									How To Balance Radiators &amp; the Role of the Lockshield Valve: A Homeowner&#039;s Guide - Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls				            </title>
            <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/</link>
            <lastBuildDate>Sun, 15 Mar 2026 23:37:31 +0000</lastBuildDate>
                        <title>RE: How To Balance Radiators &amp; the Role of the Lockshield Valve: A Homeowner&#039;s Guide</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45990</link>
                        <pubDate>Thu, 08 May 2025 13:41:14 +0000</pubDate>
                        <description><![CDATA[Good luck, I hope it all works out!]]></description>
                        <content:encoded><![CDATA[<p>Good luck, I hope it all works out!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45990</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45964</link>
                        <pubDate>Wed, 07 May 2025 18:07:55 +0000</pubDate>
                        <description><![CDATA[@jamespa So settings to date are as follows for now.
- **2011:** -10°C- **2012:** 15°C- **2021:** 40°C- **2022:** 25°C
I have put 2022 to 38c
Will see how it goes thanks £2900 later !]]></description>
                        <content:encoded><![CDATA[<p>@jamespa So settings to date are as follows for now.</p>
<p><span>- **2011:** -10°C</span><br /><span>- **2012:** 15°C</span><br /><span>- **2021:** 40°C</span><br /><span>- **2022:** 25°C</span></p>
<p>I have put 2022 to 38c</p>
<p>Will see how it goes thanks £2900 later !</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Alfapat</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45964</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45957</link>
                        <pubDate>Wed, 07 May 2025 15:43:07 +0000</pubDate>
                        <description><![CDATA[Really delighted to hear that.  I can&#039;t comment on homely but if you don&#039;t have it then you will likely want to readjust your weather compensation curve having removed the buffer.  At this t...]]></description>
                        <content:encoded><![CDATA[<p>Really delighted to hear that.  I can't comment on homely but if you don't have it then you will likely want to readjust your weather compensation curve having removed the buffer.  At this time of year it's probably nigh on impossible to get it right, most likely you will need to wait until the new heating season to get to final values.  If you need any help please just ask!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45957</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45954</link>
                        <pubDate>Wed, 07 May 2025 15:08:16 +0000</pubDate>
                        <description><![CDATA[At long last , I found a decent plumber and boiler expert locally to take the buffer out of the system(his advice) and change the piping the short distance that I had from the buffer from 22...]]></description>
                        <content:encoded><![CDATA[<p>At long last , I found a decent plumber and boiler expert locally to take the buffer out of the system(his advice) and change the piping the short distance that I had from the buffer from 22 to 28mm . Also down to one pump on the flow side directly into the CH and returning to HP . DHW remains as it was . A week into the modified system running and seems to be fine , there has been some frosty nights and cold airstream throughout the last two weeks, and that’s reflected with the heating on in the evening . I have brought the water law back to 38c from 40 , OK so far . Is Homely beneficial at  this time of year? </p>
<p>c</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/15/#post-45954</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-45952</link>
                        <pubDate>Wed, 07 May 2025 14:57:13 +0000</pubDate>
<p>@alfapat PM me and I can help, you will just neeed to find a standard plumber, not a specilaised one.</p>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-45952</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43494</link>
                        <pubDate>Wed, 05 Mar 2025 18:15:50 +0000</pubDate>
                        <description><![CDATA[I have messaged you . 
Thank you in anticipation of your help .]]></description>
                        <content:encoded><![CDATA[<p>I have messaged you . </p>
<p>Thank you in anticipation of your help .</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43494</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43468</link>
                        <pubDate>Wed, 05 Mar 2025 10:23:29 +0000</pubDate>
                        <description><![CDATA[@alfapat PM me and I can help, you will just neeed to find a standard plumber, not a specilaised one.]]></description>
                        <content:encoded><![CDATA[@alfapat PM me and I can help, you will just neeed to find a standard plumber, not a specilaised one.]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Brendon Uys</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43468</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43466</link>
                        <pubDate>Wed, 05 Mar 2025 09:12:51 +0000</pubDate>
                        <description><![CDATA[The old problem we had certainly was not right , but while it was using TRV&#039;s and open lockshieldsand the buffer, the costs were more controlled but still expensive as they were shutting dow...]]></description>
                        <content:encoded><![CDATA[<p>The old problem we had certainly was not right , but while it was using TRV's and open lockshieldsand the buffer, the costs were more controlled but still expensive as they were shutting down the system and then the HP had to make it up. I know from my Bills that they are higher than before but only because I am in this in between stage that now the temperatures in the house are more consistant the the whole idea of bypassing the the tank and or making it a volumiser has to be completed in order that the system is optimised , but I cant get someone to do it . I am committed to completing it , and then savings will be even more , Im sure of it , I am down the a flow temp of 40c now , previously 42 for two weeks,  meanwhile the daytime temperatures are helping things a little now.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43466</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43457</link>
                        <pubDate>Tue, 04 Mar 2025 21:00:00 +0000</pubDate>
                        <description><![CDATA[Before answering that, what do you feel is the problem which you would solve by reverting.  Earlier on you seemed to have made some progress albeit that we both recognise its still not optim...]]></description>
                        <content:encoded><![CDATA[<p>Before answering that, what do you feel is the problem which you would solve by reverting.  Earlier on you seemed to have made some progress albeit that we both recognise its still not optimal.  Why not leave it at the point of maximum progress, what do you think will improve if you change it back?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43457</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43456</link>
                        <pubDate>Tue, 04 Mar 2025 20:51:30 +0000</pubDate>
                        <description><![CDATA[Ok Guys James,
I cannot get anyone to respond to a request locally to come and have a look at converting a buffer tank to a Volumizer therefore eliminating the constant mixing in this . 
I...]]></description>
                        <content:encoded><![CDATA[<p>Ok Guys James,</p>
<p>I cannot get anyone to respond to a request locally to come and have a look at converting a buffer tank to a Volumizer therefore eliminating the constant mixing in this . </p>
<p>Is it the time of year or lack of committment at this time of year . Due to colder temps and time of year?</p>
<p>The reason being costs normally should have gone down daily given the OAT at this time of the year. So trying to get a plumber to submit his time and have a look at my system seems impossible . </p>
<p>Shoud I revert to my older system in involving opening lockshields and shuttin down TRV's to suit rooms . Certainly cheaper than exposing the flaw with the present set up or try and get a company to look at the proposed set up meantime .</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/how-to-balance-radiators-the-role-of-the-lockshield-valve/paged/14/#post-43456</guid>
