									Post Buffer Tank DUCA Circulating Pump Settings - Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls				            </title>
            <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/</link>
            <lastBuildDate>Thu, 21 May 2026 04:38:25 +0000</lastBuildDate>
                        <title>RE: Post Buffer Tank DUCA Circulating Pump Settings</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38477</link>
                        <pubDate>Mon, 09 Dec 2024 19:27:17 +0000</pubDate>
                        <description><![CDATA[@editor Hi, yes it does, thank you]]></description>
                        <content:encoded><![CDATA[@editor Hi, yes it does, thank you]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Potatoman</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38477</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38233</link>
                        <pubDate>Tue, 03 Dec 2024 15:04:24 +0000</pubDate>
                        <description><![CDATA[@potatoman I raised this with Secon, and here&#039;s what they say:
&quot;If you have a PWM connection then leave it in PWM. If not, auto is always safe. If it&#039;s a particularly long pipe run, you mig...]]></description>
                        <content:encoded><![CDATA[<p>@potatoman I raised this with Secon, and here's what they say:</p>
<p>"<span>If you have a PWM connection then leave it in PWM. If not, auto is always safe. If it's a particularly long pipe run, you might need constant pressure (CP) maximum speed."<br /><br />Does that help?</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38233</guid>
                        <title>RE: Post Buffer Tank Circulating Pump Settings</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38213</link>
                        <pubDate>Mon, 02 Dec 2024 22:03:02 +0000</pubDate>
                        <description><![CDATA[@editor  Hi, it is a DUCA]]></description>
                        <content:encoded><![CDATA[@editor  Hi, it is a DUCA
9266]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38213</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38212</link>
                        <pubDate>Mon, 02 Dec 2024 21:55:40 +0000</pubDate>
                        <description><![CDATA[Could you post a photo? Is it a Grundfos?]]></description>
                        <content:encoded><![CDATA[<p>Could you post a photo? Is it a Grundfos?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38212</guid>
                        <title>Post Buffer Tank DUCA Circulating Pump Settings</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38211</link>
                        <pubDate>Mon, 02 Dec 2024 21:34:41 +0000</pubDate>
                        <description><![CDATA[Does anybody know what is the best setting to have your heat pump, post buffer tank circulating pump set to, there are 5 settings: iPMW, AUTO, PP, CP &amp; CS.]]></description>
                        <content:encoded><![CDATA[<p>Does anybody know what is the best setting to have your heat pump, post buffer tank circulating pump set to, there are 5 settings: iPMW, AUTO, PP, CP &amp; CS.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/circulating-pump-settings/#post-38211</guid>
Object Caching 62/65 objects using Redis
Served from: renewableheatinghub.co.uk @ 2026-05-21 05:38:25 by W3 Total Cache
