									A Smarter Smart Controller from Homely? - Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls				            </title>
            <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/</link>
            <lastBuildDate>Sat, 14 Nov 2026 18:44:46 +0000</lastBuildDate>
                        <title>RE: A Smarter Smart Controller from Homely?</title>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/10/#post-61165</link>
                        <pubDate>Tue, 31 Mar 2026 14:20:32 +0000</pubDate>
                        <description><![CDATA[Just noticed another Homely anomaly.
I have my DHW cycle set to 14.00 to coincide with excess PV output or winter max OATs. Just noticed the heat pump unexpectedly at full pelt at 15.00. Th...]]></description>
                        <content:encoded><![CDATA[<p>Just noticed another Homely anomaly.</p>
<p>I have my DHW cycle set to 14.00 to coincide with excess PV output or winter max OATs. Just noticed the heat pump unexpectedly at full pelt at 15.00. That means the homely is taking the time input from my Samsung controller, which is not internet enable and does not auto adjust for BST rather than the actual time via the homely servers/cloud and adjusting for BST. </p>
<p>That’s archaic and very odd, as part of the installation set up is to ensure all heat pump controller schedules are disabled. That means I now need to remember to manualy adjust the controller every 6 months. Annoying in this day and age.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Papahuhu</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/10/#post-61165</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/10/#post-60498</link>
                        <pubDate>Thu, 12 Mar 2026 12:56:01 +0000</pubDate>
                        <description><![CDATA[@benson Agreed. I believe  the COP gains with homely, if any, would be marginal vs a well set up weather comp. The only possible gains could be in the situation where unplanned heat inputs i...]]></description>
                        <content:encoded><![CDATA[@benson Agreed. I believe  the COP gains with homely, if any, would be marginal vs a well set up weather comp. The only possible gains could be in the situation where unplanned heat inputs into the house (from bodies, cooking or perhaps solar) allow the temporary reduction in flow temp that otherwise wouldn’t have happened. All the marketing nonsense about 30 and 40% reductions can only be in relation to a non WC system.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/10/#post-60498</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60497</link>
                        <pubDate>Thu, 12 Mar 2026 12:37:15 +0000</pubDate>
                        <description><![CDATA[@benson I’d like to try. But for the Samsung, because it isn’t web enabled off the shelf,  there is additional electronic hardware added to the outside unit and internal controller. If I sta...]]></description>
                        <content:encoded><![CDATA[@benson I’d like to try. But for the Samsung, because it isn’t web enabled off the shelf,  there is additional electronic hardware added to the outside unit and internal controller. If I start taking out resistors and PCBs I’m going to void my warranties. I can’t take that risk.]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60497</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60495</link>
                        <pubDate>Thu, 12 Mar 2026 12:11:51 +0000</pubDate>
                        <description><![CDATA[Worth trying perhaps. Time saving in commissioning with some units is definitely the USP of something like homely, no doubt about that.]]></description>
<p>I suppose it’s also a possibility that it might be even more efficient without the homely, it’s just I’ve never tried. </p>
<p>Worth trying perhaps. Time saving in commissioning with some units is definitely the USP of something like homely, no doubt about that. </p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>benson</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60495</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60490</link>
                        <pubDate>Thu, 12 Mar 2026 11:00:59 +0000</pubDate>
                        <description><![CDATA[@papahuhu I haven&#039;t changed anything with my install other than removing homely- with the exception of one small bedroom radiator upgrade (one out of the 16 or 17 emitters that I have). Thus...]]></description>
                        <content:encoded><![CDATA[<p>@papahuhu I haven't changed anything with my install other than removing homely- with the exception of one small bedroom radiator upgrade (one out of the 16 or 17 emitters that I have). Thus yes I blame homely for hampering my efficiency and my comfort and I have provided the evidence for this.</p>
<p>Your house, and ashp, is completely different to mine, thus comparing COP is meaningless. I'm not aware of anyone else who's done the direct comparison that I have with and without homely, so just sharing my experience. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60490</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60485</link>
                        <pubDate>Thu, 12 Mar 2026 10:40:35 +0000</pubDate>
                        <description><![CDATA[@benson But I have got a homely and I haven’t done anything to optimise it and I checked yesterday and my overall Feb COP was 4.2 and March COP to date was 5.3 and improving week on week. So...]]></description>
                        <content:encoded><![CDATA[<p>@benson But I have got a homely and I haven’t done anything to optimise it and I checked yesterday and my overall Feb COP was 4.2 and March COP to date was 5.3 and improving week on week. So I’m not sure it’s necessarily accurate to assign blame on one component of the overall install.</p>
<p>I suppose it’s also a possibility that it might be even more efficient without the homely, it’s just I’ve never tried. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60485</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60479</link>
                        <pubDate>Thu, 12 Mar 2026 09:16:30 +0000</pubDate>
                        <description><![CDATA[I would definitely recommend it. Now that I think I have nailed my settings, it is better all round really- cost and comfort-wise without homely. Looking at this month already my consumption...]]></description>
<p>I was reading your thread about your change from Homely to HA at the weekend and I would like to do something similar once I have time, but that is a way off at the moment so Homely is an easy option. </p>
<p>I would definitely recommend it. Now that I think I have nailed my settings, it is better all round really- cost and comfort-wise without homely. Looking at this month already my consumption is on track to be under what March 25 was. COP for the whole of March 25 was 3.2 (and looking at the historical local weather data it was quite warm for the second part of that month), and COP currently for this March is 4.2. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60479</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60399</link>
                        <pubDate>Tue, 10 Mar 2026 17:19:23 +0000</pubDate>
                        <description><![CDATA[It&#039;s not surprising, though.
Using a home as a heat battery does allow them to claim financial savings and financial savings look good on marketing literature. Financial savings are also so...]]></description>
<p>...</p>
<p>It seems that they have ‘downplayed’ the comfort factor in favour of the COP optimisation for TOU tariffs.</p>
<p>...</p>
<p>It's not surprising, though.</p>
<p>Using a home as a heat battery does allow them to claim financial savings and financial savings look good on marketing literature. Financial savings are also something most potential customers immediately understand whereas having to live in a sweatbox isn't as immediately obvious until the controller and Smart+ subscription have been bought.</p>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Majordennisbloodnok</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60399</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60386</link>
                        <pubDate>Tue, 10 Mar 2026 11:24:29 +0000</pubDate>
                        <description><![CDATA[@toodles 
The TOU functionality is tricky, but for those without a battery and on a tight budget I can see a little bit of overheating a reasonable compromise to keep heating costs down. Ev...]]></description>
                        <content:encoded><![CDATA[<p>@toodles </p>
<p>The TOU functionality is tricky, but for those without a battery and on a tight budget I can see a little bit of overheating a reasonable compromise to keep heating costs down. Everyone has their unique priorities, for me I most object to the warm bedrooms, if I knew I was unable to set them back effectively I’d never have agreed to install it. The thought of yet additional overheating to capture the cheap overnight power tariffs makes me cringe. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60386</guid>
                        <link>https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60382</link>
                        <pubDate>Tue, 10 Mar 2026 10:13:09 +0000</pubDate>
                        <description><![CDATA[@papahuhu My feeling is that Homely had been overthinking when deciding on the algorithm for Smart+. I have had a number of conversations with various personnel at Homely on this very subjec...]]></description>
                        <content:encoded><![CDATA[<p>@papahuhu My feeling is that Homely had been overthinking when deciding on the algorithm for Smart+. I have had a number of conversations with various personnel at Homely on this very subject.</p>
<p>It seems that they have ‘downplayed’ the comfort factor in favour of the COP optimisation for TOU tariffs. I explained to them that overheating for an hour or two to enable reducing higher cost energy consumption did not really suit our requirements. I also explained that although we were using a TOU tariff, we used a buffer in the form of a battery so using the energy at the time of most need didn’t incur the higher rate(s) of the tariff.</p>
<p>By the way, I haven’t yet heard about the recent(ish) trial of updated soft/firmware that I may or may not have participated in. I say ‘may or may not’ as I understand opting for the trial may have meant my Homely controller was particpating or might have remained as part of the ‘control’ group. Regards, Toodles.</p>]]></content:encoded>
						                            <category domain="https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/">Thermostats, Volumisers, Buffer Tanks, TRVs, Pumps, Piping, Valves, Radiators &amp; Controls</category>                        <dc:creator>Toodles</dc:creator>
                        <guid isPermaLink="true">https://renewableheatinghub.co.uk/forums/thermostats-trvs-pumps-valves/a-smarter-smart-controller-from-homely/paged/9/#post-60382</guid>
Served from: renewableheatinghub.co.uk @ 2026-11-14 18:44:46 by W3 Total Cache
