true, and an argument I am having elsewhere with those who want every ASHP installation to be totally bespoke, even at the end of the market where you are fitting a 5kW come what may bec...]]></description>
<p>Perfect is the enemy of good.  I can’t perfectly control some of the “overshoot” in house temperature .. ie due to sunshine and / or burning too much firewood / and/or rapid ambient temperature changes from chinooks … and I’m not worried about that either.  A few tics in house temp higher or lower isn’t a big deal .. a first world problem really. </p>
<p>How true, and an argument I am having elsewhere with those who want every ASHP installation to be totally bespoke, even at the end of the market where you are fitting a 5kW come what may because its the lowest rated one most manufacturers do.</p>
<p>The tricky one is the hydronic slab due to its much slower reaction time as you point out.  My strategy with it is to run it on the cool side during the heating season (about 21C) as at that temp it would act as a base load heat source for the house without any overshoot possible.  </p>
<p>That should work, although there is still the possibility of overshoot depending on the reaction time of the other components</p>
<p>"11392" data-postid="63411"]</p>
<p>Our house is actually really stable regardless of ambient temperature due to how well insulated and tight it is .. where some houses drift materially within an hour, ours drifts over about 4 hrs if that makes sense .. even at -30C!</p>
<p>Ours is like that as well, despite being a 1930s originally solid wall (albeit partly upgraded) house.  The excursions due to delay will likely be slow, but nonetheless annoying.  As I say its house dependent.  Ours now runs (except at the very end of the season) on pure weather compensation with no thermostats or other room influence, <em>much</em> better than it ever ran with loads of TRVs etc.  Basically the <em>only</em> variable taken into account by <em>any part</em> of the control system is OAT.  Its not absolutely perfect, but its a whole lot better than it was previously</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63412</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63411</link>
                        <pubDate>Fri, 29 May 2026 19:40:47 +0000</pubDate>
                        <description><![CDATA[Perfect is the enemy of good.  I can’t perfectly control some of the “overshoot” in house temperature .. ie due to sunshine and / or burning too much firewood / and/or rapid ambient temperat...]]></description>
                        <content:encoded><![CDATA[<p>Perfect is the enemy of good.  I can’t perfectly control some of the “overshoot” in house temperature .. ie due to sunshine and / or burning too much firewood / and/or rapid ambient temperature changes from chinooks … and I’m not worried about that either.  A few tics in house temp higher or lower isn’t a big deal .. a first world problem really. </p>
<p>The tricky one is the hydronic slab due to its much slower reaction time as you point out.  My strategy with it is to run it on the cool side during the heating season (about 21C) as at that temp it would act as a base load heat source for the house without any overshoot possible.  I would then rely on the fireplace and air handler loop (gas or HP) to raise the last few degrees to keep the space comfortable.  Sweaters also work great to even out some lumps in heating ;) Our house is actually really stable regardless of ambient temperature due to how well insulated and tight it is .. where some houses drift materially within an hour, ours drifts over about 4 hrs if that makes sense .. even at -30C!</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Tony.Stolz</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63411</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63406</link>
                        <pubDate>Fri, 29 May 2026 18:43:41 +0000</pubDate>
                        <description><![CDATA[Definitely.
If I were you I would read up a bit on the engineering topic of &#039;control theory&#039;.  This deals with how you control real world systems which have inbuilt delays (in the case if a...]]></description>
<p>My design vision was to allow the gas furnace to run on its own thermostat set a couple of degrees cooler (ie 18C) than the HP target (20C) and simply allow the furnace to cut in whenever the HP couldn’t keep up.  I also planned to set the HP to cut out below -15 or -20C as COP becomes pretty poor below that anyway.  The fireplace can also heat the whole house and even the slab on its own (it is an interesting set up) .. so my HP design needs to accommodate that as well.  Fun eh <img class="emoji lazy" role="img" src="data:image/svg+xml,%3Csvg%20xmlns='http://www.w3.org/2000/svg'%20viewBox='0%200%201%201'%3E%3C/svg%3E" data-src="https://s.w.org/images/core/emoji/17.0.2/svg/1f642.svg" alt="🙂" /> ?</p>
<p>Definitely.</p>
<p>If I were you I would read up a bit on the engineering topic of 'control theory'.  This deals with how you control real world systems which have inbuilt delays (in the case if a house these are enormous), noisy interference, nonlinearities, the possibility to control only in one direction (in this case up only) and other embuggerations.  The maths is horrendous and well beyond me even when I was at uni, but some understanding of the basic principles, even if you don't go beyond the effects of delay (what @bobflux calls phase shift) and the basic principles of pid, will definitely help. </p>
<p>I think you may have a simplistic view that measuring and controlling based on the desired output (in this case room temperature) is guaranteed to work.  Unfortunately, even though intuitively this the true, it is not true in fact.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63406</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63404</link>
                        <pubDate>Fri, 29 May 2026 18:30:06 +0000</pubDate>
                        <description><![CDATA[@bobflux … yeah .. we have to run glycol here. The HP I’m looking at can signal a secondary system … so I may experiment with that as a control for sure.  The fireplace is trickier in a way ...]]></description>
                        <content:encoded><![CDATA[<p>@bobflux … yeah .. we have to run glycol here. The HP I’m looking at can signal a secondary system … so I may experiment with that as a control for sure.  The fireplace is trickier in a way since it is obviously manual on/off and heat output is variable .. I think a house thermostat with a high temperature shut off for the HP will pretty much be needed from that perspective alone.  I could use a sensor on the chimney to simply cut off the HP when a fire is burning I suppose.  I’m pretty sure I’m going to need some on/off control for the HP due to these secondary heating systems plus my heat gain in the winter really can be substantial.  Keep in mind our houses here are often really well insulated and airtight .. my attic has 18-24” of insulation! On a -15C day with full sun our house can easily reach 24C with no heat running! Its tricky! </p>
<p>t</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63404</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63402</link>
                        <pubDate>Fri, 29 May 2026 18:08:43 +0000</pubDate>
                        <description><![CDATA[Interesting, I&#039;m also going to combine a hydronic fireplace and a heat pump. Currently the heat pump is installed, but the fireplace is still boxed in storage while I finish that damn drywal...]]></description>
                        <content:encoded><![CDATA[<p>Interesting, I'm also going to combine a hydronic fireplace and a heat pump. Currently the heat pump is installed, but the fireplace is still boxed in storage while I finish that damn drywall...</p>
<p>Some heat pumps have a "bivalent" dry contact output that means "It's too cold, I give up, turn on the boiler." You're supposed to wire that to the boiler, probably to its thermostat input. </p>
<p>Note if it's too cold for the heat pump to run, something has to be done about the water freezing in the pipes.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>bobflux</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63402</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63396</link>
                        <pubDate>Fri, 29 May 2026 17:51:43 +0000</pubDate>
                        <description><![CDATA[@jamespa Thanks guys.  Just for fun .. I should also point out that since we are so cold here in the winter (it usually stays above -30C but we do occasionally get down to -40C), it means se...]]></description>
                        <content:encoded><![CDATA[<p>@jamespa Thanks guys.  Just for fun .. I should also point out that since we are so cold here in the winter (it usually stays above -30C but we do occasionally get down to -40C), it means secondary heat is always needed.  Gas is the best choice in my area for use as a “peaker” under these conditions (since resistance electricity is not economical due to high capacity charges).  Also, many people, including me, also use fireplaces on cold days.  Personally, I burn about 3 cord/year .. mostly at temps below -15C.  <br /><br /></p>
<p>My design vision was to allow the gas furnace to run on its own thermostat set a couple of degrees cooler (ie 18C) than the HP target (20C) and simply allow the furnace to cut in whenever the HP couldn’t keep up.  I also planned to set the HP to cut out below -15 or -20C as COP becomes pretty poor below that anyway.  The fireplace can also heat the whole house and even the slab on its own (it is an interesting set up) .. so my HP design needs to accommodate that as well.  Fun eh :) ?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63396</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63381</link>
                        <pubDate>Fri, 29 May 2026 14:37:57 +0000</pubDate>
                        <description><![CDATA[As @bobflux says this is unlikely to work.
In principle no because, by adjusting the flow temp according to the outside temperature you are matching the heat input to the heat loss from t...]]></description>
<p>Re thermostat control.  I planned to use a slab temperature sensor wired to a thermostat to control that loop at about 24C in winter (lower floor) and a separate regulator thermostat for the air exchanger loop (both floors).  Both would be wired to signal the HP to run on demand.  </p>
<p>As @bobflux says this is unlikely to work.</p>
<p> I get how the HP should modulate using just the temperature curve alone .. but don’t you still need a way to turn it on/off once you get outside of the demand zone? (</p>
<p>In principle no because, by adjusting the flow temp according to the outside temperature you are matching the heat input to the heat loss from the house.  I know its a bit counterintuitive, but the physics is sound and it works.  The variation in heat gain from windows and life is generally small compared to the house loss, other than at the ends of the season, so not a problem and more to the point generally much less of a problem that the phase shift in a control loop involving room temperature.</p>
<p>To check the temperature inside the slab, I simply put a temperature probe on the return pipe from the slab.</p>
<p>Surely your heat pump does this anyway.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63381</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63377</link>
                        <pubDate>Fri, 29 May 2026 14:07:57 +0000</pubDate>
                        <description><![CDATA[Great news then! If your heat exchanger handles it, then it&#039;s going to work fine.
It needs to handle enough flow and suck enough thermal power from the water to allow the heat pump to run a...]]></description>
                        <content:encoded><![CDATA[<p>Great news then! If your heat exchanger handles it, then it's going to work fine.</p>
<p>It needs to handle enough flow and suck enough thermal power from the water to allow the heat pump to run above its minimum power level and not cycle. The fan in the air handler can't be allowed to turn off, if it does the heat pump will cycle like crazy. In other words you can use a thermostat to control both heat pump and heat exchanger fan. If the heat pump has remote control or indoor temperature probe you can set the flow temperature according to your cooling needs.</p>
<p>I got a bunch of fan coils dirt cheap, I'm going to install them. So I'll need motorized valves and a bit of automation to send 18°C water to the slabs, and 7°C water to the fan coils, and set the heat pump flow temperature via Modbus. Not possible to do both at the same time, but slab cooling is good during the night, outside air is not hot so it works at fantastic efficiency, whereas air cooling is good during the day where photovoltaic electricity is free.</p>
<p>Note well water is oxygenated (so it'll corrode steel) and sometimes a bit acidic (so it'll corrode copper) so I hope it doesn't mix in your circuit...</p>
<p>To check the temperature inside the slab, I simply put a temperature probe on the return pipe from the slab. When the circulator is running, it gives good information about how much heat is stored inside the concrete, ie how much heat is going to come out in the next hours, so the control system (currently an ESP32) uses that. Basically it does weather compensation on the slab return temperature.</p>
<p>Thermostat is useful to stop the heat pump and avoid overheating if sunlight enters through the windows and warms the room. It depends on room solar gain so it depends on the building. If you have a lot of solar gain it's useful, otherwise meh. Thermostat as regulation for a slab... in control terms the slab has a ton of phase shift so if there's too much gain it will oscillate. Gain is simply deltaT between flow temperature and air. So if you heat the slab with 23°C water a thermostat can work. With 30-35°C water you get massive overshoot.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63377</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63375</link>
                        <pubDate>Fri, 29 May 2026 13:37:41 +0000</pubDate>
                        <description><![CDATA[@bobflux I’ve been experimenting with the cooling loop for 2 years now .. running 7C well water through it to see if the exchanger could keep up with the AC demand (we have lots of gardens t...]]></description>
                        <content:encoded><![CDATA[<p>@bobflux I’ve been experimenting with the cooling loop for 2 years now .. running 7C well water through it to see if the exchanger could keep up with the AC demand (we have lots of gardens to water anyway .. so no water is wasted).  It works great and no condensation issues on the ducts.  The exchanger is rust proof and I designed in a drain for any condensation there .. so no issues.  Our air is super dry here (think desert) so we all run humidifiers.  BTW .. historically I ran the hydronic slab on timers since using air temp was too unreliable (oscillations) .. a slab temp sensor should eliminate that I think. </p>
<p>Re thermostat control.  I planned to use a slab temperature sensor wired to a thermostat to control that loop at about 24C in winter (lower floor) and a separate regulator thermostat for the air exchanger loop (both floors).  Both would be wired to signal the HP to run on demand.  Heat rises and my air always circulates .. so the slab would provide most of the houses heat.  I get how the HP should modulate using just the temperature curve alone .. but don’t you still need a way to turn it on/off once you get outside of the demand zone? (Heat gain from windows and “life” often increases winter house temperature above 20C).  The HP manufacturer appears to have designed their system using buffer temperature for this purpose (turning the HP on/off) .. my experiment would use the “manual” on/off terminals on the HP for this purpose and I’d leave the buffer terminals open. </p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63375</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63356</link>
                        <pubDate>Fri, 29 May 2026 07:15:27 +0000</pubDate>
                        <description><![CDATA[I doubt you will want to use (or be successful with using) the home thermostats, it will probably lead to oscillation because the slab will take so long to respond. 
Also remember that turn...]]></description>
<p> That said, the system is designed to turn on/off based on buffer temperature .. so I’m not sure if the system will be ok with me using the home thermostats to turn it on/off.  I may have to just try it to find out.  It does seem to have inputs that appear to enable external on/off control. </p>
<p>I doubt you will want to use (or be successful with using) the home thermostats, it will probably lead to oscillation because the slab will take so long to respond. </p>
<p>Also remember that turning off the thermostat won't stop the slab emitting stored heat (you essentially have a storage heater but without adjustable output flaps, so you need to get the amount stored right in advance!)</p>
<p>More likely just use weather compensation.  Something perhaps to experiment with but I would definitely start with weather compensation only and no thermostatic control</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/manufacturers-recommending-buffer-tanks/paged/5/#post-63356</guid>
Served from: renewableheatinghub.co.uk @ 2026-06-13 22:18:35 by W3 Total Cache
