Recommendation for natural herbicide
We are organic, natural gardeners who avoid chemicals in our gardening practices. I’m looking for a natural herbicide to help control the grass and weeds that keep popping up on our driveway. In the summer, we’ve had success using a vinegar and salt mixture, but it really only works well in dry, hot weather. Does anyone have a suggestion for an effective natural herbicide that works in cooler or wetter conditions? Any advice would be greatly appreciated!
Follow our sustainability journey at My Home Farm:https://kirstenandmars.com
Not entirely sure you're going to like my take on this, @editor, but the best control I've found - natural or otherwise - is a heavy duty membrane underneath the gravel. I saw on your "My Home Farm" site that you've recently gone through a process of renovating your driveway so if you haven't laid a membrane in the course of that then it'd probably be a pretty significant job to do now.
Worth bearing in mind, though, that your gravel doesn't mind being shifted about so a bit of judicious use of the hoe will work well and is surprisingly easy to do. Alternatively, and especially if you ever decide to get a battery and solar PV, you might want to think about an electric weed burner.
1 x 6 kW GroWatt battery and inverter
"Semper in excretia; suus solum profundum variat"
Posted by: @majordennisbloodnokis a heavy duty membrane underneath the gravel
We paid for this in a our last house, great for the first year, then blown debris and sand/soil made a great place for weeds to grow. Sorry would never bother again.
Natural herbicide no idea. Pull spend a few hours pulling the weeds!
Maxa i32V5 6kW ASHP (heat and cooling)
6.5kW PV
13.5kW GivEnergy AIO Battery.
Posted by: @johnmoPull spend a few hours pulling the weeds!
We did that. It's ridiculously tiring because the driveway is about 30 metres long, and it doesn't end... they weeds come back relentlessly.
Posted by: @majordennisbloodnokyou might want to think about an electric weed burner.
We’ve actually got one already! That’s not a bad idea. It’s a 2kW unit, so it can eat up some power, but on a sunny day when the PV is generating, it’s a great time to use it. I may take it out.
@editor We have an electric weed scorcher; very cheap gadget from Mr. Lidl’s emporium a few years back, they feature every so often in spring and early summer. There is a very satisfying sound to weeds being scorched! Regards, Toodles.
Toodles, 77 years young and hoping to see 100 and make some ROI on my renewable energy investment!
And having posted, there is now an advert that has appeared for a company carrying out weed kill spraying!😅 Toodles.
Posted by: @toodlesAnd having posted, there is now an advert that has appeared for a company carrying out weed kill spraying!😅 Toodles.
🤣 The internet is always watching (and listening... and learning...) Yikes!
Posted by: @toodlesWe have an electric weed scorcher; very cheap gadget from Mr. Lidl’s emporium a few years back, they feature every so often in spring and early summer. There is a very satisfying sound to weeds being scorched!
We've got this one (below). Is yours the same-ish?
Similarish- ish! Ours is badged as a Florabest Thermal Weed Killer Model FUV 2000 A1 (I’m sure the ‘A1’ makes it the best model! 😉) I hope you appreciate the background in the photo that I went out in the spitting rain to take a few minutes back. The short power lead is plugged into a beefy extension lead and there is a cable retainer moulded into the handle which I use to hold the extension lead thus avoiding the plug and socket trailing. As to powering…. err.. not today, the typical yield from the 21 panels grosses approx. 0.3 kW and has been doing so for a few days now.🥲 though I have seen bursts of 1.5 kW momentarily.) Our weed killer usually takes 7-10 seconds to complete the scorching of a weed - I don’t envy you Mars with 100 metres of driveway to weed! Regards, Toodles.
- 25 Forums
- 1,612 Topics
- 34.8 K Posts
- 46 Online
- 1,887 Members
RE: British Gas versus Octopus: Two possible heat pump routes - how to evaluate them?
@jancold My day 1 of install over. It started at 7 wi...
By Lucia , 9 hours ago
RE: Undersized Vaillant ASHP and abandoned by installer
Ps to the above. The requirements on the heat pum...
By JamesPa , 9 hours ago
The greenhouse tomatoes have ,as usual, done well but t...
By Jancold , 9 hours ago
RE: Locational electricity pricing
@transparent Phew! ok have skim read despite hectic d...
By Lucia , 10 hours ago
RE: How to Solve Mould and Mildew Issues in Renovated Properties
The answer if you’re doing a major renovation is a MVHR...
By Judith , 10 hours ago
RE: In the middle of an ASHP installation - a few questions
@toodles thanks. What I have is an old and dirty lookin...
By benson , 11 hours ago
RE: Will heat pump heat hot water without increasing the temp in my home?
Do you have a reference for that directive @toodles ? ...
By Transparent , 11 hours ago
RE: Calculating inverter size to match battery size
I expect your Seplos kit came with some guidance as reg...
By Toodles , 14 hours ago
RE: Determining correct flow rate for a heat pump
It’s clear from what you say, above and what we have ex...
By SUNandAIR , 17 hours ago
@mphb - thanks, a useful link. Using google translate, ...
By cathodeRay , 22 hours ago
'If you are not part of the problem there's good money ...
By AllyFish , 22 hours ago
RE: Suitability of 45C flow temp with existing pipework
I've ordered a cheap borescope online and I'm going to ...
By Alex_N , 2 days ago
RE: Ecodan - flow rates, sensors, settings
Hi @rhh2348 , coming late to this thread as our Ecodan ...
By SUNandAIR , 2 days ago
RE: Agile: average import cost vs other tariffs?
@tim441 Last year I ‘netted’ about £400 that way so I h...
RE: Gas Combi to ASHP - Making sense of survey results and proposal.
@irmartini I think that @editor might sympathise with t...
RE: Heat pumps don't work: debunking myths & misconceptions
I applied for my G99 last November. Largely as a resul...
By IanMK13 , 3 days ago
Setback for Vaillant Arotherm Plus
Currently our Vaillant Arotherm Plus is set in fully We...
By JWilliams89 , 3 days ago
Unfortunately @burtis James is right. MCS is the Gove...
RE: How can I programme a setback for my Samsung Gen6 8kW heat pump?
@simonh Im not sure how useful they are but Ive attache...
By bontwoody , 5 days ago
Latest Topics
By Homonid 1 day ago
By Tim441 3 days ago
By Alex_N 3 days ago
By JWilliams89 3 days ago
By Toodles 4 days ago
By Jeff 4 days ago
By dssr 5 days ago
Solar Edge Inverters, returns recycling policy
By AllyFish 6 days ago
